Question about Sewing Machines
Necchi model 6015 sewing machine
Machine will not start. It is pulugged in, the clutch knob is in proper place, no threads caught in the hook race. What could be the problem? Please
Thank you. That was the problem. I am grateful.+
Posted on Dec 21, 2007
I do not have an 6015 i have and 6022 in necchi
Hello jone...... please rewrite your question one more time starting fresh with the brand, model number and exactly what is wrong with your machine. We truly do want to help you but we need all of that info. in one place. Thanks. Joe
Dec 24, 2010 | Necchi 6015 Mechanical Sewing Machine
I have an omega 3730m sewing machine and i find that when i am sewing, the stitching underneath balls up nad is not tight. i tried to adjust the tension but nothing seems to work. any suggestions?
I find that re-threading both top and bottom threads fixes the problem. Sometimes the thread has not gone through the tension springs properly. try a new needle too.
Dec 08, 2010 | Necchi 6015 Mechanical Sewing Machine
I cleaned my machine and now the bottom thread making huge loops and it is jamming up. i have a necchi omega 6015
have you cleaned under the needle plate
change the needle
make sure the thread has not come off the thread take up lever
some thread & needle don't work togeather--try this
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
Nov 21, 2010 | Necchi 6015 Mechanical Sewing Machine
Machine feels like it is bound up neddle will not move
Normally this will be caused by lint/thread caught in the bobbin/hook area.Remove the bobbin case, push the two fingers (about 4 and 8 oclock positions) that hold the race cover on, and then remove the hook. If it will turn now then your good. Clean the area out, put a couple drops of oil on the hook and reassemble it.
May 25, 2010 | Necchi 3102 Mechanical Sewing Machine
The thread keeps breaking while I am sewing.
nake sure the machine is threaded proiperly with a good mercerised thread no thicker than a number 40, make sure the needle is in the correct way round, top tension about 4 or 5
Oct 25, 2009 | Necchi 6015 Mechanical Sewing Machine
Thread caught in hook race
There should be a small screw on the side of your bobbin case adjust it little by little until you get the correct tension.
Jun 06, 2009 | Euro-Pro 9125 Computerized Sewing Machine
Machine wont sew
You may need to get a scrap piece of material to lead off with or hold on to your thread and gently pull it to start your material.
Oct 27, 2007 | Necchi 6015 Mechanical Sewing Machine
Wire thread guide placement
The thread will be threaded in a clockwise direction on the tension control. Pull the thread until there is a tension on the spring. There will be a catch on the thread that you will notice this. Now, thread the machine in the same way that is normal. It should work. Make sure you start your tension at four to test how it is doing. From there make slight changes in tension. Don't worry about the very tiny bend in the wire at the very end. It is only for weight and to keep your thread from catching and getting broken.
Dec 21, 2017 | Necchi 3101 Mechanical Sewing Machine
How to Thread machine
Just call 1-800-525-9987 and ask for Parts or Service - these guys are the sole importer of Necchi and can answer your questions - sorry i haven't found a download for a manual in english - if you want in italian is available for the 6000 series here: but the guys on the number at the top will be able to tell you the best place to get one. Hope this helps :)
Feb 27, 2007 | Necchi 6015 Mechanical Sewing Machine
Sewing Machines Logo
80 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
