Question about Frigidaire FAC124 wall/Window Air Conditioner
Frigidaire air conditioner
Need to know how to get remove front cover so I can slide it out of sleeve.
    Problem Solver:
  • 4 Answers
Remove cover .It might have two screws on the side or just pops off. Pull unit out from cover. if it does't move remove screws in back of unit near condensor
Posted on Dec 29, 2007
How do I take the unit out of the sleeve to clean it?
remove front cover,unplug from wall and slide out of case.
Aug 07, 2015 | Kenmore Heating & Cooling
How to remove front cover of FAX050S7A
Good Morning Friend,
I understand you want to know how to remove the front cover of your Frigidaire air conditioner, model# FAX050S7A. Typically, this is not a do it yourself action, as there are no step by step instructions on how to remove the front cover. I suggest either contacting the manufacturer or your local authorized technician for further assistance. Hope this is helpful.
-Best Regards-
WP
Jun 30, 2014 | Frigidaire FAX050S7A Air Conditioner
Can i take my frigidaire ac out of the case without removing it from the window?
Good Afternoon Friend,
I understand that you want to know whether you can take your Frigidaire air conditioning, model# FRA256ST2, out of the case, without removing the case from the window. Yes you are. Below are step by step instructions for removing your air conditioning from the case.
    1)Unplug your air conditioner.
    2)Take the front grill off.
    3)Remove the filter.
    4)There are four panel screws, two on each side of where the front grill and filter were. Remove these screws.
    5)Gently pull out your air conditioner.
    For replacing your air conditioner, follow the steps in reverse. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer light status has changed successfully. Hope this is helpful.
    -Best regards-
    WP
May 31, 2014 | Frigidaire FRA256ST2 WallWindow Air...
"Check Filter" light is on.
If you look thru the front panel just behind it you will see a spong filter. you will need to access it either by removing the front cover or removing the whole front of the unit . wash it in warm soapy water and replace it . let me know
Jul 21, 2011 | Frigidaire FAA065M7A Air Conditioner
Removal of front cover, so filter can be cleaned
On my air conditioner the filter slides out from the top of the air intake grill. It looks like part of the grill but look closely you should see the seam across the top of the grill. You don't have to take the front grill off.
Jul 06, 2011 | Frigidaire FAH106N1 Wall/Window Air...
Need to remove through wall fedder air conditioner
If it has a sleeve, just remove the front cover and give a little yank on the unit and it will start sliding out of the sleeve. Unplug the unit first, and the unit will slide all of the way out of the sleeve and you can just set it on the floor or wherever.
Jul 06, 2010 | Heating & Cooling
I need the serial number for my Fridgidaire FAM186R2A AC
Yes the front cover is the same as the grille.
You should see the plate with the serioal and model number on the chasis after you remove the grille.
Good luck.
Jan 30, 2010 | Frigidaire FAL126L1A Air Conditioner
Where is Fridgidaire serial number -air conditioner
If you remove the outer cover and look inside there should be sticker with the serial # on it
Jan 29, 2010 | Frigidaire FAL126L1A Air Conditioner
Through the wall vs. window installation
I just purchased an alleged "window mount" air conditioner with the closest dimensions to the existing model. Do these mount as through the wall as well? My current opening = 18 x 26" the new purchase is 16 27/32 x 26.
There are 2 different types of window air conditioners – there are the window type of which will fit in a window that opens top to bottom and there is the slide in model of which the actual air conditioner will slide into a metal sleeve which is very common in apartments. In either case you need to measure the inside of the metal sleeve and then give that to the air conditioner dealer and he will know what to do and there is also a POS (point of sale) @ the store of which will also assist you in the measurement of the A/C unit – the window unit you need to measure the opening of the window itself, I hope this was helpful
Apr 09, 2008 | Frigidaire FAC124 wall/Window Air...
Frigidaire FAC124 wall/Window Air Conditioner Logo
986 people viewed this question
Top Frigidaire Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
