Question about Frigidaire ATF6000ES Front Load Washer
Err 57 - No response from machine just flashes Err 57 Checked the resistance on the motor and it appears fine showing 5 ohms at each connection. Replaced the motor control board as advised by the tech data sheet. Still registers Err 57.
  • rgsherrill Oct 02, 2009
    i followed the instructions that you just explained. The motor is fine and it suggested if that is the cast that i replace the motor control board. I did and it still says Err 57.
    It does not say E57 but rather flashes Err and then registers 57 and stays there. Don't know if this is different or still pointing to the motor
  • rgsherrill Oct 17, 2009
    Replaced control board and it seems to initially fix things but I am getting E91.
  • 708 Answers
Sorry for the delayed response, PC problems. Anyway, it could be 1 of 3 boards. the control board, interface board, or the control panel. Visually inspect them and see if anything looks blown. Most of the time it is the control board. However, without actually seeing it it is an educated guess.
Posted on Oct 13, 2009
  • Chris Yelton Oct 18, 2009
    E91 suggests that there is a possible wiring fault to the selector as the LEDs do not light up. you need to trace the wire from the selector to its opposite end and make sure all connections are tight and no fray in the wire anywhere
    President:
  • 1,653 Answers
The error indicates that there is a High Current detected on the Inverter and given the motor seems fine have you checked the Inverter itself and made sure that the output contacts are not shorted or bridged in any way. Try seeing what the output of the invereter is off load and also on load.
Posted on Oct 05, 2009
Staus light flashes 3 times then pauses then 1 more changed pot, motor, and brake changed also lights and horn work the motor and brake are fine being checked
Youre 3 lights flashing unplug charger & turn key of and back on.., Hi the correct pot for you're scooter is a 25kohm resistance =25,000 ohm's..in regards to brake assembly try ringing monster scooter parts 800-798-0325 to c if u have the correct brake assembly cheers i do u know the make & model of scooter :: resistance on the potentiometer sounds a bit wrong most range between 25 K ohm to ,100 K ohm resistance. A 100 K ohm = 100-000 ohm's..a pride wrangler uses a 250 K ohm pot . Cheers
Jul 06, 2016 | Health & Beauty
Where is the fuse box for the wipers
It is under the dash panel right hand side , kick panel ? Fuse F1.1 10amp . an fuse F1.113 30 amp.
Visual Inspection Chart Mechanical Electrical
  • Windshield washer hoses
  • Wiper linkage
  • Multifunction switch
  • CJB fuses:
    • 1 (10A)
    • 38 (25A)
    • 113 (30A)
  • Circuitry
  • Windshield wiper motor
  • The windshield wipers are inoperative
  • Multifunction switch.
  • Circuitry.
  • Ignition switch.
  • Windshield wiper motor.
  • Go To Pinpoint Test A .
PINPOINT TEST A: THE WINDSHIELD WIPERS ARE INOPERATIVE Test Step Result / Action to Take A1 CHECK CIRCUITS 65 (DG) AND 1002 (BK/PK) FOR VOLTAGE
  • Key in OFF position.
  • Disconnect: Windshield Wiper Motor C125.
  • Key in ON position.
  • Measure the voltage between windshield wiper C125 pin 5, circuit 65 (DG), harness side and ground; and between windshield wiper motor C125 pin 8, circuit 1002 (BK/PK), harness side and ground.
  • Are the voltages greater than 10 volts?
Yes
GO to A2 .
No
REPAIR the circuit(s) in question. TEST the system for normal operation. A2 CHECK CIRCUITS 57 (BK) AND 875 (BK/LB) FOR OPENS
  • Measure the resistance between windshield wiper C125 pin 6, circuit 57 (BK), harness side and ground; and between windshield wiper motor C125 pin 3, circuit 875 (BK/LB), harness side and ground.
  • Are the resistances less than 5 ohms?
Yes
GO to A3 .
No
REPAIR the circuit(s) in question. TEST the system for normal operation. A3 CHECK THE MULTIFUNCTION SWITCH
  • Disconnect: Multifunction Switch C202a.
  • Carry out the multifunction switch component test. Refer to Wiring Diagrams Cell 149 for schematic and connector information.
  • Did the multifunction switch pass the component test?
Yes
GO to A4 .
No
INSTALL a new multifunction switch. REFER to Section 211-05 . A4 CHECK CIRCUIT 57 (BK) FOR OPEN
  • Measure the resistance between C202a pin 4, circuit 57 (BK), harness side and ground.
