Question about LaCie d2 Extreme 250GB External with Triple Interface USB 2.0/Firewire 400/800 - 300790U ... Hard Drive
Daisy chain my external hard-drives
I have 2 new LaCie 1TB hds. what  cables do I use to link them together??
  • 77 Answers
I don't think these drives are designed to be daisy chained. This worked for SCSI drives, but not for USB drives.
Posted on Jan 19, 2008
Harddisk woun't mount
The hard disk inside it has probably died. Take it out of the case and put it in the pc directly - if even now it's not responsive then it's surely dead - junk it. if now you can see it then the electronics if the case are dead - junk it and buy a new external case.
Jul 19, 2010 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Lacie 1 tb external hard drive won't work
ya .. put it for replacement and u get a new one for free .. just dont tell them u dropped it
Jan 10, 2010 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Hi ,my name is sameer i have 120gb lacie external hard disk,but is not suporting usb cable how can i change case pls help.............
just open your external HDD case, look for the connector (SATA or IDE), so buy new external harddisk case according the connector type.
Dec 20, 2009 | LaCie Big Disk External USB 2.0 1TB Hard...
Lacie 1tb external hard drive into ps3 is not regconised
I have the same issue, however with my verbatim 500g its ok. i believe it is because the lacie is a desktop external and therefore is compatable with windows xp and 7 alone.
Verbatim is a "portable" external hard drive which makes it compatible with several different systems. I would suggest returning it, I just formatted my old verbatim harddrive and set up mediaasharing. Through my router. You can actually route the lacie harddrive by going to my computer and right click the icon. Next go to share with; advanced settings and allow all. Then when you turn your ps3 on search for media servers... I would suggest to google media server for ps3 to get it all seet up. GOOD LUCK
Jun 07, 2009 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
La cie hard drive mount issues
I had the same problem and surprisingly, after many attempts to get the drive to mount with different connections, etc., the problem turned out to be the power adapter. If you've got the same kind of adapter on another drive, switch it out and see if your drive shows up. Good luck.
Nov 09, 2008 | LaCie Big Disk Extreme with Triple...
Firewire problem I think - I have a Sony Vaio laptop, the firewire port is 4 pin, it is connected to a LaCie CD Burner via 6 pin and the burner is daisy chained to a AcomData external hard drive via 6 pin....
If the hub has an external power supply it migh do the trick. That way you can have a backup port if needed.
Make sure the hard drive isn't connected to the hub. Sometime windows doesn't see it when its connected to a hub.
Jul 14, 2008 | Computers & Internet
Lacie 1tb hd
You can try to boot up with Linux LIVE cd and plug on the external HDD.
Apr 24, 2008 | LaCie d2 Extreme 250GB External with...
Lacie 1TB external hd won't mount!
check wires connecting them together first, ok?
then, turn off the LaCie, connect to your MacPro, and then turn on the drive..
that should show as a mounted drive.
need printer drivers update?
Mar 09, 2008 | LaCie Big Disk Extreme with Triple...
Don't get it
I notice that you had issues initially installing the drive. Is it possible hat your actions as noted in the link corrupted the HFS+ formatting that was shipped on the drive?
Review this link
If as you noted THIS WAS THE FIRST TIME YOU USED THE DRIVE, you have no data on the drive to loose or recover.
Especially if you believe your actions may have corrupted the formatting of the drive, reformatting may be the appropriate response and could yield a working drive eliminating many return headaches. However if this does not seam reasonable contact with LaCie as to why the drive did not work directly out of the box may be appropriate. (I did confirm in the drive specs that the drive should have been formatted correctly for an apple computer -- windows users need to reformat the drive before they can use it )
I hope this helps
Dec 14, 2007 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Computers & Internet Logo
592 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
