Question about Cst - Berger 20X Speed Line Transit - Level Kit - 54 - 200K
Have a berger lld20 line detector and a lmhrotary
Have a berger lld20 line detector and a lmh rotary laser cst by berger. line detector does not function. The LD -400 does work. can you tell me if the lld -20 will work with this unit.
John Bains Bains5@verizon.net
I just put 3 new battery's in and leaser light will not come on.
Check for green corrosion on contacts and clean them A dab of WD40 on a Q tip will may help clean & improve the connection and provide extended protection.
Aug 25, 2013 | CST/Lasermark Self-Leveling Rotary Laser...
Which instruments does the the CST/berger DTEP diagonal eyepiece work with?
according to http://www.engineersupply.com The CST/berger DTEP diagonal eyepiece works with the following instruments:
  • CST/berger DGT-02 theodolite (56-DGT2)
  • CST/berger DGT-10 theodolite (56-DGT10)
  • David White DWT-10 theodolite (46-8890)
Apr 17, 2013 | Retail Supplies
I have a CST/berger Magna-Trak 202 magnetic locator that just stopped working.
Likely the on/off button is no longer at the right position to make contact with the tab. Take it apart, and you may need to glue a little piece of plastic to the button.
Feb 01, 2013 | Bosch CST Berger MagnaTrak 200 Series...
I need a manual. Power will not come on. Changed batteries. No power. Also, where does the red attachment that tells you to go up or down hook on? I have power to the unit which hooks to the pole.
Hi Richard.
The manual is available from this webpage.
http://www.cstberger.co.uk/uk/en/
Type lm30 into the text box which says "trade name/tool number" and click "start search"
Click on the thumbnail then to download the pdf.
Check for corrosion on the battery terminals and those in the laser.
From what I can see in the manual, there should be a clamp for the laser receiver that lets you clamp it to a staff.
The target plate (part 24 in the manual) has a reflective coating and there should be a magnetic holder for it.
Nov 24, 2011 | Cst /Berger 57 LM30 Manual Leveling Dual...
My laser turns levels tries to spin but wont. I am told its the motor. can l buy a motor ?
Please contact CST/Berger directly for warranty service or parts inquiries about that laser.
Their website is here. If you click on the self-support knowledge base link and type in warranty service you'll be able to access a list of options for repair of your unit.
(If you have a product(s) that needs to be returned for service, please contact the Customer Support department at 800-435-1859 or click on the LIVEPERSON icon right now to obtain a RMA number before shipping the product(s) back.)
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jan 06, 2011 | CST/Lasermark Self-Leveling Rotary Laser...
I need the mounting bracket that attaches to the story rod. the model of receiver is rt-a1655
check with bosch or cst/berger. robotoolz is now owned by bosch and they have eliminated most of the robotoolz product line
Jun 17, 2010 | Robotoolz RT-5250-2XPK ePlane XP High...
Green light turns on momentarily, then nothing from unit
make sure batteries are tight in unit ,making good connection there are many internal things that could be wrong no rotation could be bad drive motor broken belt bad pcb robotoolz now owned by bosch who owns cst-berger discontinued robotoolz lasers there is a guy who will give free estimate on repair A.P. Service & supplies 610-944 8030
May 28, 2010 | Robotoolz SelfLeveling Laser Level with...
Cst - Berger 20X Speed Line Transit - Level Kit - 54 - 200K Logo
Top Cst Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Cst Measuring Tool and Sensor Expert? Answer questions, earn points and help others
