Question about Canon PowerShot SD1200 IS / Digital IXUS 95 IS Digital Camera
Locked card Camera sees SD card as locked when it is not locked.
  • Canon Master
  • 4,738 Answers
Remove the SD card from the camera. Slide the tiny switch on the side of the card to its other "unlocked" position. Reinsert the card in the camera. But if you've already tried this, see this link for additional things that you can try.
Posted on Oct 02, 2009
My VPC-E760 keeps saying card is locked but the sd card is not locked
For the card locked, make sure that you are using a 2GB or smaller card. The E760 can not use 4GB or larger SDHC cards. 2GB cards can still be purchased on Amazon if your local store no longer carries them. If you are using 2GB, then here are some more tips for card locked.
For the "lens error", see this article for tips and steps that might help you repair it.
Apr 11, 2012 | Sanyo VPC-E760 Digital Camera
Screen says 'card locked' but the card is not locked
Step 1 - Check to see if SD memory card or SDHC memory card's write protect tab is set to "Lock" -
Unlock the write protect tab.
Step 2 - Try another SD memory card or SDHC memory card to see if the problem also occurs. If not, the memory card is faulty, if the problems doesn't go away, the camera is broken.
Mar 15, 2011 | Canon PowerShot D10 Digital Camera
Even though the sd memory card is "not" in the locked position, it still says card locked when I turn my camera on. I have a Canon Powershot sd 780
Hello(Read the whole solution, i think you have the second scenario)
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Nov 27, 2010 | Canon PowerShot A530 Digital Camera
My ixus 8515 says "card locked". The card has been broken, but a new one, wich is not locked, is placed in the camera. The display still says "card locked". What can I do?
Hello
Kind regards
Andrea
Aug 31, 2010 | Canon IXUS i7 Digital Camera
When I take a pic it says card locked...
Hello
If the card works in another camera or another card doesn't work in your camera , the problem is with your card reader in your camera.
Kind regards
Andrea
May 16, 2010 | Polaroid i737 Digital Camera
Memory cards are locked but the card is not locked
It's unusual that an A95 would report "card locked" as it uses a compact flash card which is incapable of being locked. Please verify the model of your camera, and the card that it uses.
In the mean time, I'll assume that actually own a different camera that uses SD cards. If so, please see this link for troubleshooting tips for SD card locked problems.
But if you indeed own an A95 with compact flash, the problem may possibly be caused by bent flash card pins inside the camera card slot (take a look inside using a flashlight). If bent pins are found, then see this link for a possible home fix.
Apr 15, 2010 | Canon PowerShot A95 Digital Camera
SD card locked
The lock switch on the SD card looks like a bit of plastic without any electronics. A bit like the write-protect tab on a 3.5" FDD.
So there must be a sensor in the reader / camera which detects the position of the switch. Maybe there is dirt in the sensor. The best way to check would be to try another SD card, but you could try blowing out any possible dirt and see if that fixes the problem. Can the camera write to the SD card?
Try moving the switch to lock and unlock status.
Apr 07, 2010 | Canon PowerShot A75 Digital Camera
SD card locked for Samsung SL202
This used to happen occassionaly with my canon camers. Just use a peice of scotch tape or if you have one a small dab of hot glue to stop it from sliding.
Hope this helps FixYa,
Chris
Sep 03, 2009 | Canon PowerShot A560 Digital Camera
Camera says SD Card is locked but card is open;
First I know you've said you've checked the card's slide switch, but just want to restate this first for others with the same problem who may not know of this switch.
Check to make sure that you didn't accidentally place the tiny locking slide switch on the side of your SD card in the "locked" downward position. The correct "unlocked" position should be slid up toward the direction of the connectors.
If you've tried this, and it's still showing locked, it's likely that the locking switch inside the camera's card slot is stuck. If you look inside the slot on the side of the slot where the SD card slide switch would be, you'll see a glint of gold color on the side. This is the camera's lock/unlock switch. The other glint's of gold that you may see at the far end of the slot are the reader's connectors (ignore those).
Somehow, the locking switch is making contact and has become stuck in the locked position. With a plastic toothpick, or other skinny NON-METALLIC item, tap against this switch to see if you can jar open the contact to its normal unlocked position. Also try blowing compressed air at it, as some gunk may have worked its way in there, jamming it closed. Occasionally, reinsert the SD card to see if the issue has been corrected.
If repeated tries fail, it may be time to consider opening the camera to force open this switch (not recommended unless you have some familiarity with electronics). In this case please see the following (xscrewdriver, hope you don't mind me referencing your blog):
http://www.myfixtips.com/blog/digital-camera/how-to-fix-a-%e2%80%98card-locked%e2%80%99-problem-125.htm
Jun 16, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Canon PowerShot SD1200 IS / Digital IXUS 95 IS Digital Camera Logo
91 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
