Question about Bose Lifestyle 12 System
Haow do we take apart the woofer lifestyle 12
I have no sound from the center speaker. The speaker is good i think its the plug in the back of the subwoofer. How can i chek that and take apart the woofer on a lifestyle 12
  • 3 Answers
There is a gap all the way round the rear of the sub woofer between the plastic rear cover and the main body. The top gap in the center you will see what looks like a cog wheel, use a flat head screw driver to turn this untill a flat section sticks up. Make sure it sticks out all the way. Undo the 2 screws on the bottom of the unit just above where all the cables plug in. Slide the rear cover donwards and lift away.
Posted on Nov 09, 2009
  • Vret Nov 09, 2009
    Sorry forgot to tell you to pull the Treble and Base nobs off before you push down on the rear cover !
  • markecouture
    markecouture Nov 13, 2012
    I cannot find the two screws
SPEAKERS WORK, WOOFER DOES NOT
as far as i know these speakers contain the and everything else in the subwoofer. The good news is that the system itself works, as the speakers produce sounds. If you feel like taking the system apart yourself , you may check for some wires that got de-attached from the subwoofer, if not, i would advise you to take the system to check it by technical support.
Jan 18, 2014 | Boston Acoustics BA745 Computer Speakers
We have a Bose Lifestyle model 5 music center and it won't go into surround sound mode. It will play a CD and all 5 speakers work. Any suggestions??
Are you sure the red and white wires plugged into the audio output on your TV because I had the same problem and learned thats where you plug them into
Nov 06, 2012 | Bose Lifestyle Model 5 Music Center
Bose Lifestyle 12 system control unplugged and plugged back in
it could be a bad wire or circuit boaed for the speakers sound but seeing i'm not looking at the item in question it's really hard to say what it could possibly be
Jun 22, 2009 | Bose Lifestyle 12 System
No Sound from the speakers
sounds like the amp went , you will need to call bose
Dec 09, 2008 | Bose Lifestyle 12 System
Humming sound
I think it's time for you to upgrade to a new system. If not, try to see if you can get someone that's great with fixing electronics to repair it or return it to the manufacturer for a replacement.
May 15, 2017 | Bose Lifestyle 12 System
BOSE Lifestyle 48 Calibration Issue
try unpluging everything apart from the headset in the aux input (make sure you plug in to the white and red NOT BLACK) Sub woofer and power cord. Also make sure the power is on the the sub woofer. rx7pat
Apr 06, 2008 | Bose Lifestyle 48 System
Infinity 3.5c , 2 powered Woofer 5.25" suddenly no sound.,
The woofers on my 3.5c stopped working, but with mine the light was off. I unplugged it and left it for about 24 hours and then plugged it back in and it worked. No idea why. It's happened twice and each time takes at least 12 hours or a day or so before it'll work again, just unplugging it for an hour won't do it.
It seems like both times the problem started when the speaker got unplugged without it being shutoff first, but I can't confirm.
But if your light is still on it's probably a different problem. With my 4.1t towers when the light was on but there was still no sound it equated to numerous fried amp components which cost about $150 for repair.
Oct 31, 2007 | Infinity Intermezzo 3.5C Center Speaker
Lifestyle 12 by Bose
No sound ? Make sure the audio input cable is connected to the music center FIXED outputs, the black connector is fully seated in the music center SYSTEM CONTROL 1 jack, and the multi-pin connector is firmly seated in the Acoustimass module jack. ? Turn the music center off for ten seconds, then on again, to reestablish communication between the music center and the speakers. ? Check the connections for any external components. Make sure to select the correct source for the desired input. ? Check the speaker connections. ? Be sure the CD is placed correctly, label-side up, in the music center, and the cover is closed. ? Increase the volume. ? Check to see if MUTE is lit in the display. Press the MUTE button on the remote to unmute the sound. ? Disconnect any headphones. ? Connect the FM and AM antennas , and last but not least. Make sure there is power going to the remote speakers or the unit will not communicate with them. Good Luck
Jun 14, 2006 | Bose Lifestyle 12 System
Bose Lifestyle 12 System Logo
678 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
