Question about SanDisk Sansa E280 MP3 Player
Key locked mode is on - SanDisk Sansa E280 MP3 Player
  • 313 Answers
To unlock it Press and Hold the Home button until an “Unlocked” Message appears. also Press and hold the home button to lock the unit, this can only be preformed when the unit is powered. good luck.
Posted on Oct 01, 2009
How do you reset the alarm system on a 98 olds silhouette after it triggers without the remote entry
Theft Deterrent Arm/Disarm Modes
Important: Although mode 2 provides increased security, the content theft deterrent system disarms only by pressing unlock on the keyless entry transmitter. This can pose a problem if the keyless entry transmitter is damaged, lost, or inoperative for any reason while you attempt to disarm the content theft deterrent system.
Mode 1: The system arms when you lock the doors with the keyless entry transmitter. The system disarms when you unlock the left front, right front, or liftgate door with the key or the keyless entry transmitter. The system does not arm when you lock the doors with a power door lock switch.
Mode 2: The system arms when you lock the doors with the keyless entry transmitter. The system disarms when you unlock the doors with the keyless entry transmitter. The system does not disarm when you unlock the doors with the key.
Mode 3: The system arms when you lock the doors using a power door lock switch or the keyless entry transmitter. The system disarms when you unlock the left front, right front, or liftgate door with the key or the keyless entry transmitter.
Changing the Feature Customization Modes
  1. Turn off the IP dimmer switch.
  2. Turn the ignition switch to the LOCK position.
  3. Remove the BCM PRGRM fuse.
  4. Turn the ignition switch to the ACC position. The BCM flashes the fasten belts indicator and sounds the chime 4 times, which indicates that BCM type 4 is installed on the vehicle. At this point, the BCM has entered the feature customization mode.
  5. In order to change the theft deterrent/shock sensor mode, turn the headlamp switch from OFF to PARK and back to OFF.
  6. The BCM flashes the fasten belts indicator and sounds the chime a number of times equivalent to the theft deterrent/shock sensor mode. A transition past mode 4 repeats the sequence starting with mode 1.
  7. Complete the following steps in order to change the theft deterrent arm/disarm mode:
6.1.
Insert the key in the left front, right front, or liftgate door lock cylinder.
6.2.
Rotate the key from the center to the unlock position.
6.3.
Press the horn button on the remote keyless entry transmitter.
6.4.
Count the number of chimes that you hear. The number of chimes tells you which mode you have set.
6.5.
Press the horn button again in order to change the mode. Continue to press the button until you hear the number of chimes that indicates the mode that you want.
6.6.
Turn the key back to the center position and remove the key from the door key cylinder.
In order to exit and save the current feature customization modes use the following procedure:
  1. Turn the ignition switch to the LOCK position.
  2. Reinstall the BCM PRGRM fuse.
If you are unable to change locking modes Theft Deterrent System Feature Customization Inoperative
Aug 25, 2015 | Cars & Trucks
How do you use the number lock on keyboard?
Number lock is used to toggle the ten-key numeric keys on the keyboard from number-only mode to command mode. The default mode is for the keys to behave as commands (Home, End, Delete, etc.) and selecting the number lock toggles them to number-only mode.
Nov 02, 2014 | Computers & Internet
I have a Onity Advance lock and the green light is flashing at a very rapid rate. The lock stays in the open position all the time and never goes to the secured position. So you can just press the handle...
I am going to guess that this lock is a common door.
The flashing green and staying unlocked indicates that this lock is in "Office Mode"
If a master key has office mode capability, and the lock program has office mode capability, the lock can be permantly unlocked by "double dipping the key". It can be put back in to regular mode by "double dipping the key" again. This will only work if the master has the "office mode" capability.
Thanks,
Ken Croston
407 814 4974
www.ElectronicLocksmith.com
Jul 13, 2011 | Locks & Locksmithing
I used csorb's instructions to reprogram a master key for my 2000 Lexus RX300. The ignition works perfectly, but the doors don't lock or unlock.
Hi!!
I believe your alarm is in the PASSIVE MODE, here is how it works.
