Question about Refrigerators
Can you put r408a in r404a compressor but the system is on r502 they used r408a as a drop in. is the oil in the system compatable
  • 31 Answers
R 404a compressors use ester oil, this oil can be used with old and new refrigerants.
R502 and R408a compressors used mineral oil, that oil cannot be circulated by new HFC refrigerants like R404a.
So if you know the oil is compatible and the refrigerants have very similar cooling characteristics ...I can't see y not.
Posted on Oct 02, 2009
When we turn on A.C or defrosters alternator makes noise and vibrates engine drops
are you sure it's the alternator and not the AC compressor?
makes more sense if it's the compressor putting excess load when you turn on the AC system
maybe add a small can of oil via low side port w/ that r134a adaptor to see if the compressor is low on oil; that can be bought at walmart or any auto parts store
but really has to be evacuated and checked if correct oil level inside the system, which costs $$$
Apr 15, 2015 | Ford Taurus Cars & Trucks
Is Refrigerant Gas R 404 A is a ozone depleting gas?
here ya go this is what the mighty google says
R404A is a blend of non-ozone depleting HFC refrigerants (R125, R143a and R134a). It has similar properties and characteristics to R502 and is used in both medium and low temperature applications. It is widely used for commercial refrigeration applications, including display cabinets, cold rooms and ice machines, as well as transport refrigeration and industrial refrigeration.
As R404A is a blend it should always be removed from the cylinder as a liquid when charging the system.
R404A is not compatible with mineral oil. Equipment manufacturers recommend Polyol Ester oil (POE) See oils section.
R404A can also be used to retrofit existing R502 & R408A systems, however, it will be necessary to carry out multiple POE oil changes.
Many users find that DuPontTM ISCEON® MO29 (R422D) or MO79 (R422A) are easier to use for retrofitting systems.
Aug 01, 2011 | Refrigerators
Why air compressor model: MH75 intercooler leaked with dirty oil? Please state also what is the causes, recommended and effect if not change anything.
With out more info I can only pass along what I typically see while in the field. Inner coolers experience a lot of high temps and varying pressures. After a while of expansion and contraction they sometimes fail. This is true for both rotary screw and piston type compressors. As for the dirty oil all oil lubricated compressors pass some oil. this oil plates out in the system. This plating / residue can be linked to the oil used. compressor oil is formulated so their is less carbon and residue built up while lets say oil for your car is formulated differently. I know from experience some auto type oils build carbon badly if used in a compressor. their are several causes but mainly poor maintenance ,this causes more wear and the compressor passes more oil. even small things like leaks that allow unfiltered air into the compressor will cause the oil to become contaminated thus the dirt in the oil plates out in the system as oil is passed and carries over. the dirty oil you see coming out from the leak is contamination that has plated out in the system. what damage is done is done. At this point in time my recommendation would be use a good compressor type oil, do good maintenance, change oil and filters at the specified schedule more often if in a dirty environment and repair/replace the inner cooler. Now if you want to go further you can disassemble and clean parts, coolers etc. You can also purchase cleaners for some compressor that will remove build up that has plated out in the system. However please be careful and make sure the cleaner is compatible with your compressor. If not it may damage seals ,gaskets, o rings etc. hope this helps you.
Jun 23, 2011 | Ingersoll Rand Air Tools & Compressors
Product NR83A2. Lubricate is coming from the trigger and exhaust cover. The nailer is new and I put lubricate in the gun prior to placing the air plug on. What is the best way to drain the excess...
Excess oil will eventually be consumed /blown out of gun, however if you store the gun over-nite with air inlet pointed down, gravity will assist. I find that oil /water will accumulate inside gun especially if compressor is passing oil and/or weather conditions cause system to produce lots of water. Majority of guns that come in for repair suffer from a lack of lubrication. Several drops at start of day should be ok for oil lubricated compressors and maybe more for oil-less. If oil drips out of gun overnight (if stored as stated above) then reduce drops. What actually shortens life of gun is debris that enters gun from handling and that enters hoses during transport. Before connecting air hose to gun (with hose under pressure) momentarily connect a spare quick connect fitting and blow debris out of hose.
Mar 16, 2011 | Hitachi 3 - 1/4" Framing Strip Nailer
Where do I oil it?
your gonna wanna oil thru the connection at the air line, 3-4 drops, also keep the front of nailer, where the driver goes thru, 4-5 times per day of use. with neaumatic oil, oil for air tools.and give the 3-4 drops before operation, and the 4-5, while in use.
Mar 13, 2011 | Craftsman Air Tools & Compressors
What should the iowside pressure be on freezer went the inside temp. is 0 degree?
Depends what freon you are using.......... For R12 6 to10 PSI
For R502 25 to 30 About the same for R404A
Feb 01, 2011 | Frigidaire Freezers
How do I oil a paslode nail gun
just put oiler somwhere in line between compressor and gun, this should be sufficient. another method is to put single drop of oil into air intake every hour or two - depending on workload, i use oiler. but sometime when this is not feasible, i just put drop or two of oil into air intake on the beginning of the job and maybe another one on midday.
Aug 04, 2010 | Tools & Hardware - Others
Refrigeration
Your pressure sound pretty good. I would check the thermostat and the relay on the compressor. If you are getting no frost on your coil, that is usually a tall-tall sign of a bad compressor then it would be better to just replace the unit.
Apr 22, 2009 | Frigidaire FRT21H8 Top Freezer...
Can not get temp. below +10 f
what is your superheat and is defrost cycle working
Jun 19, 2008 | McCall Freezer 7-7045FT
Refrigerators Logo
462 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
