Question about Apple iMac G4 Desktop
Drive Tray Problems
I am having a problem with my drive tray. The problem being that it will not extend. I sounds like it wants to extend, but doesn't. Any advice would be wonderful.
  • pillgrim Dec 21, 2007
    It is a 1Ghz processor. I recently installed some RAM in the user accessible slot, but there was no disk in the drive. As far as a loose cable, I don't know. Is it possible a cable came loose when I installed the RAM? Is this a common problem?
    Novelist:
    Champion:
  • 382 Answers
Has this machine been transported of moved with a disc in the drive? Some models of the G4 flat panel imac, have a slot above the drive where a wireless card maybe installed. Is there a possible loose cable in the path? If you can power it down and Let me know the processor speed ( which is specified on the bottom of the machine -in Ghz or Mhz ) I can better help you.
Keep me posted.
Posted on Dec 21, 2007
  • Keith Seekwhensir
    Keith Seekwhensir Dec 21, 2007
    No, though i have seen the drives fail due to the machine being abled to properly calibrate the the laser. Was the drive working fine before the ram install? And so I can correct myself. The G4 flat panel Imac has the wireless slot across from the user installable ram slot. The emac, not the imac, has the wireless card slot above the drive bay door....so that eliminates that chance. About how far does it eject? And when you installed the memory in the computer, in what position was the machine at rest? When the tray is ejected to it fullest that it can, i would give a slight tug outward, it may be possible for the lubricant on the eject gears to have "stuck". This particular all in one model is very compact in its dome shape, but the optical drive is still very modular, so there is no way of any cables or what not to actually impede. Also try pulling down the white door fully, if the tension on that has changed, it may inhibit the tray from fully opening.
    Keep me posted.
Cd tray wont open
CD/DVD Drive Tray problems
There are two ways to open the CD/DVD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD/DVD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD/DVD disc.
If you still having problem opening with the Eject button, then the CD/DVD drive is faulty and needs replacing.
Apr 13, 2013 | HEWLETT-PACKARD Hp G62-225dx Laptop...
DX4300-150
Mar 12, 2013 | Computers & Internet
Dell cd drive door won't open
Feb 22, 2013 | Dell Studio XPS 8000 (DXCWKW12) PC Desktop
The cd door won't open on the tower
CD Drive Tray problems
There are two ways to open the CD drive door if the button just below the drive tray does not work.
If this does not work then you can manually open the CD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD disc.
If you still having problem opening with the Eject button, then the CD drive is faulty and needs replacing.
Feb 16, 2013 | ZT Group Cisnet PC Desktop
My dvd tray is not ejecting,i cannot insert a cd
Feb 05, 2013 | Computers & Internet
My acer x1700 cd drive wont open.. i can hear it attempt to open. i do not have an emergency bottom or push out hole. please help many thanks
If you continue having problem opening with the Eject button, then the CD drive is faulty and needs replacing.
Oct 23, 2012 | Acer Computers & Internet
I have a hp laptop cd stuck inside how do you get it out
There are two ways to open the CD drive door ifthe button just below the drive tray does not work.
Straighten a paper clip and gently insert it into a tiny hole below the drivetray next to the Eject button. Push the paper clip gently until the drive traypops out, then pull the tray until it is fully out, then you can remove the CDdisc.
If you continue having problem opening with the Eject button, then the CD driveis faulty and needs replacing.
May 29, 2012 | HP Computers & Internet
Toshiba DVD ROM SD-M1912 Tray Opens Intermittently or Partially
Yes... we do get attached to our toys.
Sounds like your tray slides (left and right) have some kind of contamination?
Best if you can remove the drive so you can CAREFULLY clean the tray rails and slides. Don't be tempted to lubricate with anything because the oils (etc) may serve to capture even more junk... a common Q-Tip should do the job.
Most drives have a tiny hole in front to extend the tray manually? If not, open the drive door and HOLD IT OPEN as you power-down for easier service.
INSPECT the tray 'gears' inside. IF they have a paste-type lubrication on the gears just break off one of the ends of the used Q-Tip and reapply the paste (usually) to the SAME GEARS it came from... DO NOT put the lubrication anywhere else!
Finally use common rubbing alcohol on a Q-Tip to clean the drive tiny belt.
Below is a YOUTUBE video that may help you!
Anthony
How to With Chad 360 Stuck Disc Tray Repair
Nov 30, 2008 | Toshiba SD M1712 Internal DVD Drive
New DVD read writer not functioning
sounds like the drive lock is not seating properly, (gearing mismatch)
The drive tray lock is a peg on a round gear which locks into a groove on the underside of the tray (you can see it on the underside on the tray,
at some point this gear has "slipped" and now does not meet this groove and closes before hitting this groove,   some manual manipulation of the drive tray can solve this but it is tricky
The easiest way is to "pop" the latch,  which allows you to remove the drive tray completely This "latch" is usually a sprung toungue of plastic which normally prevents the removal of the tray,  if this toungue is lifted the tray can continue on the gear train and can be completely removed, (the eject function will roll the gears forwards and backwards without the tray).
all you do then is to press eject (the mechanism gears will roll out) then you just insert the tray at the correct point (usually at full extend) to re-allign the tray lock (sometimes it takes a couple of attempts to get this right)
Oct 30, 2007 | Computers & Internet
Optical Drive does not opent
If you had a CD in it, the CD may have wedged itself such that the tray cannot be extended. If it was empty, you may have a gear that is no longer making contact with the tray. I would remove it from the computer and look at taking the cover off the drive to see if the tray's path is obstructed.
Sep 25, 2007 | Sony VAIO VGC-RA710G PC Desktop
Apple iMac G4 Desktop Logo
57 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