  • Is the resistance less than 5 ohms?
Yes
GO to A5 .
No
REPAIR the circuit. TEST the system for normal operation. A5 CHECK CIRCUITS 56 (DB/OG), 58 (WH), 61 (YE/RD), AND 63 (RD) FOR OPENS
  • Using the following table, measure the resistance between the multifunction switch C202a harness side and the windshield wiper motor C125 harness side:
    Multifunction Switch C202a Windshield Wiper Motor C125 pin 7, circuit 56 (DB/OG) pin 10, circuit 56 (DB/OG) pin 3, circuit 58 (WH) pin 11, circuit 58 (WH) pin 5, circuit 61 (YE/RD) pin 1, circuit 61 (YE/RD) pin 1, circuit 63 (RD) pin 9, circuit 63 (RD)
Yes
GO to A6 .
No
REPAIR the circuit(s) in question. TEST the system for normal operation. A6 CHECK FOR CORRECT WIPER MOTOR OPERATION
  • Disconnect all wiper motor connectors.
  • Check for:
    • corrosion
    • pushed-out pins
  • Connect all wiper motor connectors and make sure they seat correctly.
  • Operate the system and verify the concern is still present.
  • Is the concern still present?
Yes
GO to A7 .
No
The system is operating correctly at this time. Concern may have been caused by a loose or corroded connector. TEST the system for normal operation. A7 CHECK THE WINDSHIELD WIPER MOTOR
  • Carry out the windshield wiper motor component test as described in this section.
  • Did the windshield wiper motor pass the component test?
Yes
The system is operating correctly at this time. Concern may have been caused by binding or incorrect pivot arm adjustment. REFER to Windshield Wiper Blade and Pivot Arm Adjustment in this section. TEST the system for normal operation.
No
INSTALL a new windshield wiper motor. REFER to Windshield Wiper Motor in this section. Hope this helps !
Feb 16, 2015 | 2002 Ford Expedition
What does LD code mean on my whirlpool cabrio washer mean?
Ld flashes when the water level does not change after the drain pump is on.
Is the drain hose or the drain pump clogged?
Is the drain hose height greater than 96? ?
Is the pump running? If not, see TEST #7.
TEST #7 Drain/Recirculation
Perform the following checks if washer fails to drain or recirculate.
1. See Activation of Manual Diagnostic Test Mode, and perform the Manual: Pumps test.
2. Remove the console to access the machine/ motor control assembly. See Accessing & Removing the Electronic Assemblies.
3. Visually check that the P4 connector is inserted all the way into the machine/motor control. If visual check passes, go to step 4. If visual check fails, reconnect P4 and repeat step 1.
4. Remove connector P4 from the machine/ motor control and check resistance values of pump motor windings. Resistance values should match those shown in wiring diagram, page 7-1. If resistance values are good, go to step 7. If winding measurements are much higher (tens of ohms to infinity) than shown in wiring diagram, a problem exists in the motor winding or in the connection between the machine/motor control and the motor. Go to step 5.
5. Tilt machine forward to access the bottom of the machine and the pumps. See Figure 1, page 6-13.
6. Check the resistance at the pump motor. Remove the connector at the motor and take measurements across pump terminals. Measurements should be as shown in the wiring diagram. If winding measurements are much higher (tens of ohms to infinity) than shown in wiring diagram, replace the pump motor. If the resistance at the pump motor is correct, there is an open circuit in the wiring between the motor and the machine/ motor control. Repair or replace the lower wiring harness. If the pump motor windings and machine/ motor control check OK, repair or replace the pump. Be sure to check the pump and tub sump for foreign objects before replacing pump.
7. See Activation of Manual Diagnostic Test Mode, and perform the Manual: Pumps test.
8. If the Manual: Pumps test failed, then the machine/motor control has failed: Unplug the washer or disconnect power. Replace the machine/motor control assembly. Perform the Manual: Pump test.
Aug 20, 2014 | Whirlpool Washing Machines
Winsheild wiper will not work
The wiper control module is probably at fault ,without test that is just a guess . The wiper/washer switch is a input to the wiper control module. Do you know anything about automotive electronics an electrical systems ?
  • The Wipers are Inoperative
  • Fuse.
  • Wiper motor.
  • Multi-function switch.
  • Circuitry.
  • Wiper control module.
  • GO to Pinpoint Test B .
Voltage drop testing the power an ground circuits for the wiper control module would be a good place to start . Do you know how to test electrical circuits with a volt meter ?
