Question about Kenmore Washing Machines
Display show f21 and it wont drain - Kenmore Washing Machines
  • 71 Answers
The f21 code actually is a no drain code....the machine has an electric pump behind the cover on the bottom with a lint trap in it....just unscrew the lint filter from the pump(there will be alot of water coming out when you take this out) and clean the trap and that should take care of your problem
Posted on Oct 03, 2009
F21 error on model mhwe300vw13 maytag 3000 it
Hello & Welcome to FixYa
F21 error is displayed when the washer is unable to drain, press PAUSE/CANCEL button twice to clear the display. After this please check the drain hose and drain pump filter for any blockages and make sure it is not clogged with foreign particles. You can also check the drain pump to verify that its working. Please get back to me if you have any other questions.
Kevin
Aug 05, 2011 | Maytag Washing Machines
He2 plus front load washer keeps showing F21 error code. I cleared the drain pump filter. Still displaying F21 how do i check to see if i need a new pump
If you found a blockage in the pump screen restricting the drainage and it now drains fine but F21 is still there,the error code can be cleared by pushing the PAUSE/CANCEL 2 times within 2 seconds.
If after clearing the error code if it returns on the next wash cycle the pump will need to be replaced.
I hope this has helped you resolve your washer troubles,
Gene
Aug 05, 2011 | Kenmore HE2 Plus Front Load Washer
My kenmore washier is showing a code f21 when it gets ready to drain. it's a kenmore elite 5
Kevin
Jun 28, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Door its lock shows light code f21
Kevin
Jun 26, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Water wont drain prooperly. The machine is making "buzzing" noise and showing F21.
Kevin
Feb 27, 2011 | Whirlpool Duet GHW9150P Front Load Washer
When I wash a load on NORMAL, it shows a code of F21 before the entire washing process is finished. What is F21?
Kevin
Feb 14, 2011 | Whirlpool Duet GHW9150P Front Load Washer
What is F21. Its keep showing.
Most likely bad water level switch.
Also,
EXPLANATION AND RECOMMENDED PROCEDURE
F21 LONG DRAIN
If the drain time exceeds 8 minutes the water valves turn off.
NOTES:After 4 minutes the "Sd" error will be displayed, then
4 minutes later the "F/21" error code will be displayed. Press
PAUSE/CANCEL two times to clear the display.
Possible Causes/Procedure
1. Check the drain hose and make sure it is not plugged or
kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure
the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Washer repair in Corona Del Mar, CA
Appliance repair in Corona Del Mar and Orange County, CA
Jan 26, 2011 | Kenmore HE2 Plus Front Load Washer
F 21 is showing on the display and the machine wont start.
Hi
Error code SD means LONG DRAIN. This error appears when the drain time exceeds 8 minutes and the water valves turn off. After 4 minutes the "Sd" error will be displayed, and then 4 minutes later the F21 error code will be displayed. Press PAUSE/CANCEL two times to clear the display. Please Check the drain hose and make sure it is not plugged or kinked. If the drain hose if fine then unplug the washer and check the electrical connections at the pump and make sure the pump is running. Check the drain pump filter for foreign objects. To access the drain pump and filter remove the front kick panel and trace the drain hose to the bottom of the washer, drain pump would be located there. If you are not able to access it, then replace the back panel as well. Plug in washer or reconnect power. If the issue is still not resolved then you would need to replace the drain pump.
Hope this helps... Please post back if you need more information.
Daniel
Jan 10, 2011 | Washing Machines
Shows f21 on display what does this mean ?
Check the drain line for kinks or obstructions. You can take a flashlight, remove the hose from the pump and look into the suction port of the pump. Check for anything clogging the pump. (like the occasional stray sock). Also check the pump impellers for broken or missing blades and ensure that the pump impeller spins freely. If any blades are broken/missing or if you cannot get the impeller to spin freely, the pump is defective and will need replaced. Hopefully it is just a clogged pump or drain line. Hope this helped and best wishes.
Sep 09, 2009 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
115 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