PASSIVE MODE Setting (Arming) Anti-Theft System The system will automatically set 30 seconds after following methods are performed: Remove ignition key from ignition switch. Exit vehicle, and close all doors. After performing this, anti-theft indicator on left side of instrument panel will light continuously for about 30 seconds. After 30 seconds, anti-theft indicator will blink once per second. When system is set, doors cannot be locked or unlocked using door lock control switch.
CANCELING THE ALARM AND REPROGRAMING MAY SOLVE YOUR PROBLEM.
Canceling Anti-Theft System Setting (No Alarm) When system is set (armed), but alarm is not sounding, use one of following methods to cancel system setting:
  • Unlock left or right front door using key.
  • Unlock all doors using remote keyless entry system.
  • Insert key in ignition switch and turn to ON position (this is operative only when anti-theft system has not been triggered).
HERE IS HOW TO REPROGRAM THE ALARM IN CASE YOU NEED TO RESET IT.
PROGRAMMING
PASSIVE MODE NOTE:Initial mode is passive mode off. If there is a different signal in middle of programming, signal is invalid.
Programming Passive Mode Off
  • Remove ignition key from ignition key cylinder. Ensure all doors (including back door) and engine hood are closed and unlocked. Perform all of following methods within 30 seconds:
  • Lock or unlock any door with key or remote keyless entry system.
  • Open driver door.
  • Lock and unlock driver door lock knob 3 times.
  • After performing this, system should start force lock after 2 seconds. Perform all of following methods within 20 seconds:
  • Unlock driver door lock knob.
  • Close and open driver door 2 times.
  • Lock and unlock driver door lock knob.
  • After performing this, system should start force lock after 2 seconds. Passive mode should now be off.
Programming Passive Mode On
  • Remove ignition key from key cylinder. Ensure all doors, engine hood and luggage compartment door are closed and unlocked. Perform all of following methods within 30 seconds:
  • Open driver door.
  • Close and open driver door 4 times.
  • After performing this, system should start force lock after 2 seconds. Passive mode should now be on.
If you need further assistance, please provide an email address to send more info on your security system
Good Luck!! A 4 THUMBS UP rating would be greatly appreciated for this solution. Thank you for using FixYa!!
Mar 01, 2011 | Lexus RX 300 Cars & Trucks
How to reset keyless entry remote on 2000 toyota celica.
Begin with:
The driver's door open and unlocked.
Key out of the ignition.
1.Insert and remove the key from the ignition switch 2 times within 5 seconds.
Steps 2 and 3 should be performed within 40 seconds.
2.Close and open driver's door TWICE.
3.Insert the key into the ignition and remove it.
Steps 4 - 6 should be performed within 40 seconds.
4.Close and open the driver's door twice.
5.Close the door.
6.Insert the key into the ignition.
7.Turn the ignition switch from "Lock" to "On" and back to "Lock" at about 1 second intervals to select the desired mode:
1 time for ADD mode.
2 times for REWRITE mode.
3 times for CONFIRMATION mode.
5 times for PROHIBITION mode.
8.Remove the key from the ignition.
9.To confirm your mode selection, the power locks will now cycle "lock" to "unlock" a number of times corresponding to your key cycles in step 7.
If Confirmation or Prohibition modes have been selected, opening the door will complete the procedure.
10.For Add or Rewrite modes do the following within 40 seconds of Door Lock confirmation:
A.Press both transmitter Lock and Unlock buttons simultaneously between 1 and 1.5 seconds and release.
B.Within 3 seconds of step A press the transmitter Lock button for more than 1 second and release.
^If the transmitter has been successfully programmed, the power locks will cycle "lock" to "unlock" once at this time.
^If there are problems with the transmitter or the procedure up to this point, the locks will cycle twice. If this occurs, verify that you have received the correct transmitter, and then repeat the above procedure.
C.If multiple remotes are to be reprogrammed, repeat steps A and B.
11.Open the driver's door to conclude programming mode.
Sep 03, 2010 | Toyota Celica Cars & Trucks
How do I reactivate the wireless remote control transmitter for a 2004 Toyota Camry XLE? I replaced the battery and the transmitter still does not work.
To Program Wireless Remote Transmitters:
Begin with:
5.Insert the key into the ignition.