PINPOINT TEST B: THE WIPERS ARE INOPERATIVE CONDITIONS DETAILS/RESULTS/ACTIONS B1 CHECK FUSE JUNCTION PANEL FUSE 16 (30A)
Fuse 16 (30A)
  • Is the fuse OK?
Yes GO to B2 .
No REPLACE the fuse. TEST the system for normal operation. If the fuse fails again, CHECK for a short to ground. REPAIR as necessary. B2 CHECK FOR VOLTAGE TO THE WIPER CONTROL MODULE - CIRCUIT 65 (DG)
Wiper Control Module C294
Measure the voltage between wiper control module C294-2, circuit 65 (DG), and ground; and between wiper control module C294-11, circuit 65 (DG), and ground.
  • Is the voltage greater than 10 volts?
Yes GO to B3 .
No REPAIR circuit 65 (DG). TEST the system for normal operation. B3 CHECK CIRCUIT 57 (BK) FOR OPEN Measure the resistance between wiper control module C294-3, circuit 57 (BK), and ground; and between wiper control module C294-5, circuit 57 (BK), and ground.
Yes GO to B4 .
No REPAIR circuit 57 (BK). TEST the system for normal operation. B4 CHECK THE MULTI-FUNCTION SWITCH
Multi-Function Switch
Check the multi-function switch; refer to Section 211-05 .
  • Is the multi-function switch OK?
Yes GO to B5 .
No REPLACE the multi-function switch; REFER to Section 211-05 . TEST the system for normal operation. B5 CHECK CIRCUIT 993 (BR/W) FOR OPEN Measure the resistance between multi-function switch C269-4, circuit 993 (BR/W), and wiper control module C294-7, circuit 993 (BR/W).
Yes GO to B6 .
No REPAIR circuit 993 (BR/W). TEST the system for normal operation. B6 CHECK CIRCUIT 589 (O) FOR OPEN Measure the resistance between multi-function switch C269-1, circuit 589 (O), and wiper control module C294-1, circuit 589 (O).
Yes GO to B7 .
No REPAIR circuit 589 (O). TEST the system for normal operation. B7 CHECK THE WIPER CONTROL MODULE OUTPUT FOR VOLTAGE
Wiper Motor C152
Turn the multi-function switch to the HI position. Measure the voltage between wiper motor C152-4, circuit 57 (BK), and wiper motor C152-3, circuit 56 (DB/O).
Yes REPLACE the wiper motor; REFER to Motor-Windshield Wiper . TEST the system for normal operation.
No GO to B8 . B8 CHECK CIRCUIT 57 (BK) FOR OPEN Measure the resistance between wiper motor C152-4, circuit 57 (BK), and ground.
Yes REPLACE the wiper control module; REFER to Module-Windshield Wiper . TEST the system for normal operation.
Jun 29, 2017 | 2002 Lincoln Town Car
Mw612
The Motor Controller has detected excess current in the motor or electronic
switches. This fault has occurred momentarily.
Primary Source: Wiring.
Action: Check the wiring connections from the Motor Controller to the Stator
and the Rotor Position Sensor.
Secondary Source: Motor.
Action
1) Measure/check the motor harness, connectors and motor for shorts. This can
be done by taking a resistance measurement between phases of the motor
harness at the Motor Control module end. Nominal resistance should be
around 12.2 ohm for Phase 2, 3 & Phase 4. For Phase 5 and 6 Smart Drive
the nominal resistance should be around 32 ohms.
2) Check the Rotor Positional Sensor, Stator brass bridge terminal point and
associated harness for water, mechanical damage or corrosion.
Tertiary Source: Motor Controller module.
Action
If all the above show no signs of fault then replace the Motor Controller module.
Also check for water leaks from the cooling chamber or valves that could possibly
come in contact with the Motor Controller and fix the leak before replacing with new
Oct 19, 2012 | Fisher and Paykel GWL11 Top Load Washer
The dl. Code comes on
DL = Long Drain Ld flashes when the water level does not change after the drain pump is on.
Dec 31, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My Maytag Bravos quiet series 300 washing machine stopped. Won't drain. A message Ld shows. Not sure what to do
Hi and welcome to FixYa, I am Kelly.
My response is very long and will be in 2 parts this is PART 1
Here is what the service manual says about Ld:
"Ld" (Washer is taking too long to drain
water from the wash tub)
Check the following:
Is the drain hose kinked or clogged?
