Question about Estate TS25AFXK Side by Side Refrigerator
I have an Estate TS25AF that is not cooling down (both freezer and fridge). The fan is running and compressor is trying to kick on. Is this something I can fix or do I need a repair man?
  • 1462 Answers
SOURCE: Refrigerator warm, frost in freezer
take back panel off freezer and check for ice build up which will block air flow and temps will rise. melt off carefully with a hairdryer.make sure drain is also clear and use hot water and patience if blocked with ice. if fault re-occurs, you have a fault with defrost system
Posted on Apr 24, 2007
fridgetech
  • 473 Answers
SOURCE: fridge not cooling
Most of the time on a whirlpool the problem is the relay on the compressor sometimes called the start device. I would replace that first. If you need help finding the part let me know. I will need the complete model # from the sticker inside the fridge section. You can look it up with diagrams at http://www3.sears.com/.
Posted on Nov 09, 2007
  • 105 Answers
SOURCE: subzero 361rfd fridge compressor wont stay runnig
It sounds like you have either a bad relay or a bad compressor. The fact that you hear the compressor try to start indicates that the control is good and there is voltage to the compressor. I would suspect the strat winding of the compressor but a meter would need to be used to determine is this is true.
Posted on Apr 07, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Food and drinks freezing in my refrigerator. How do I adjust?
Inside your refrigerator is a control on left side of the panel. Try to adjust there and try to close the dampers near the lower drawer bins. If that don't work change the temp a little higher in the fresh food compartment. But closing the ducts should do the thing. Let me know, Thanks Sea Breeze
#27 below in pic try ajusting the air coming into fresh food compartment.
seabreezehvac@yahoo.com
http://servicepartstec.blogspot.com/
Posted on Apr 21, 2009
SOURCE: estate tt14ekraw01 it seem like it is runing all
Just kept turning fridge down . It began to cycle and shut off and on like it is suppose to.
Posted on Jun 06, 2009
Fridge is freezing food fan seems to be running all the time
sounds like you may have a stuck freezer control.try bumping that knob with the back of your fist,if it stops,that is it.if not it still may be the problem.let cool down in freezer for 10 min. open freezer door and turn knob back to off very slow,if it kicks off just at off ,control most likley bad.
Apr 16, 2014 | Frigidaire Refrigerators
LG GR-S512GCA NOT COOLING
check and see if compressor is kicking on and off after a few sec if it is you might try a hard start on the compressor its a little switch that goes on the compressor where the wires go cost around thirty dollars be worth a try before going out and buying a new fridge
Jan 27, 2014 | Refrigerators
Compressor works, cooling fan does not, fridge and freezer are correct temp.
Where exactly is this fan located? Are you saying that if you spin it it does start to run? For how long? Tx, Petra
Jun 15, 2013 | Refrigerators
Both fridg and freezer not cooling down. Diconected damper wich was continualy trying to close heard Evap. fan trying to kick on surge surge surge
well u answered ur own question if the evap fan isnt running then the compressor is overheated check the fan and make sure that the fridge isnt froze up unplug it for a few hours and plug it back in and see if it will cool for a while
Jan 22, 2011 | GE Refrigerators
The divider between fridge and freezer is very hot. How can it be cooled down
Clean the coils at the bottom front , behind the bottom kick plate AND pull the refrig out and remove the panel covering the compressor . Once removed , check that the cooling fan ( condensor fan motor ) is not blocked and is running as the compressor runs .
Sep 27, 2010 | Refrigerators
Im having a problem with the fridge not cooling. the ice box works just fine and i have the controls on max but its not cooling down
See if the compressor is running. its under the fridge and will be humming. If its running you fridge and the fan under the fridge is running also then your fridge is low on freon. If the fan is now running replace it. If the compressor is not running it could be the starter which is inside the plastic cap on the compressor. It is a nickel size part connected to one of the 3 prongs on the compressor. It also could be the timer. The timer is a device that turns to fridge defrost. It is located behind the plastic in the top,back of the ref side of the fridge or behind the back in the freezer or under the front bottom underneath the fridge. it will have a slot near its center that a flat blade screwdriver can fit in turn it slowly and you will hear audible clicks the compressor should kick on if not its not the timer. good luck
Aug 12, 2010 | Frigidaire 20.6 cu. ft. Top Freezer...
Fridge and freezer same temp.
First of all, there is only one thing that cools in a fridge and that is the freezer. The fresh food section is cooled by air forced into it from the freezer.
  • You ice maker will not work if the temp inside the freezer is above 5 degrees. It has a thermostat inside it that enables it.
  • The knob that turns the fridge off and on is the thermostat for the freezer.
  • The other knob opens and closes a damper between the freezer and fresh food section.
  • There is a fan that should be running that pulls air from the freezer into the fresh food section.
(The factory does make the discription of the knobs confussing)
Now. turn one of the knobs all the way one way and then the next. If it turns the compressor off, it's the thermostat. If it does not, try the other knob. Once you find the thermostat, set it in the middle of the scale. Now place the other knob the same. Check and see if you can either feel or hear the inside fan running. If so lets go to the back. This is where your compressor is. It is under the fridge and also has a fan that blows on it. You will need to remove the back bottom panel. See if you can tell if the fan is running. Also notice if the fan is blowing into a set if coils. You should also be able to fill the compressor, if it's hot, it's running. If these two are running, and you didn't see a coil at the fan. Take the front kick panel off the fridge and clean the coil that's under the fridge. If it's dirty, give the fridge a couple hours and see if it cools down. If so, this was your problem. If both knobs are set mid scale, both fans are running, the compressor is also running and the coils are clean. You most likely have a bad timer, compressor or thermostat. This is all that's left.
Please rate solution
Sep 16, 2009 | Amana ASD2326HE Side by Side Refrigerator
Fridge not cooling,compressor wont kick in
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
fsdgj
Jun 02, 2009 | Maytag MZD2665HE Stainless Steel Side by...
Frigidaire model FRT21H7AS Not cooling, compressor makes noise
HI, The relay has gone bad and needs replaced. Probably not the compressor. Fairly common problem with these new fridges.
Let me know if I can assist you further.
Vic
May 18, 2009 | Frigidaire FRT21H7AS Top Freezer...
Trio: humming and temp in freezer rising
It sounds like the condensor fan motor is seizing up. This is the fan that cools the compressor down. Does the outside of the fridge feel excessively hot to touch? Can you feel air being circulated under the fridge or behind the fridge? It could also be a faulty defrost timer. Try to identify where the buzzing is coming from and if it is the condensor fan you can put a normal standing fan behind the fridge, blowing onto the compressor untill the repairman can get to you.
Oct 29, 2007 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Estate TS25AFXK Side by Side Refrigerator Logo
240 people viewed this question
Top Estate Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Audie Bogus
Audie Bogus
Level 1 Expert
Are you an Estate Refrigerator Expert? Answer questions, earn points and help others
