Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
The temperature in our freezer and fridge are climbing
  • monster_tech May 11, 2010
    Check for frost build up on rear inside wall of freezer, if so then defrost heater is more than likely defective. Advise and let me know.
    Scholar:
  • 103 Answers
Check for frost build up and rear inside wall of freezer. If so you possibly have a defective defrost heater.
Advise.
Posted on Oct 10, 2009
Wat temp is for fridge and freezer to be on plz
What are your recommended temperatures for the fridge-freezers? The default and recommended temperatures for our fridge-freezers are as follows:-
4?c for the fridge compartment, 5?c specifically for the fruit and veg compartment, and -20?c for the freezer.
The ideal temperature setting for a refrigerator is 3?C and for a freezer it's -18?C. The only exceptions are fridge-freezers in the RB*** range, for which we recommend -19°C (as -18?C isn't an available option for these models).
Keep your fridge at the perfect temp with these handy tips
Dec 04, 2016 | Refrigerators
Why is it beeping?
if temperature is rising, you will get a beep. you need to find why the temp rising. Clean condenser coils and make sure that condenser motor is running art full speed.
Sep 01, 2015 | Samsung RS275AC Refrigerator
Fluctuation of temperature GE Profile
g.e has mother boards or computer board in them located on the back outside wall,your board is on the top left,part number wr55x10942,everything on your machine runs through that board,also look at the evaporator coil where the thermostat is,there's a sensor on the top of the coil,it looks like a white bullet,if there's a black ring around it where the wires connect to it you also have to change that too.wr55x10025.go here and look at picture,if your board doesn't have all the relays like on this board then you don't have the updated board
http://www.repairclinic.com/PartDetail/Main-Control-Board/WR55X10942/1531075the new board has all 7 relays and is the newest board.hope this helps and good luck with it.
Sep 12, 2012 | GE Refrigerators
Over temp light on and refrigerator/freezer not staying cold.
Extended warranties usually are not worth the cost. My guess is that KitchenAid wants you to pay $73 out of pocket even though it should be absorbed as part of the warranty replacement of the refrigeration system.
Mar 08, 2017 | KitchenAid KBRC36FMS Bottom Freezer...
My 5 year old fridge and freezer have been climbing in temperature for the last 3 hours. I took what I could out and put it in the basement fridge and turned off the ice maker. What else can I do?
did you try to turn the thermosat on the fridge back . it may have been move to the cooler side. sometimes it is just that simple and we tend to overlook that kind of stuff sometime.
Aug 30, 2010 | GE Refrigerators
GE bottom freezer model PDS22MBRBWW gets too warm
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 12, 2010 | GE Profile PDS22SBRR Stainless Steel...
Water dripping from freezer into refrigerator area and frozen water in freezer
The defrost cycle is melting ice that will not go down the drain tube in the rear of the freezer. This can be a clogged tube due to debris, organic growths or ice blocking flow. What doesn't end up dripping into the fridge ends up freezing in the freezer compartment. Make sure the fridge is level or tilted back slightly.
Unplug the fridge from power. Remove the contents of the freezer and remove the ice maker, back wall plate and floor plate in the freezer section. Remove ice build up on the floor and tray in the freezer by thawing and soaking up water. Flush hot water (use a turkey baster to get at it) at the opening of the drain hose that is connected to the tray to thaw any ice.. once flowing to the evapraor tray under the fridge, mix up 1/2 oz of bleach and 4 oz of water and pour down the tube to kill any bacteria.
Reassemble and restock the freezer. Monitor the temperature of the fresh food (34 deg) and freezer (0 deg) compartments. If you notice the temperatures start to climb, there may be a problem with the defrost timer, terminator, etc. and may require a pro's help.
Mar 12, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Fridge tempertature
I have the same symptom too - freezer temperature flashes at -2. "Power Freezer" or setting it to any other temperature is not working either.
As a result, no ice being made. Please help!
Aug 03, 2008 | Samsung RS2630SH Side by Side Refrigerator
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
113 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
