Question about Sanyo DS20425 20" TV
Hi, I need a remote control for this tv. What is the remote control order #. Thank you.
I have sony tv rm-GA010 controller.for lcd tv. but
Hi, you can order a new RRMCGA759WJSA from Replacement Remotes. or you can order the keypad repair kit from replacement remotes to fix your keypad problem. You need the solution that is sold in the kit to fix the rubber keypad for those buttons.
Nov 01, 2013 | Sharp GA759WJSA Remote Control...
Tv code
Buenos Dias, por favor estea necesito de su ayuda Ojala que la ONU su alcanse de Hacerlo, control tengo remoto de la ONU (RCA universales D * 770) y necesito el Codico p?rrafo Este tipo de televisi?n. TOSHIBA 37 " Muchas Gracias.
??? tv-code-wfb10cpomwor51hin1oy0zit-5-0.jpg ??? tv-code-wfb10cpomwor51hin1oy0zit-5-5.jpg
Good Morning, please this need your help UN Hopefully your alcanse do, have remote monitoring of the UN (RCA universal D 770) and I need Codico paragraph This kind of television. TOSHIBA 37 " Thank you.
Jun 10, 2013 | Universal Remote Control Remote Control
What code do I use to program my Dish remote - I have a Polaroid 40" HD TV?
Hi! my name is Kimberly Escobar I'm with DISH Network customer support. Just came across your post and would like to provide you with the information you need. One of the codes you can use for a Polaroid T.V is (627). In order to try to get the remote programed you need to press and hold the clear T.V button for 5 seconds until all the other buttons light up once they are lid let go of T.V button and enter the number 627 followed by the pound key (#). Then the T.V button should flash 3 times after that you can try your volume or powering on and off your T.V. You can find more information and help at Dishnetwork.com this link may be helpful: http://www.dishnetwork.com/SupportSection/power-scan-instructions hope this helps! if you need further assistance please feel free to contact us directly at 1800-333-DISH thank you!
Jan 26, 2011 | DISH Network IR Remote Control
Need Vizio VO320E code to program AT&T remote
hi! i have here a couple of codes for your tv, just try them, 1343, 1489, 1004, 1429, 1433, 1439, hope this helps!!!! goodluck!!!!
Jun 06, 2010 | Universal Remote Control BW056D Remote...
Remote control dosnt work on this tv
I have the same plasma Pioneer tv. I also tried a replacement remote and no fix. I replaced the infrared receiver module (~$4 from Radio Shack) on the TV, yes it involved taking the tv apart. Voila, now I have two working remotes.
May 12, 2009 | Pioneer Televison & Video
Sky remote code
You will need to go to Sky's website and order a new remote if this doesn't work.
Press tv on the remote
press and hold Select and red until the remote LED blinks twice
type in 0 0 6 0
press power button on the remote, if the tv goes off press select and it should control all the tv functions.
if the tv does not go off press tv then power buttons on the remote and keep doing this until the tv goes off, then press select once the tv goes off.
Like I said earlier, if this doesn't work you will need to order a new/replacement remote via Sky's website then put the code listed above in.
Jul 18, 2008 | RCA RCR660 Remote Control
Philips Matchline
Under the flap on the remote control, there are two buttons with a line and two arrows drawn between them, press both of these buttons together and the instalation menu will appear, choose automatic installation and in about 5 minutes the TV will set istelf up.
Jun 20, 2008 | Philips 30PW633R 32" TV
NEED A CODE
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! If that didn’t work, you will probably have to contact the manufacturer to get the code..
Thank you for using FIXYA!
Cheers!
IrishDruid
May 29, 2008 | Televison & Video
Direct tv codes
THE CODE IS 11610 AND IT WORKS!!!! :)
Sep 22, 2007 | One For All URC-3021 Remote Control
Remote control
Without a name, thats almost imposable my friend. Try a Good universal on the manual search. maybe you will get lucky and the remote will work. Good Luck
Jun 14, 2007 | ViewSonic NextVision N4000WP 40 in....
Sanyo DS20425 20" TV Logo
24 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
