Question about RCA DRC8030N
Won't turn on, just says "Hello" and will load no further
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 106 Answers
This is due to one of the IDE devices inside (Hard Drive or DVD drive) not sending the requires "I am Ready" signal to the main board while the DVR does a power on self test. With the hundreds of units I have come across, 99% of the time it is due to a faulty DVD drive. These "Loader" brand DVD drives were on the cheap and when they give out, the unit does not go past the Hello. You can verify this by replacing the the DVD drive with any other DVD burner or DVD drive or even a CD drive that comes from a computer (IDE connector). The only fix for this is to replace the drive or simply connect an old CD drive inside and not use the DVD properties of the DVR, only the hard disk recording/playback.
Posted on Oct 16, 2009
  • Gerson War
    Gerson War Oct 24, 2013
    I still have extra power boards and mother boards for this unit if interested. Send me a message
    Problem Solver:
  • 10 Answers
Sounds like a shortage inside
Posted on Oct 01, 2009
Gsan,
Need drc8030n parts HELP cjbr2k@yahoo.com
Posted on Nov 04, 2009
Zeki 10" tablet won't load
Hi, Is your Zeki fully charged? My suggestion is to hold the on/off button for a few secs. to fully power down. Put it on the charge and let it fully charge before trying it again. Then try turn it on again.
Feb 18, 2013 | Shopnbc Zeki 10" 8GB Android 4.0 Ice Cream...
Gas won't stop coming from oven
Hello suremoss - Once you have experienced a gas leak, I highly recommend turning the unit and the gas off if you can reach it. For safety and liability reasons we do not suggest that you troubleshoot this yourself any further and to contact a professional to move forward immediately
Dec 16, 2012 | Frigidaire Gallery 30" Self-Cleaning...
PIP wont turn off
I can assist you but I need to know the name and model of the TV you are asking about. The only information that I have here is that you have a projection screen TV. Please clarify and I will be able to assist you further.
Best regards,
EJ Kudelka
Mar 16, 2012 | Televison & Video
ERROR CODE NP AND NOW DOOR WON'T OPEN
Hello first try unplugging the machine for 7 minutes if this doesn't then allow you to open the door then you can manually release the door lock by taking off the dispenser assebly holder (bezel) and pulling on the door lock release cord you will find inside. Also as far as the nP I think the erro your seeing is ND which is no drain in which you can click this link
http://www.fixya.com/support/t340703-maytag_neptune_error_code_nd another tech has posted with pictures on this issue. IF you have any further questions message me back Thanks
Rick
Sep 25, 2011 | Maytag Neptune MAH5500B Front Load Washer
When turning on the unit it continuosly plays the hello message and won't go any further hope you can help
there is firmware on the main board of the lcd television. it seems that it is currupted & therefore not working properly. by opening the back cover u will see there is a board where audio/video & RF signals are going in. u need to replace that board.
Sep 03, 2011 | Televison & Video
Open-cloesh problems
Hello
Check its loading belt and loading motor. If loading belt get loose or loading motor has low pulling power [due to trouble with its carbon brushes inside it], this type of problem will occur. There is a gear wheel assembly inside it which draws in and pushes out the tray mechanism. If any of these wheels gets broken, the mechanism won't work properly, even if the loading motor and loading belt is right. If so, replace the loading mechanism. It won't cost more, and can be bought from most of the electronic spare part shops at your town. OK.
Aug 12, 2011 | Televison & Video
Is there an internal fuse on a Bosch WFL2450?
Welcome to FixYa.
As a freestanding unit, NO. It won`t have isolated fuses, However, if the unit is plugged into the dryer, then YES. It does through the dryer utility box.
If it is plugged into the dryer then you`ll need to look at the back of the dryer where it plugs into the dryer.
This is an example of what you need to look for...
If your washer is plugged in here, check the fuses inside the small box up in the corner, i.e.
**Please unplug the washer or dryer ( depending on the set-up I mentioned...freestanding or feed into dryer ) or turn off the breaker before servicing the unit any further...safety first**
Let me know if it is indeed plugged into the dryer and we can go from there.
I`ll watch for your reply.
Regards,
Macmarkus :)
Sep 12, 2010 | Bosch Classixx WFL 2462 Front Load Washer
Computer won`t start
Hello there my friend
There is a easy check, it sometimes MEMORY PROBLEMS, or VIDEO , check your RAMs, and take out one module, if has more than one, and restart the PC, I know you will write me back! :)
tell me!
Open Sky
Sep 19, 2008 | Everex GA3400 Refurbished AMD Desktop...
Broken belt, motor wont turn
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=721048
Generic problem for all Vacuums
Broken belt, motor won’t turn
Posted by msmclovin on Jun 29, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. If the motor shaft won’t turn then you may have a bad motor or a stick carbon brush, but if it is just the belt the replace the belt with a genuine belt because the average belt change id every 4 to 6 months for the best cleaning and to store the extra belts in a Ziploc bag in the refrigerator. But you question does not tell me what brand name and model # it is so I have a hard time to diagnose the problem for you so my explanation if just a generic one and should work for you but next time please note the brand name and model #. If you have further problems please feel free to contact your local vacuum cleaner dealer in your area or call the Kirby cust serv dept listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 29, 2008 | Vacuums
RCA DRC8030N Logo
1,427 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
