Question about Acer Aspire M1100-U1402A Refurbished AMD Desktop PC - AMD Athlon X2 4400+ , 2GB DDR2, 320 SATA II, D
Turns on, cd light comes on but cpu does not boot and light does not come on, the monitor says "no signal" . Cpu dpes not shut off at the button anymore. I have to unplug it to turn it off. HELP! By the way I read to unplug and hold power button for 30 sec then plug it back in, did'nt work. Just want to know if theres something I can do myself or do I have to give in and take it to get repaired.
  • 380 Answers
You should get it repaired. That is likely a power supply failure. Yes, I see you have power, but I still say power supply, because there are 2 types of power: There is Motherboard power and there is CPU power. If CPU power is not correctly flowing, the CPU will not activate. If the CPU is not active, the board will not process any information, even though the board is receiving power. Power supplies are not hard to replace and are usually about 40 bucks
Posted on Oct 01, 2009
Want boot up. Whern you push the power on button, one light on the CPU comes on and all fans come on. There is one beep when you push the button. The CD drive has power. The moniter does not come up. I...
it means machine working fine but display problem check it your RAM check with a soft cloth may monitor is also avilable or check behind the VGA cable proper connect it or not
Sep 23, 2011 | ASUS P4P800-VM Motherboard
The light is on yellowe
Hello Qutey Babe, Hi.... the yellow light means there is no signal from the CPU. check your CPU.
Blue means normal, there is signal coming from CPU Yellow (orange usually). means no activity on the CPU,
Dec 06, 2010 | Acer AL1916W 19" LCD Monitor
Why the monito out sleep why
Pls check whether your cpu is properly booting because your monitor sleeps out because there is no signal detected coming in from the cpu try to connect your monitor to another cpu so that you can determine the proper operation of the monitor...
Jul 17, 2010 | HP W2007 LCD Monitor
Monitor turns on for about ten seconds then the
something like this happened to my comp. once, and it was because my cpu wasn't properly cooled. the fan on the cpu had been disconnected from the power supply. if a cpu gets too heated it can cause a lock-up or reboot, and can eventually damage the cpu. so, that would be the first thing i would check. a virus is also a possibility. if you have virus software try booting from the virus software cd-rom. if you can get into your bios setup by pressing 'delete' during the boot process you can change the boot sequence under one of the options there. put the cd-rom as your first boot device. i use norton's anti-virus, and it allows a scan for viruses before going to the 'desktop'.
of course, if you already have a functional anti-virus program it probably would have caught it without doing any of those steps.
good luck. keep us up-to-date on your situation.
Jan 16, 2010 | Acer AL2216W LCD Monitor
My monitor is not responding to anything. what can i do aside from rebooting?
do you see the light blinking in the monitor? I mean the POWER led light up? If so, then the monitor is ok and is working good. It is your CPU which has a problem and not sending digital signal for the monitor to display.
Try to turn off your computer. After 3 minutes turn it back on. then notice if you will hear a short beep from the CPU. That signals a successful video initialization. If you went through that process, then your computer will get back to life.
However, if you dont hear a short beep from the CPU, then definitely your CPU is frozen therefore there is nothing to display to the monitor.
You need to open the CPU case, pull out memory modules then plug them back in. Then try booting.
If not successful, try to open case and pull out the processor. Put it back in after 30 seconds. Try booting again.
Do ALL THESE while your PC is UNPLUGGED.
Good luck.
Oct 09, 2009 | Computers & Internet
No signal when power button turn on
Sounds like either the power supply unit's fan isnt functioning and the the uniy over heats and the computer then wouldnt boot up (to protect itself) or the processor is overheating. But rather seems like a power supply problem
Jul 06, 2009 | Acer AL1916W 19" LCD Monitor
No signal then orange light on my Gateway FPD1975W 19Inch Monitor
If you have a add on display/graphic card in your CPU then shutdown the system, open the case and try to press the display card gently. Sometimes if the card get loose the display will not come.
If you don't have add on display then try to press the Memory gently after shutting down the PC and try the signal again.
If not resolve let me know whether any beep/sound is coming out of your CPU box?
Rate my answer please.
Thanks.
Jan 04, 2009 | Gateway FPD1975W 19" LCD Monitor
I have a shap lcd computer monitor and when i plug it into my computer and turn the power on, the little green power light comes on, screens back. and after 5-10 seconds the light turns orange and blinks...
It could be your monitor is fine. It simply goes to a cycle when its turned on and does not detect any signal coming from your CPU, it simply goes on standby mode (hence the darker image and orange/blinking light.) have you checked the computer (CPU) part?
Dec 04, 2008 | Computers & Internet
A mind of its own
check the cmos battery and the power suply. lok for swollen compassitors
Dec 30, 2007 | Computers & Internet
NO PICTURE
see there is power in monitor and check also that your monitor is getting signal from cpu just remove the data vga data cable from cpu and see is it showing any massage on screen like check signal or any other massage. and check your keybord also by pressing num lock key see the light is on and aoff when you pressing the num lock button . if nothing is happen that mean your monitor is not getting signal from cpu and it is not monitor problem . bye
Sep 25, 2007 | Acer AL1916W 19" LCD Monitor
Acer Aspire M1100-U1402A Refurbished AMD Desktop PC - AMD Athlon X2 4400+ , 2GB DDR2, 320 SATA II, D  Logo
291 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
