Question about HP EliteBook 6930p Notebook PC
I accidently remapped my keyboard or mouse. How
I accidently remapped my keyboard or mouse. How can I reset it?
  • HP Master
  • 5,568 Answers
Go to the Start menu and select Control Panel. Open the Keyboard folder and check the settings selected.
Posted on Oct 01, 2009
German keyboard layout problem
The uses for mapping your keyboard are numerous, but remapping your keyboard's keys is not for the squeamish.
There are numerous software applications to map and remap a keyboard's keys.
The best part is that the software is free and easily downloadable via the Internet.
So, go ahead and swap those unused keys on your keyboard to suit your computing experience, and make your keyboard more effective without fear of damaging your computer
Place your mouse pointer over a key on the visual keyboard. Notice that the key is numbered.
To see what function the key is currently assigned to, allow your mouse pointer to hover over the key.
A pop-up displays what the key is attributed to.
Left-click the mouse pointer on a key you wish to change.
Click on Choose New Remapping from the drop-down menu.
Select Remap Key from the Control area on the interface.
You may also opt to disable or enable the key, and reset the default for this key.
Left-click Apply. Look at the list box at the top-left of the interface, labeled "Remapped keys currently in effect."
Ensure that the keyor keys you selected are listed in this list box.
Fix a mistake by resetting the defaults.
Click on the top button adjacent to the list box you just visited.
Pressing this button will remove all the changes to your keyboard mapping.
SharpKeys is a Registry hack that is used to make certain keys on a keyboard act like other keys.
http://www.randyrants.com/2008/12/sharpkeys_30.html
Jun 29, 2013 | Acer TravelMate 2500 Notebook
USB Mouse works, keyboard does not
You will need to update the drivers on the computer for the docking station. It will be the windows seven drivers or lack of them that is causing a failure to remap the usb ports that the wireless dongle is plugged into.
May 25, 2017 | IOGear GCS632U 2-port KVM Switch
Is it possible to use any alternate key for my damaged enter key
the only option apart from replacing the keyboard (which is easy but usually fairly expensive) would be to use the on screen keyboard which you control using the mouse.
you activate the on screen keyboard through Programs->accessories->ease of access and select on screen keyboard
Hope this helps
May 06, 2011 | Computers & Internet
Left click button wont work
Hi, it is either a:
1., software problem (check control panel => mouse for options)
2., hardware issue, listen to the sound of it clicking, if it sounds different from (for eg. weaker) than the right click than it is a faulty switch
You may try taking apart and replacing the switch if you another mouse lying around.
But if are not experienced with soldering, just remap the left click in control panel (replace left click with right click and right click with middle button) or get a cutom mouse utility to do the same.
This way you can use it while you get a new one.
Mar 03, 2011 | GE 97985 Mouse
I have a Logitech keyboard+mouse wireless combo MK250. Since Day 1 I can't type few special character. For example the inverted coma" and at the rate symbol@ are interchanged i.e I have to press shift+2 to...
Look for a KeyMapper program on your system. It sounds as if some keys have been remapped on your system. If that's the case, any keyboard will exhibit the same symptoms and, of course, they work fine on other systems with no remapped keys.
May 27, 2017 | Computers & Internet
The spacebar brings up help info
you need to remap your keyboard. ask Windows help for complete instructions.
Oct 27, 2009 | Microsoft Natural Ergonomic Desktop 7000...
I accidently took out the usb for my microsoft mouse msk-1056 and it worked for a while but then stopped. How do i get it to work again?
also reset the pmu..it will solved or the issue about energy ..or maybe you must donwload the drivers again,also try in another user ..make a text account...
Aug 14, 2009 | Microsoft Wireless Notebook Optical Mouse...
Logitech keyboard
Click start and go to the control panel then click on the hardware and sound link find your mouse from there and click settings and within those settings you should see sensitivity and click speed.
change them to your likeing.
Dec 14, 2008 | Compaq Keyboard
Keyboard and mouse won't work after start up
Pls check that the press button on the top of touchpad, most probably its disabled by being accidently pressed.
Dec 11, 2008 | Dell Inspiron 1521 Notebook
HP EliteBook 6930p Notebook PC Logo
193 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
