Question about Kenmore Freezers
Hi, Kenmore upright freezer model 253.9284213 The other night the door was dripping and the internal temperature was warming up. The compressor would kick on then a few seconds later it would stop. Then it would repeat again a few minutes later. The compressor was warm. I found on the internet it could be the compressor relay or overload switch. So I removed both of them and tested them with my ohm meter. They both passed, and they also looked to be in good condition (no corrosion). I also spun the timer knob a few times. When I put it all back together, the compressor turned on properly. The freezer has been working normally for the past few days, but I am tentative to put food back in it. I don't like problems that just fix themselves and go away. Any thoughts? Should I replace any components as preventative maintenance? Thanks
dididsaythat
  • 291 Answers
SOURCE: freezer making noise & left side of the freezer (on outside is very warm to touch)
Sounds like the freezer evapurator fan... they make noise on and off at times when bears are wore... Thats about the only thing that can make noise inthe area ur talking about.. if noise comes back listen where the freezer fan is.. is most liklly the problem
Posted on Nov 03, 2007
22yooper
  • 828 Answers
SOURCE: Freezer Problem
If it started to cool again the compressor was running. Check the condenser and make sure it is clean. Provide as much air movement through the garage as possible . 100 degrees is a high temperature to be operating a refrigerator in.
Posted on Jun 10, 2008
  • 1462 Answers
SOURCE: Condensation on base of Hotpoint R134a upright freezer
sounds as tho you have an insulation breakdown. no repair except to refoam - and that is difficult to do
Posted on Aug 09, 2008
  • 1462 Answers
SOURCE: freezer does not work
almost certainly a problem with the defrost timer - just replace complete. doesn't matter what position you set timer to when replaced
Posted on Sep 07, 2008
mikeh77586
  • 9 Answers
SOURCE: Kenmore Upright Freezer compressor running 6 seconds every minute
Usually the compressor runs pretty warm anyway. However if you think it's too hot I would start with the condenser coils located either under the unit or on occasion they are located on the back. The air flow across these coils as well as the airflow around the compressor must be maintained. I forgot to ask if the condenser fan is running. Check and make sure that the Fan is running and the air flow is good. Also, When you transported the unit did you move it standing vertically like it normally stands or did you lay it on its side. If you transported the unit on its side you must wait a minimum of 24 to 48 hours prior to start up or the unit could be ruined permanently. The refrigerant has to be utilized through the compressor as a gas. If the unit is on its side liquid refrigerant could be introduced into the compressor and can cause permanent damage. If this is the case I recommend that you turn the unit off at once and wait the 36 hours for the Refrigerant to settle then try it again. This transportation rule applies for any appliance That uses refrigerant, Air Conditioners etc. These units are not that hard to diagnose. The only other item that is usually a problem is the defrost timer. It is not very expensive and can also cause some of the same symptoms that you are eluding to. The defrost timer allows the freezer to periodically shut down to prevent the buildup of frost or ice on he evaporator coils and on the inside the unit. If it is defective, then the unit will either run all the time and cause the evaporator coils to freeze up or will not allow the compressor to switch on and it will not freeze like it should.
Posted on Nov 12, 2008
Kenmore upright freezer not freezing
Kenmore & Whirlpool refrigerator frost build up in freezer not ...
? 7:02
www.youtube.com/watch?v=gVXT7pZyk_o
Sep 12, 2013 - Uploaded by ApplianceVideo.com Service a Kenmore Upright Freezer which has the following problems: Not Cooling Properly At: http ...
Freezer Troubleshooting - What to Check Before You Call a ...
www.realestate.com > Realestate.com Blog > Articles
Aug 12, 2012 - Alternatively, if the freezer is in a defrost cycle, it will not kick on immediately, the temperature ... Refrigerant circulates through coils, spreading coldthrough the unit interior before .... We have a kenmore upright deep freezer.
Sep 19, 2015 | Kenmore Freezers
Kenmore freezer too warm
Are you referring to the internal temperature of the freezer? If so
have you checked that the door is closing ok and that the door seals are meeting the door frame all round?
It might be that the coolant gas has slowly leaked out. A good indication this has happened is that the bottom of the freezer is a lot warmer than the top. If this is the case a serviceman will need to drain the existing gas and then recharge, re-pressurise and seal.
If you are referring to the outside cabinet temperature then it's probably ok and there is no fault. You would expect the outside panels of a freezer to be around room temperature or warmer as the freezer removes heat from inside the cabinet and expels it outside.
Jan 01, 2014 | Kenmore Freezer 20.3 cu. ft. Frost Free...
My Kenmore 9 upright freezer feels warm on the outside, what could be the cause. I have defrosted and cleaned it already and seems to work fine. however i am concerned with the outside temperature. Please...
This is normal. The condenser coils on freezers are typically located in the walls.
The refrigerator in your kitchen has condenser coils that are hot either under the frig or on the back. Freezers do not need as much heat transfer on the coils with the air so they put them in the walls, it is called a warm wall condenser. It may even feel hot to the touch if you happen to feel it near the end of a cooling cycle. It will be the warmest close to the compressor and cool off at it makes it around the cabinet down to the other side.
Apr 25, 2010 | Kenmore Freezers
Need to empty drip pan. How do you remove the
The standard procedure is to remove the plastic grill at the bottom of the front of the freezer and then slide the pan out for cleaning and emptying. Might as well vacuum dust out while your at it. Helps the compressor operate at a cooler temperature.
Please rate this answer for me. Thank you.
Mar 26, 2010 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Sears Kenmore Upright freezer is Making a loud humming sound
change the rubber washers on the compressor should work a treat...
Feb 05, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Upright freezer quit cooling, compressor runs, interior fan runs. copper line from compressors, 1 is warm and 1 at room temp
Hi..
Try to check this
Good luck!!!
Regards
PCmania
Jul 08, 2009 | Frigidaire Freezers
Freezer compressor runs steady & getting -30F
You probably have a defective thermostat or sensor for reading the temperature.
Mar 23, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezer won't run
There is no reset switch. There is a thermal overload protector mounted on the compressor. Does the compressor hum and then give a click sound. If so your compressor has failed. If the compressor is cold (Room Temperature) and it does not try to run your thermostat may be bad. If so remove the temperature control and jumper the two main wires that connect to the control. Unit should be unplugged to do this operation. Insulated the wires so they do not contact any metal surface. Plug the freezer back in. If it runs and cools replace the thermostat.
Jul 01, 2008 | Freezers
Kenmore Upright Freezer Model 253-9280810
is it possible the door has not been closed at some point?
If so they can build up with ice in the evaporator which the defrost system cannot handle....Try a manual defrost.
Depending on where the unit is installed high ambient temperature can drop the internal temp enough to set the alarm off though they will still freeze sufficiently
Dec 28, 2007 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Freezers Logo
351 people viewed this question
Top Kenmore Freezers Experts
AJMAL KHAN
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
