Question about Jenn-Air JSD2789GES Side by Side Refrigerator
The refrigerator goes from -76 degrees to +27 degrees and then back again. will not go to 37 degrees
  • marc244 Oct 01, 2009
    i'll check it out
    thanks,
  • 11,896 Answers
Sounds like your temperature control unit or sensor is bad. You can test continuity with a tester and also test temp sensor with a glass of water and a continuity tester to see if it changes properly.
Posted on Oct 01, 2009
Refrigerator
The self defrost mechanism is not working. The evaporator is getting blocked with ice, an insulator, and that affects freezer as well as refrig temps. When you unplug unit the ice melts and it will work till the ice block returns.
Sep 07, 2016 | Refrigerators
Please tell me the restriction code for nokia 3220 RH-37 imei no is 359396/00/988474/20518259
OK, here is what you do. You incert the T-moblie card into the phone, and enter the code. To enter the letters, sipmly press the *(star) key until you get the desired letter, and when you press #(pound) it should show a message saying "phone unlocked" or some message of that sort. If it says incorrect code, try the next code, If it doesn't unlock, incert the other SIM card and try it again. Here are the codes.
DCT4 Codes for IMEI: 355006007080235
Provider: 31020000
U.S.A., T-Mobile U.S.A
Type: 2
#pw+ 75 23 30 27 30 75 03 3 +1#
#pw+ 88 43 31 30 62 15 53 2 +2#
#pw+ 03 65 33 45 64 37 73 3 +3#
#pw+ 74 80 40 06 46 02 44 3 +4#
#pw+ 48 84 57 60 36 76 15 0 +5#
#pw+ 73 80 40 35 76 12 04 7 +6#
#pw+ 85 49 41 27 12 71 34 5 +7#
May 18, 2011 | Nokia 3220
How can lower my refrigerator temperature to 37?
You need to unplug your unit for 24hrs. You need to clean out the fins with air compressor and vacuum. This has worked wonders for my 550.
Jan 04, 2010 | Sub-Zero Bottom Freezer Refrigerator
Fridge off all night, how long for temp to go down from 76
will take a while at 76 also check fan in freezer section make sure not iced up and is working correctly the moisture from the warm air can cause the fan to ice up causing more problems
Nov 19, 2009 | Sub-Zero Refrigerators
New gallery series frigidaire side by side. 'fridge temp set at 37 degrees, but temp drops to 30 degrees. Everytime I reset to 37 degrees, it eventually goes back down to 30
If it is new (under one year old) then it is under factory warranty, and is not your problem.
Contact your selling dealer and request a service call. There should be no charges to you. Please post back if we are not on the same page as to the age of the machine. Jack
Nov 01, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Whats the correct temperature the fridge should be set at? our milk goes off very quickly and nothing chills.
A refrigerator should be set for a temperature of 37 to 39 degrees F. Refrigerator controls are not usually marked in degrees but have indications for "warmer-cooler". Set the control toward the cooler side and check the temperature. Place a reliable thermometer on a middle shelf to check the temperature. If the refrigerator is not able to maintain a temperature in the 37 to 39 range then the cooling system may need service.
Oct 21, 2009 | Refrigerators
Refrigerator does not maintain 37 degrees
i have seen this problem before its the control board in the back the board is about 150 dollars and it goes every DING DING 5 years lol horrible design of the one that comes on the fridge every ge side by side has this problem  its very easy to replace but have to "ground" yourself before you touch the new control board meaning rub you hands on plumbing pipes, not pvc or copper
good luck if you got questoins let me know
Jun 08, 2009 | GE PSS25NGM Side by Side Refrigerator
Jenn-Air JSD2789GES Side by Side Refrigerator Logo
27 people viewed this question
Top Jenn-Air Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
john h
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
