Question about Canon EF 17-40mm f/4L USM Lens
Soft ratcheting noise when focussing
Just took delivery of this unit ,and put it on my 350d press the button an i can feel and hear the focussing motor moving the inner lens ,this appears to be notchy and unlike any lens i have had before, can someone tell me ,is this normal?
    Problem Solver:
  • 17 Answers
I've had mine repaired out of a center in New York. they did an excellent job. Replaced the servo and internal focus ring. It is an inexpensive lens but can be repaired much cheaper than replacing it. if you don't shoot 10s of thousands of pictures a year or can live with a little less than professional quality...and don't have the money, the repair of the beast is a good alternative.
Posted on Feb 04, 2009
  • 216 Answers
Yes, most are like that.
Canon is making a killing with lens: 17-40/4.0L; 24-105/4.0L and those EFS lens.
You've purchased about $800.00 and have a 40/F4.0, that is very slow.
This is a cheaper L lens and at lower cost.
The better model would be 16-35/2.8L II, but the cost is high.
Send it back and pray that they will give you an exchange.
Or better, asks for the upgrade: 16-35mm/f2.8L II. This lens will hit you around $1,700.00.
Posted on Dec 29, 2007
Engine makes hissing noise. Valve cover or just a gasket?
Soounds like it to me.... But to be sure, knowing the make, model & year of the car would be a huge help!
Jul 23, 2016 | Cars & Trucks
Canon 60d internal flash wont work. No error message at all. Doesnt work by pressing flash button either, no noises at all after pressing. Thanks
you have to take it out of auto mode to have any control over flash, try putting it in P mode then press the flash button which is next to the flash. if this doesn't work, take it back to where you got it from to take a closer look.
Feb 20, 2011 | Canon Rebel XT / EOS 350D Digital Camera
1997 chevy 1500 makes a gear grinding noise in 2wd when on the gas put in 4wd and it stops
Chalk your tires and have a 3/8 drive ratchet in hand slip under rear end of truck with a flash as well drivers side differential axle their is a 3/8 fitting your ratchet will fit rite in insert the ratchet and counter clock wise loosen out the fitted fill plug using index finer insert and bend your finger if you feel no rear end fluid you will need to top it up this made be the wind gear noise your hearing see owners manual for sae grade.If fluid is full consider the problem will most likely be a transmission problem and is going to be internal and you will need to have the truck hoisted up to properly diagnose the problem so you will might have to consider taking it in to a transmission specialist shop.
Dec 27, 2010 | 1997 Chevrolet K1500
AF problem in CANON 350D
This is a problem with the mirror and the sensor. Have you out the camera in sensor clean mode? turning the camera to P then use the menu buttons to go to the second set of tool. clean sensor is there. You must have a good battery charge for it to work. take off the lens then hold the camera face down and activate the sensor. This did not work for me but this was one of the suggestions, if the mirror does lift back up when you put the camera in sensor clean mode then it is not the hinge that some are paying to be replaced. I took my camera and oddly enough turned it upside down in af mode in auto mode and it started shotting photos and focusing again. i did this about ten shots and when I put it back right side up everything worked fine! Try it and let me know.
Erikka Tiffani
Sep 04, 2009 | Canon Rebel XT / EOS 350D Digital Camera
CDX-S2000 Volume, Source, and Mode buttons not working????
Hey jshaff, try taking off the detachable front, and you will see a reset button, press and hold in for 10 secs, this should solve your problem. if it doesn't work first time keep trying. you must have power to the head unit for this to work. you will hear the cd make a noise and that should be that, try and let me know.
Jun 05, 2008 | Sony CDX-S2000 CD Player
Autofocus not working. 'Ratcheting' noise from lens area...
Sounds as if something is preventing the gears engaging. Service required.
Sep 16, 2017 | JVC Cybercam GR-DVP9 Mini DV Digital...
Hotpoint microwave exhaustive fan combined unit - fan not working
Do you feel air flow? That's the key.
Most microwaves have the exhaust fan assembly at the back edge, not up front immediately behind the grille / vent.
Post back if you can give us more detail or have other questions.
Oct 13, 2007 | Hotpoint RVM1635 Microwave Oven
Only one auto focus point
have you already pushed the focus point button - top right, under your thumb and then push the set button? Pushing the set button will flip between only the centre focus point and all 7.
May 06, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Ice Maker Making Noise
The motor for the auger drive runs pretty slow (about 18 rpm), it could be the drive is running continuously (unless the door is open). Check that and let me know some more info, is the noise real loud, soft, etc. Can you feel anything vibrating or running when the door switch is pressed in?
Nov 05, 2006 | Amana ASD 2624 Side by Side Refrigerator
Canon EF 17-40mm f/4L USM Lens Logo
94 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
