Question about LG 37LC7D 37 in. LCD HDTV
Where can i find in replacement plastic peice for my flat sceen it cacked
  • 11,896 Answers
Possibly
etech.com,
or
ebay,
or
www.shopjimmy.com
or
spares.bigwarehouse.com
Posted on Oct 01, 2009
The primer outlet valve on zama carb is leaking. How can I fix this?
I don't know what make or model the piece of equipment is that you're referring to, but if the primer bulb sits on the top of the carb then there is a plastic base that can be replaced. If its a primer that has pipes connecting to the cack of it then you will need to replace the primer bulb entirely
Mar 16, 2016 | Garden
How do i remove the wheels or whatever i need to remove to get the hose peice out it was held by a plastic peice tht i wanna replace
Remove the wheels, axle, handle latch and spring. Then try to find someone that still has a power head elbow for an old hoover. I can check to see if they still have any if you call me. 1-800-353-4677 tomorrow
Jan 29, 2014 | Vacuums
The picture went from full sceen to half a sceen. how do i get it back to full sceen.
need the model number of the set and also is it half the screen left or right or half the screen from bottom to top
Dec 30, 2012 | Televison & Video
Washer will not agitate or spin - still fills and drains
check the peice underneath the motor it is a plastic peice. and then check the dog ears inside the agitator. thats what i had to replace and it cost about 30 bucks. and took about 30 minutes.
Sep 19, 2011 | Whirlpool LTE5243D Top Load Stacked...
I need to detach the stand from the samsung b2330 HD tv pl advise
screws are in the back, sometimes you have to pull the plastic peices apart.
Mar 29, 2011 | Samsung B2330HD 23 in. LCD TV
The incline on my pro form crosswalk 400e is slipping when you incline it. There seems to be a plastic piece that slides up and down on the incline gear. I think that the peice is either broken or loose
Hello there. Yes there is a plastic piece in your particular model of incline motor. It also does wear out on occasion. The only fix is to replace the entire incline motor. This motor is available at http://www.iconservice.com If you go to the replacement parts section and input your model number (29633) you will be able to find part number 51 is available for $159.
Good Luck! Tim
Jan 26, 2010 | Exercise & Fitness
No steam when I pump the handle.
most likely problem is the plunger inside of the pump. 38.00 dollars i think
Jun 12, 2009 | Lincoln 4000 Fresh-O-Matic Rice Cooker
Water leaking from white plastic peice under washer
If this piece had 2 hoses attached and slides onto the motor, then it is the pump. you will need to replace it. Part # 3363394 available both new (27.99) and used (9.99) from timerking.com Hope this helps!
Jan 07, 2009 | Roper RAS6233KQ Top Load Washer
Four blinks goodman furnace
yes you can and it is on the heat exchanger just inside the front panel it is about 1and1/2 by 2 inches with two wires connecting to it, it has two screws holding it in place, it looks like it is a peice of flat plastic
Dec 21, 2008 | Goodman GMS90703BXA Heater
LG 37LC7D 37 in. LCD HDTV Logo
20 people viewed this question
Computer Repairing
Computer Repairing
