Question about Welding Tools
Injector pipe leaking new injector pipe fitted couldnt prime it injector pump tested not good new one fitted now getting diesel to the injector but still no will not have it
  • 58 Answers
Hi take the injector out ,refit pipe turn motor over for 30 sec or so keep well away from end of injector ,if fuel comes out put it back and try it take air filter off spray wd 40 in when it turns over DO NOT USE EASEY START if no fuel came out of injector replace it silk090
Posted on Oct 24, 2009
How to prime the injectors and fuel rail after replacing the injectors?
Electromagnetic or electronic fuel injectors are self-priming and all that is needed is to crank the engine, though I believe on later systems the injectors are coded and will not work unless the ECU has been informed the codes have changed. I think this applies more to diesels than petrol engines but on such matters I am not expert...
Staying with diesels for a moment - new injectors on either engine would usually mean fitting a new fuel filter. Sometimes this would require the primary diesel circuit to be bled in order for the high pressure pump to work.
The amount of starter cranking required can be cut by leaving each injector pipe loose in turn until diesel is dribbling from it.
Feb 20, 2016 | Cars & Trucks
How to bleed injector pump on isuzu nkr pick up
These are self bleeding so if diesel is getting to the pump it won't need bleeding. If you still feel the need to bleed the system then loosen one injector pipe turn the engine until you see diesel coming tighten again it should fire up. If you have a good flow of diesel coming from the filter to the pump and diesel at the injector pipe then your pump pressure may be low. To check remove any injector reconnect the pipe to it with the injector end where you can see it. Turn the engine with the starter a few times the diesel should be making a mist. Wear eye protection for this test
May 28, 2014 | 1995 Isuzu Trooper
Air in diesel filters
check diesel filter rubber ring or diesel main pipe puncher
Jan 30, 2014 | Mahindra Cars & Trucks
Injector pump leak
This will almost certainly be the plastic fuel pipes connected to the fuel pump replace both of them this is a common fault the rubber o rings on the pipes harden and leak make sure you prime the diesel filter after replacing these pipes the engine can be difficult to start on this model once air is allowed in the system
Nov 22, 2013 | Mercedes-Benz E-Class Cars & Trucks
Isuzu kb 280 dt got a fuel starvation problem after it stands for a few days, when i pump the prime pump on top of fuel filter the problem is gon.
It could either be a fuel pipe between your prime pump and injector pump that sucks air so your diesel flows back into your fuel tank. Or you need to replace the prime pump.There is a rubber diaphragm in the prime pump that gets worn. Unfortunately need to buy a new prime pump. A simple sollution is to fit a non return valve to your fuel line. That need to be connected between the prime pump and fuel tank. Hope it helps. Blessings
Nov 09, 2012 | Isuzu Rodeo Sport Cars & Trucks
How do i bleed the diesel on a 1990 isuzu rodeo jb1 4wd
1990 its an injector pump ,two bleed screws on the in jector pump,but it might have a auto bleed pipe,think it has so prime it with the hand pump then slacken the injector pipes on the injectors and assistant cranks ,never no more than 20secs so as not to overheat the motor ,then as one or the other shows fuel pumping up tighten it as you get to 2 or more it will start
Aug 19, 2010 | 1990 Isuzu Pickup
How do you bleed a peugeot 206 1.9 diesel fuel system
The diesels I've worked on are bleed at the injectors. You need to loosen each injector in turn and pump up fuel pressure until only fuel comes out, no air, than tighten the fitting up before it back feeds. Repeat this process for each injector.
May 09, 2009 | 2006 Peugeot 505
Jag diesel x-type fuel filter change
change fuel filler as normal then connect fuel feed from tank connect injectors leak off to fuel fillter leaving the rail flow pipe off this is the midddle one with the arrow pointing out
connect a piace of clear plastic pipe to this connection and slowly suck the fuel through the filtter and half way up pipe you can see this happen stop sucking the fuel will flow back to fillter take the pipe you were sucking through off and connect the feed to rail pipe turn on and crank engine she will start immediately
Mar 14, 2009 | 2004 Jaguar X-Type
My fuel filter will not prime on a 6.2 diesel what could I have done wrong
hi from the uk if your vehicle is equiped with a manual fuel primer device? and unable to prime f i pump ? no fuel at f i p are you trying to prime with the ignition on ? as the fuel shut off solenoid that is fitted to f i p is elec/ignition on activated so fuel can then be primed into the f i p and then to assist starting just loosen a couple of injectors delivery pipes while turning engine over then retighten the stop solenoid is liken to a temp sender unit ? and is normally located at the top of f i p adjacent to fuel inj pipe connections solenoid has a wire attached to activate fuel valve in solenoid allowing fuel flow and ign off shuts fuel supply if you operate on/off with key ign you can hear click if working? but better test is by volt meter to test if ign supply ok? if you have merely ran out of fuel or just changed filter ? then provided no air leaks on supply fro tank the above should get you started ? come back if you have more info/update? hope and wish you good luck
Oct 26, 2008 | GMC C2500 Cars & Trucks
Welding Tools Logo
82 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