6.Close the door.
Sep 02, 2010 | 2004 Toyota Camry
How do you change the keyless entry code
You need to key in the original key code, then within 5 seconds press 1/2 button. Key in your new code, then the door locks should cycle to indicate the code has been saved.
Aug 12, 2010 | 2002 Ford Explorer
How do I reprogram the 2004 Pontiac Vibe key fob?
To begin programming, follow the procedure.
  1. Set the following conditions: • Ignition off and ignition key out of cylinder. • All doors closed except drivers door. • Drivers door is unlocked.
  2. Insert and remove the key from the ignition switch twice within 5 seconds.
  3. After the above operations, close and open the driver door twice within 40 seconds. Then insert the key into the ignition key cylinder and remove it.
  4. After the above operations, close and open the driver door twice within 40 seconds. Then insert the key into the ignition key cylinder and close the door.
  5. Turn the ignition switch from LOCK to ON and back to LOCK at approximately 1 second interval 1to5 times to select desired mode. • 1 time for add mode • 2 times for rewrite mode • 3 times for confirmation mode • 5 times for prohibition mode
  6. Remove the ignition key from the key cylinder.
  7. After selecting a mode, the integration relay automatically performs the power door LOCK to UNLOCK operation within 3 seconds to inform the selected mode. • In the confirmation mode, when the operation is performed twice, it directs that 2 types of recognition codes have been registered. • In the confirmation mode, if the number of the registration code is 0 the LOCK to UNLOCK operation is automatically performed 5 times. • If the prohibition mode or confirmation mode is selected, registration procedure is completed. • If the add or rewrite mode has been selected, the doors will lock-unlock once or twice at 1 second intervals, once for add mode or twice for rewrite mode. • If the confirmation mode is selected, the doors will lock-unlock 0 to 2 times at 2 second intervals to inform the technician of the number of transmitters programmed. • If the prohibition mode is selected, the doors will lock-unlock 0 to 5 times at 1 second intervals.
  8. Registering new recognition codes for the add mode or rewrite mode. • Within 40 seconds after the add mode or the rewrite mode has been selected, press the LOCK and UNLOCK buttons on the transmitter simultaneously for 1.0 to 1.5 seconds. Within 3 seconds after the previous operation, press either one of the buttons for more than 1.0 seconds. • Within 3 seconds after the transmitter has been turned off, the LOCK and UNLOCK operation will be automatically performed once if the registration of the recognition code of the transmitter is completed correctly. In case the LOCK and UNLOCK operation is performed twice, the registration of recognition code has failed. Perform the registration procedure from the beginning once again.
  9. Press a transmitter button for 2 seconds. The doors will lock-unlock once at a 1 second interval to inform the technician that the signal has been received from the transmitter. • If the doors lock-unlock once, the transmitter programming has been completed. Go to step 8 to continue programming for additional transmitters. • If the doors lock-unlock twice, the transmitter programming is not complete. Go to step 8 to begin the transmitter programming again.
If any of the following conditions occur during programming, the remote control door lock receiver will return to normal operation:
Jun 11, 2009 | 2003 Pontiac Vibe
My Logitech EX110 wireless keyboard has no light indicators for CAPS LOCK and NUM LOCK. Should it have those indicators?
Your EX 110 receiver has 3 indicator lights (LEDs) that display the status of the Caps lock, Function key, and the Num lock during normal operating mode. These lights will also flash when the connect button on the receiver is pressed.
LED A: Indicates that the Caps Lock (Capital lock) key is on when lit.
LED F: Indicates that the F keys are in Standard F Keys Mode when lit and in Enhanced F Keys Mode when the LED is off.
  • Your EX 110 keyboard has an Enhanced F Keys Mode for F keys that provides additional functions you can program. See Knowledge Base article 9526.
LED 1: Indicates when the Num Lock (Number lock) key is on. This function allows the number pad to produce only numbers
Mar 27, 2009 | Logitech EX110 SP CORDLESS Keyboard/Mouse
Cap Lock on or off
Feb 11, 2009 | Logitech Cordless Desktop EX110
SanDisk Sansa E280 MP3 Player Logo
71 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
