Question about Garden
Need a diagram on how to connect the fuel lines back on a ryobi 725r trimmer
    President:
  • 1,776 Answers
Typical fuel line routing is:
One line (the one with the fuel filter in the end of it) comes out of the fuel tankneed a diagram on how to connect the fuel lines - 2.gif and goes to the bottom fitting on the carburator. The second line comes out of the tank and goes to the bottom fitting on the primer bulb. The third section of line goes from the top fitting on primer bulb to top fitting on the carburator. Hope this helped and best wishes.
Posted on Oct 01, 2009
How do you get the fuel line connected to the fuel filter nipple on the bottom side of the gas tank on the Ryobi 725r gas trimmer?
You must run the fuel line through the back of the tank and out the filler hole,make your connections,i used a small amount of vaseline to make the connections.Then pull the filter into place,make sure some of the nipple of the filter pokes through,then slide the retainer ring on the hose and force it onto the filter nipple.
May 09, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi 725r leaks gas from air filter and will cut out after starting up
This is a problem with most ryobi tools. From what i've read over time the gas lines shrink and need to be replaced. You'll need to replace both the lines coming from the carb to engine and the one connecting to your primer bulb. I hear there is a kit that contains both the primer bulb and fuel lines for this exact problem.
Apr 21, 2010 | Ryobi Garden
Putting fuel line on right on ryobi 725r 15'' 31cc weedeater
One line (the one with the fuel filter in the end of it) comes out of the fuel tank2.gif and goes to the bottom fitting on the carburator. The second line comes out of the tank and goes to the bottom fitting on the primer bulb. The third section of line goes from the top fitting on primer bulb to top fitting on the carburator. Hope this helped and best wishes.
Sep 08, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
2 Cycle Gas Trimmer will not start
it is normal to see air bubbles in line when pumping the bulb. to make sure what the problem is, try starting several times, remove spark plug. if dry, yes no fuel, remove the carb. if wet, place plug on engine block and look for blue spark. no spark means you need new plug, plug cord or ignition module
Jul 24, 2009 | Ryobi Factory Reconditioned 18" 40cc...
How to remove drum connector off ryobi weedeater
I believe there are four phillips headed bolts around the outside edge of the housing
Jul 23, 2009 | Ryobi Garden
RYOBI 725R FUEL LINE DIAGRAM
I just rebuilt my 725r. I don't have a diagram but I can explain it. There are two lines coming out of the fuel tank. The line closest to the rear is the fuel feed and has the in-tank filter (these are available for replacement). This line goes through the lower case hole of the air filter housing and attaches to the bottom of the carburetor. The line toward the front of the tank attaches to the longer/lower fitting the primer bulb and is the return. The line coming off the shorter/upper fitting of the primer bulb goes through the upper hole of the air filter housing and attaches to the top of the carburetor.
FYI also, the forward carburetor screw is the low idle adjustment & the rear, the high-speed mixture. The original oil mixture spec called for 32:1
Jun 13, 2009 | Ryobi 15" Electric Factory Reconditioned...
Need routing of fuel lines on Ryobi string trimmer Model 725R.
The larger fuel line goes from fuel filter to carbuerator.The smaller line is the return line from the purge bulb tofuel tank. mitchjl_1692
May 27, 2009 | Ryobi 15" Electric Factory Reconditioned...
Ryobi 2 cycle gas trimmer 705r/725r
The gas nipple that come out I have...whats goes in the other hole?
Aug 28, 2008 | Ryobi Garden
Garden Logo
746 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
