Question about Garden
Battery drains with mower key in the off position (SCAG ZERO TURN )I changed the ignition and the positive and negitve cables. I also just rebuilt the starter.
  • Chuck
    Chuck May 11, 2010
    WHEN YOU CHANGED THE IGNITION, DID YOU REPLACE IT WITH THE SAME NUMBERED SWITCH OR USE SOMETHING ELSE?
  • bowlmongonty May 11, 2010
    is the battery old? old batteries with dead cells will not hold a charge, they will drain down overnight or even within a few hours.
    Problem Solver:
  • 7 Answers
How long does it take to drain battery,check to make sure battery is good,no bad cells,hold load after charge,check to make sure electric clutch is not staying engaged with switch off...
Posted on Oct 02, 2009
What is the rectifier for the scag zero turn riding mower
You did not post what model this is on. However this is most likely the voltage regulator on the engine. The Scag brand has numerous issues with this item and electrical problems in general. I would contact SCAG about it.
Oct 21, 2016 | Garden
Key will not work in scag ztr
Go through your safety switches to make sure they are all being engauged proparly first.
Jul 28, 2014 | Scag SFZ48-600FS Freedom Z Zero Turn Mower
Mower was running shut off now does nothing when i turn key
If electric start check for low battery or loose battery cables. Could be a bad starter.
Jun 21, 2014 | Toro 52" 27hp Z Master Zero Turn Lawn...
My freedom z will not start
1. Be sure the fuel shutoff valve, located behind the
operator's seat, is completely open.
2. Sit in the operator's seat, fasten seat belt and place
the steering control levers in the neutral position.
3. Engage the parking brake.
4. Place the PTO switch in the disengaged position.
5. If the engine is cold, choke the engine as needed.
6. Move the engine throttle control to about half engine
speed.
7. Turn the ignition key to the START position and
release the key as soon as the engine starts. Do
not hold the key in the START position for more
than 15 seconds at a time. Allow at least 60
seconds between each cranking attempt to prevent
overheating of the starter motor. Prolonged cranking
can damage the starter motor and shorten battery
life.
8. Allow engine to warm before operating the mower.
Apr 05, 2014 | Scag SFZ61-730FS Freedom Z Zero Turn
Scag mower
If equipt, check the low oil switch circuit. Might be a failing switch.
Sep 24, 2013 | Scag STT61V-791DFI-SS Gas Turf Tiger...
Gravely zero turn lawn mower
are you sure you have the wire from the battery to the ignition key on?
Did you accidently knock the wire from the ignition key to the Starter relay off?
Aug 23, 2013 | Garden
I have a Scag zero turn mower and the fuses keep blowing 20-30 minutes into mowing my yard. It will die in the middle of mowing. I changed 5 fuses the other day withing my time of mowing. We checked all...
Does the scag have the control switches in one of the control arms? Have you tried taking a test light going to battery positive and hooking that into the feed supply side of the fuse( the side of the fuse that does not have battery power to it) if the test light is on this would mean that is shorting to ground somewhere within the harness at that time you'll need to wiggle each part in the harness while watching the light to go out or blink showing your close to the source of the short a close examination then you should locate it. Bare or chaffed wire.
Jun 11, 2013 | Garden
When I turn the key on to start my Troy-Bilt RZT 50 zero turn mower, there is nothing. No ignition light, nothing. I have a new battery and I put a new fuse unit but still nothing. Help!
Do you hear a clicking sound???NO ?? Do you have the speed ?turning handles in the extrem OUT position? Is the ground cable connected to the engine block?? Is the Red cable connected to the + Positive post on the battery?? Is the BLACK cable connected to the - Negetive post on the battery?? Why did you need to replace the fuse? Is the battery charged??
If none of the above corrects the problem replace the ignition switch
May 02, 2011 | Mustang Rzt 50" Zero Turn Riding Lawn...
Garden Logo
399 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