Is the drain hose installed properly? See
"Connect the Drain Hose," page 2-5. Press
PAUSE/CANCEL to clear display
Also:
Is the drain hose clogged, or the end of
the drain hose more than 96? (244 cm)
above the floor?
See "Drain System," page 2-3.
6. To remove the drain pump: (there are 2 pumps... the drain pump is on the left)
a) Loosen the clamps and pull the inlet
and outlet drain hoses off the pump.
Note that there is a tab on the outlet
connector that fits into a slot in the
hose.
b) Remove the three 5/16? hex-head
screws from the drain pump and remove
the pump from the tub.
Check the pump inlet and the tub outlet for obstructions.
Pump electrical winding resistance test:
-Disconnect the wire connector from the
drain pump terminals.
- Set the ohmmeter to the R x 1 scale.
- Touch the ohmmeter test leads to each
of the drain pump terminals. The meter
should indicate between 10.5 and 14 ?.
----Due to the design of the machine the 2 wires going to the drain pump have be notorous for backing out of the plastic connector. Check the connector of the pump for loose terminal connections. --
From the Ld troubleshooting steps / procedure:
Long Drain
• Is the drain hose or the drain pump clogged?
• Is the drain hose height greater than 96? ?
• Is the pressure hose connection from the tub to the machine/motor control pinched or plugged?
• Is the pump running? If not, see TEST #7.
TEST 7
test.
control.
repeat step 1.
pump motor.
Unplug the washer or disconnect power.Replace the machine/motor control assembly.
Nov 21, 2010 | Maytag Bravos 3.8 Cu. Ft. Washer
Wont power up
Hi dear.If you know what you are going to do,follow those steps,other wise call service department.(If you like,you can also contact me via icatci@hotmail.com I'm in Sydney 2144 I might help you to solve the problem) Phase 5 Only. The pump is used as part of the power supply if it is not connected Smartdrive will appear dead. Check the pump ~motor resistance is 33 ohms. If the pump is open circuit, has the thermal onnectlon cut out tripped? This should reset within 15 minutes after tripping once the pump has cooled down. If the thermal cut out has tripped, check for a blocked pump.
Check that the resistance of each of the water valves is 15 ohms 64 ohms (Phase 5).
Replace the Motor Controller, if none of the above faults are found. I hope that helps,thanks
Aug 31, 2010 | Fisher and Paykel GWL11 Top Load Washer
Kenmore oasis he top loader shows LD error code. got back panel off, now what?
Long Drain Ld flashes when the water level does not change after the drain pump is on. • Is the drain hose or the drain pump clogged? • Is the drain hose height greater than 96˝ ? • Is the pump running? If not, see TEST #7.
TEST #7 Drain/Recirculation Perform the following checks if washer fails to drain or recirculate. 1. See Activation of Manual Diagnostic Test Mode, and perform the Manual: Pumps test. 2. Remove the console to access the machine/ motor control assembly. See Accessing & Removing the Electronic Assemblies. 3. Visually check that the P4 connector is inserted all the way into the machine/motor control. If visual check passes, go to step 4. If visual check fails, reconnect P4 and repeat step 1. 4. Remove connector P4 from the machine/ motor control and check resistance values of pump motor windings. Resistance values should match those shown in wiring diagram, page 7-1. If resistance values are good, go to step 7. If winding measurements are much higher (tens of ohms to infinity) than shown in wiring diagram, a problem exists in the motor winding or in the connection between the machine/motor control and the motor. Go to step 5. 5. Tilt machine forward to access the bottom of the machine and the pumps 6. Check the resistance at the pump motor. Remove the connector at the motor and take measurements across pump terminals. Measurements should be as shown in the wiring diagram. If winding measurements are much higher (tens of ohms to infinity) than shown in wiring diagram, replace the pump motor. If the resistance at the pump motor is correct, there is an open circuit in the wiring between the motor and the machine/ motor control. Repair or replace the lower wiring harness. If the pump motor windings and machine/ motor control check OK, repair or replace the pump. Be sure to check the pump and tub sump for foreign objects before replacing pump. 7. See Activation of Manual Diagnostic Test Mode, and perform the Manual: Pumps test. 8. If the Manual: Pumps test failed, then the machine/motor control has failed: Unplug the washer or disconnect power. Replace the machine/motor control assembly. Perform the Manual: Pump test.
Jun 16, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Frigidaire ATF6000ES Front Load Washer Logo
309 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
