Question about Konica Minolta Office Equipment & Supplies
Konica 4345 Error code F45-1 Comes up when turned on FRUSTRATING
This error code comes up imediately when turned on & you cannot operate machine at all. It seems to make a click noise from a relay/switch like an overide switch, I don't seem to be able to find anybody who knows about this error.Can somebody please give some adivise this is so frustrating as it dosn't always happen only every so often & when it does you can't get past it. GRRRRR!
    President:
  • Konica Minolta Master
  • 990 Answers
Hello sir; The error code you display, it's exposure lens not go back home possition, my suggestion; remove the glass turn off power, manually move the lens unit for and back find is somethings block over there or check the home possiton senser.
Posted on Oct 02, 2009
Konica 7145 error code F34-2
do this once code comes back replace the fuser continue reset couls cause fire ruining a perfectly good day
To reset failure codes, perform the following:
1. Enter the 25 mode (turn the machine ON, while pressing the 2 and 5 keys).
2. Select [1. software SW settings].
3. Using the arrows on the left of the touchscreen scroll to DIP SW 3.
4. Using the middle arrows scroll to BIT 1.
5. On the touchscreen select OFF (0).
6. Power the copier OFF/ON.
Dec 30, 2013 | Konica Minolta Office Equipment & Supplies
Minolta c550 error code C-D403
sir, mam
Controller error could be a bad main board, have tech come out try to reflash the firmware (copier operating system) not driver
Dec 04, 2013 | Konica Minolta Magicolor Office Equipment...
An error on my c360 konica minolta c-3721
fuser temp too high to reset turn off machine then turn on while holding down the utility/counter button when the trouble reset button comes up on the touch screen touch it and make sure it says ok then turn the machine off wait 10 seconds and turn back on if error code comes back fuser unit will have to be replaced
Dec 11, 2012 | Konica Minolta Bizhub c203 Copier
Error code sc 49-04 for konica 1050 copier
Aug 27, 2012 | Office Equipment & Supplies
Error code c-c 152
I think your problem comes from the scanner, try the operation if you have anotherPWB-C when you turn on the machine.
5/16/79 CC151: Error upon startup ROM contents (MSC)
5/16/80 CC152: Error upon startup ROM contents (Scanner)
5/16/81 CC153: Error upon startup ROM contents (PRT)
5/16/82 CC154: Error upon startup ROM contents (PH)
1 Check the ROM version. -
2 Rewrite the firmware. -
3 Replace the Appropriate board.
Apr 25, 2012 | Konica Minolta bizhub 250 All-In-One Laser...
Konica Copier says malfunction detected code C-0096
this is the error code for the image transfer belt pressure retraction failure to reset error code with the machine turned on open and close the front door if error comes back will have to replace either the transfer belt or the belt pressure motor
Oct 26, 2011 | Konica Minolta bizhub 350 All-In-One Laser...
KONICA MINOLTA C253 COLOUR MACHINE ERROR CODE C-D403 touch screen not working printout not coming our service engineer could not find the error
The c-d403 code indicates a checksum error. Try turning the copier off and on via the Main power switch either behind the copier or inside the front door of the copier. Checksum error along with no operation panel means something could be fried on the main board.
Feb 17, 2011 | Konica Minolta bizhub C250 All-In-One...
Bizhub 600 - error code 47-07 mean?
C 4704 is a Laser error code. I would turn off the machine by the main switch located in the front door. Unplug the machine for 10-15 seconds then reconnect and turn on. If the code comes back you may need to call a service technician
Apr 22, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Error code c0070
Power off the machine and gentlly take out the toner bottle. Then with the bottle out turn on the machine let the machine go thur its normal routine when the indicator comes on for toner install toner bottle. If the code comes back you have a problem with the Toner Bottle motor, gear, or Main Board.
Apr 17, 2010 | Konica Minolta DiALTA Di183F Copier
140 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
