Question about Broksonic CTGV-5463TCT TV
Lighting struck the apartment about a week ago, tv was plugged in when lighting struck apartment. Tv does not turn on anymore.
  • Broksonic Master
  • 458 Answers
Best to take it to a repair centre as lightning damage can cause either minor fault such as an internal fuse blown or major problems that would make it uneconomical to repair. Ask for an estimate for the cost to repair.
Posted on Oct 01, 2009
Can't be turned on. Last used a week ago, now no red light at all when power is supplied.
Make sure the cord is pushed in all the way on the back of the tv. If it is then check for fuses on the power supply board inside the tv
Jan 02, 2014 | Samsung UA40C5000 40 LED TV
Toshiba hooked to dish struck by lighting, will not turn on, solution?
Ensure the power outlet has power. Try TV on a different power outlet. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Aug 01, 2012 | Televison & Video
My Television, LC-37SB24U, must have been struck by lightening over the weekend. It was on a surger. As of now, it will not turn on. The power light will come on, but a after a few seconds the power light...
This problems it not a fuse problems or u would have no power to the tv at all.If ur tv it is on plug into a power surger protector.Tries the tv unplug,replug it back about an hour later for the tv to do a resetting itself back to the factory setting.50/50 this tv will power up and work again.If the tv still have same problems,than the tv main tv Tuner signal board it is shorted and the causes and the problems.The tv main tv Tuner signal board it is the board that where the tv incomming broadcasting signal wire plug into it.You can do and have some basic mechanicals skills like take things aparts and putting it back togther wright?Yes,tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv main tv Tuner signal board for the replacement.
Aug 15, 2011 | Sharp LC37SB24U 37 in. LCD TV
Sony kv36hs500 tv, suddenly no power, no standby lights, no sound
U check the power source?Take the tv aparts,check or replaced the power fuse,might get lucky.Not,than sorry,this tv can't be repair,without replacing electronic's componnents parts.Hire the same shop to do the repair.Ur tv power ICS inverter are dead.
Jun 15, 2010 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Av channel
unplug it for 5 or 10 minutes then plug it back in turn it back on run it thru the setup program
Sep 27, 2009 | Philips Magnavox 13MT143S 13" TV
Color messed up on tv since lightning strike
your tv may have ben magnetized by the lightning strike.
tv's have an automatic degaussing circuit that demagnetizes
the pix tube when the set is turned on. this degaussing circuit
may not be working or magnetism may have been too strong for
the internal degaussing to correct.
contact local tv repair shop in your area see if they can manually
degauss your set , it should be a min. service charge around $25.
roland
Mar 22, 2008 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
TV was struck by lightning
If it was struck by lightning, the surge would completely fry the insides of your TV. Your TV probably won't work anymore and you may have to consider replacing it. Some TVs have accident warranties so something like this could be protected, but if not, you will have to purchase a new one.
Aug 27, 2007 | Toshiba 32A35 32" TV
TV shuts off after few minutes
tap it on its side then try to turn it on and see if it stays on if it does bad solder connections
Aug 11, 2006 | Sanyo DS31520 31" TV
Broksonic CTGV-5463TCT TV Logo
217 people viewed this question
Top Broksonic Televison & Video Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Broksonic Televison and Video Expert? Answer questions, earn points and help others
