Question about Ardisam 5.5 Hp Rear Tine Rototiller
How do the belts go on my rototiller, are they twisted or what
  • 472 Answers
THAY SHOULD RUN UP AND DOWEN AND NOT TWISTED
Posted on Oct 02, 2009
I have a 1969 Cub Cadet 127 with a rototiller, and it loses power and stops spinning each time I lower the rototiller in the garden. I cleaned the rototiller and belts look good. Help!
You may have wear on the pressure plate and sometimes you can adjust the turnbuckle on the clutch rod and that will take care of the problem. If that doesn't help you may need to replace the pressure plate. Cub Cadet part # IH-473471-R1.... Hope this will help you.
May 23, 2017 | Cub Cadet Garden
My Earthquake Rear Tine Gas Rototiller - 196cc Viper Engine 4-cycle just makes a squeeling noise and tines won't rotate.
Sounds like the belt is slipping. Have you removed the belt cover and inspected the belt and the tensioner pulley ? If your model is like mine the tension can be adjusted just below the handles by looseneing the nut where the cable goes into the cable sheath and moving the cable cover further away from the handle. That takes up some slack and will make the tensioner pulley tighter on the belt. If the belt is shot tension isn't going to help.
Try "google" with "earthquake 5070 manual" first option should be a PDF copy of a model 5070 manual. Will have diagrams on how to adjust the cables.
May 08, 2014 | Earthquake 6015V Rear Tine Rototiller
Earthquake rototiller won't disengage
the tensioner is to tight and belt stays engaged loosen the tension below the handle
Apr 04, 2014 | Earthquake 6015V Rear Tine Rototiller
I have a very old Wizard (Western Auto) Front Tine Rototiller Model gis 6990 A27 with power reverse. I am looking for a manual or a diagram of the drive belt routing. (Patent #2903077). Any assistance...
Hi and welcome to FixYa, I am Kelly
Here is a picture of the belts installed.
http://photos.cubfest.com/albums/userpics/10231/Belt_Routing.jpg
NOTE the front fwd direction drive belt / closest to the motor is installed like any other belt. The rear belt for REVERSE direction has 1/2 twist. The idler pulley presses in for foward driving and pulls out against the reverse drive belt.
This should be what you need.
Thanks for choosing FixYa,
Kelly
Jun 20, 2011 | Garden
We require help with a broken belt on the rototiller
bring the broken belt to napa auto parts or kragen ,,or go to www.managemyhome.com they can tell you where to buy or get it
May 20, 2009 | Garden
Craftsman rototiller 3 5 model 917 299130 leaks
Sounds like you are speaking of the float bowl.
It should not have a hole in it.
You could purchase the part from Sears or a small engine shop.
If it were mine, I'd remove the bowl, clean it, and patch with a gasoline impervious material such as JB weld.
Apr 05, 2009 | Craftsman Garden
Looking for owners manual
I have a manual for the Wizard 5HP tiller. The reverse belt basically makes a figure 8
The belt goes over the motor pulley and over the idler pulley then makes a twist in the middle and around the bottom pulley. This cause it to basically rotate the opposite direction from the rotation of the drive pulley
Apr 05, 2009 | Garden
Ardisam 5.5 Hp Rear Tine Rototiller Logo
219 people viewed this question
Top Ardisam Garden Experts
Jay Finke
Jay Finke
lnbn1975
Wade Mobley
Wade Mobley
Are you an Ardisam Garden Expert? Answer questions, earn points and help others
