Question about Tascam Dp-02cf Digital 8-track Recorder
I have a sony mini disc recorder walkman mz-n505, and it is skipping out in ten to twenty second intervals when traveling on my bike. It has never done this in the past, do you think it needs cleaned? It works fine when stationary at home.
    Brigadier General:
  • 3,006 Answers
Unfortunately this is usually the sign of a failing read/record head unit.
MD players don't work like CD players in that the disc is not constantly spinning and the head is not constantly reading. Instead, the disc spins up and the head reads enough information into memory to play; if there is an error in reading the info the head will make multiple attempts to retrieve the data until it's complete. normally this is highly successful and is why MD players are usually regarded as the best electro-mechanical music delivery system for runners, cyclists and any other moving application.
When the head mechanism wears out the errors increase and the head has to oversample frequently to get the data. Eventually it's doing this so often that it can't also cope with the additional requirements of being in a moving environment and runs out of data, causing skipping and black outs. At the moment your player is fine when stationary but you'll soon find that it will begin to skip even under those conditions.
MD head cleaners are available, but I stopped using them years ago as they are a waste of money. MD's themselves have protective covers which prevent the disc from getting dirty, this also means that they do not transfer dirt to the heads. MD units also do not open all the way like most CD units, so there is no opportunity to accidentally touch the heads. In practice, you'll only find an MD cleaner to be of potential use if you live in a very dusty environment. In most cases if the MD head has actually got dirty enough to need cleaning then an MD cleaner simply isn't man enough for the job.
Replacement heads are rarely available these days and even when they are they're a 'mare to replace. I'd suggest looking out for a free/cheap replacement player. FreeCycle often has free examples which I've sometimes found to be boxed and unused as MD wasn't everyone's cup of tea. This is great for the likes of us as it also means that there are plenty of cheap MD units around as well and also lots of free/cheap used discs (although not all can be erased and re-recorded on).
Posted on Oct 05, 2009
Need software for mz-n510 md walkman mini disc please
There are three set of software for your Sony Net MD Walkman MZ-N510 Personal MiniDisc Player.
Please download and USE the latest version of these files to avoid operation problem.
Please SELECT the correct operating system on the page before download.
Click HERE for the official Sony download page.
Jan 27, 2011 | Sony Net MD Walkman MZ-N510 MiniDisc...
I have the sony minidisc recorder mz-n505 and bought a new acer computer with windows 7 but i can not get the walkman to work. No driver. I have download the software from sony and still does not work. Can...
Sony no longer support minidisc products so there will be no new Win7 drivers.
If you don't have an earlier pc or laptop to use it with, then you can try using the Win7 Compatibility Wizard.
Sep 18, 2010 | Sony Net MD Walkman MZ-N505
Drivers for sony md walkman MZ-N505
You can download the driver for this unit from this link , just type the model of your device.
http://esupport.sony.com/US/perl/swu-list.pl?mdl=MZN505
Jul 26, 2010 | Sony Net MD Walkman MZ-N505
Manual funcionamiento MZ-N505
Try this site:
http://www.usersmanualguide.com/sony/minidisc_walkman/mz-n505
Feb 07, 2010 | Sony Net MD Walkman MZ-N505
Record on to mini disc
you can use optical cable / or mini plug to (Y) RCA jacks ...plug the optical cable to the back of a CD player or RCA jacks to your Reciever / Amp (output) to record
Aug 25, 2009 | Sony Net MD Walkman MZ-N505
I need the software drivers for my Sony Net MD Walkman MZ-N505
Click Sony Support and download required software of MZ-N505 by selecting Vista OS in drop down list there.
Mar 18, 2009 | Sony Net MD Walkman MZ-N505
Erasing an MD after "TR Protect" has been set.
I figured it out!! Initialize! Connect your MZ-N505 to a PC with the USB port. You'll need a USB A to mini B cable.Using the SonicStage software from Sony Support. You can then click the Transfer tab at the top of the screen. Select NetMD. All the current tracks on the disc should appear in the right hand window. At the bottom right of that window click Device/Media info. A dialog should pop up allowing you to Initalize (erase) the disc. Whew! I also bought a bunch of used Mini Discs that I wanted to record over. I ran into the same "TRProtect" message. Now I can use all these discs! Hope this helps. Have fun.
Dec 19, 2008 | Sony Net MD Walkman MZ-N505
Hi I need the hadware disc for sony portable minirecorder mz-n505
Go to Sony Support and check downloads area where you can get driver and SonicStage for your MZ-N505 Sony walkman.
Nov 18, 2008 | Sony Net MD Walkman MZ-N510 MiniDisc...
Sony MZ-N505 - says mini disc is blank
Hi- it sounds like the record head is bent or needs adjustment. I do repairs on Sony minidiscs, so you may contact me at: masondixon@netzero.com for help.
Jacques
Nov 03, 2008 | Sony Net MD Walkman MZ-N505
NEED A DRIVER FOR PC
google sony go to sony us there are drivers & soft ware there for walkman mz-n505 good luck worked for me
Jun 16, 2007 | Sony Net MD Walkman MZ-N505
Tascam Dp-02cf Digital 8-track Recorder Logo
185 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
Michial Gueffroy
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
