Question about Tech Solution TS-8000 Cross-Cut Shredder
Auto Shut off doesn't work anymore
I lightly oiled the blades by dripping some vegetable oil on the blades. Soon after, the auto-shut off sensor that stops the machine automatically if I don't put anything in the blades after approx 30 seconds. stopped working. Originally it would re-start when I put a sheet of paper in without having to press the on button. The shredder still does it's job great but I miss the auto-shut off and on. (Not to be confused with the shut-off from overheating which I've never had happen.)
I suspect that some of the oil got on a sensor or electric eye. Is it easy to locate this sensor and possibly wipe it off?
  • BLOCKWALKER Mar 03, 2008
    Dear fellowesrep,
    Thanks for the suggestion. Did that and the auto shut off still doesn't work. Looks like I'll have to get it fixed.
    Sincerely,
    BLOCKWALKER
    Scholar:
  • 102 Answers
Though I only work with Fellowes shredders this sounds like a paper feed sensor issue. If your unit has a mechanical paper feed sensor you can try to jiggle it in and out to see if any paper may have become jammed behind switch. If the unit has an electronic sensor it may simply need to be cleaned with a Qtip dipped in rubbing alchohol. Either of these should be located in the center of the paper throat.
If neither of these help your paper feed sensor or your pcAuto Shut off doesn't work anymore - 1.gif board has gone bad and you will have to contact your manufacturer for further parts availability.
Posted on Mar 02, 2008
Auto shut down relay
Oil Light comes on when the Pressure drops below a certain amount. If I was a betting man, I would tell you to test your CRANK SHAFT SENSOR.
Feb 13, 2014 | Chrysler 300M Cars & Trucks
2001 ford taurus Have a constant leak oil light has been on for weeks 3 days ago car would not turn on went to auto advance to get the battery check; replace battery car still shut off, permenantly f
There are some simple kits which have a glowing fluid which can be seen with a UV ultraviolet light supplied in the kit.
You add the glowing liquid to the engine, run the motor, and inspect the drips for the leak location. Then you fix that bad part.
Now sometimes the sending units do leak. But any gasket or seal can leak just as well.
Do not run the engine with the oil light on. Check your oil level constantly. No oil=no engine.
Can not speculate on battery problem from info provided.
Feb 20, 2013 | 2001 Ford Taurus
Oil level and oil temperature are normal. Oil
Same here....I soon had the same problem after changing the oil..Found out after many tests and research that auto parts stores cross reference a lot of audi oil filters to the vw counterparts..Which do fit audi,but are shorter and lack the oil capacity to feed the engine.Then the pressure light pops on!!!! make sure the larger/longer oe type is installed.If your not sure buy it from audi its not much more than the napa brand.
Jul 18, 2011 | 2001 Audi A6
Service engine soon light came on yesterday. oil is full and i changed it two weeks ago
Good Evening, unfortunately it is not as simple as it could be. Servicing your engine usually meant changing your oil or doing a tune up. Your service engine soon light could come on for emission related sensors, transmission related information and otherwise. If it is still running correctly and still feels fine I would not quite worry yet. However I would not hesitate to take it to your local autozone or advance auto parts stores and they can hook up to your vehicle and give you a little print out of what the diagnostic code is stored in the system causing the light to be on. And armed with that information we can help solve your problem. Anymore these lights can come on from your gas cap not being on tight enough or the gasket on it not making a good seal. Hope this helps and anything we can do after you find out what the code is please ask.
Oct 29, 2010 | 1998 Saturn SL
2002 Trailblazer. My oil pressure low dsiplay came on after driving 40 miles, the engine shut down. The oil was changed 1000 miles ago, oil level is fine. What could this be?
could be a few things-(if oil pressure is showing low usually under 20 lbs recheck oil level) bad sensor,oil pump,low oil level ,sludge have truck scanned for trouble code some stores such as auto zone / advanced auto scan for free
Nov 04, 2009 | 2002 Chevrolet TrailBlazer
Car wont start
alot of cars have a auto shut down when they loose oil pressure, if the oil level is good, check oil sending unit ,if it is bad replace it and should solve the problem,thnaks hope i helped,robert b.
Jun 26, 2009 | 1998 Chevrolet Malibu
Service engine light stays on after an oil change
The Service Light indicates that the EMC has detected and problem and needs to be addressed. Your going to have the get the Blazer scanned for DTC codes which could be a simple problem as to a faulty Gas Cap to a bad O2 sensor.
Sorry can not help you more then this but most large auto parts store like Auto Zone will scan your blazer for free and some auto shop charge as low as $10.00 to scan and reset the ECM.
Good luck and hope it's something simple.
May 22, 2009 | 2002 Chevrolet Blazer
Reset service engine soon light
oil change might not have they obd2 tester to shut
the light go to auto parts chain store like autozone
tell shut it up for you for free
Apr 19, 2009 | 1998 Mercedes-Benz E-Class
Oil sensor buzer/light will not shut off 96 cabiro VW
I am not certain, but, most vw's have 2 oil pressure sensors. One is on the head, one down near the oil filter. Maybe the other one is bad..Auto zone or NAPA could tell you if yours has two (2)..
My daughter's '87 jetta DID HAVE the oil pump fail (at ++200,000 miles), it was easy to change, about $150 and 2 hrs and a pair of ramps. Had the oil pump out and in my hand in about 40 minutes.
Sounds like you could just have electrical gremlins under the dash. Have someone (or you) actually put a pressure guage on the oil pressure connection to look for pressure, don't burn up your engine.
Oct 22, 2008 | 1996 Volkswagen Cabrio
Tech Solution TS-8000 Cross-Cut Shredder Logo
518 people viewed this question
Top Tech Solution Office Equipment & Supplies Experts
Marvin
Marvin
Michael Galve
Michael Galve
quennie732
Are you a Tech Solution Office Equipment and Supply Expert? Answer questions, earn points and help others
