Question about Epson Office Equipment & Supplies
I have a Stylus CX5400 and can't get black to print without mixing blue into it. Tried new cartridges, same effect. On a text document the same lines turn blue everytime I print, the rest prints black. Any input Thanks
  • kirbyfcombs Oct 02, 2009
    I cleanded around the bottom of both cartidges, used several! new black and blue ones but still mixes. It seems odd that the same lines within the text turn blue everytime.
  • Epson Master
  • 419 Answers
You may have a leaky blue (cyan) cartridge that has polluted the black output.
Well worth checking the inside of the printhead (where the cartridges are located) and see if there's a build up of ink.
Also, well worth checking that you haven't received an incorrectly marked cartridge that contains cyan instead of black ink.
May not be the direct solution but it will certainly help isolate a few possible causes.
Hope it helps.
Martin
Posted on Oct 02, 2009
The blue colour has run out but the black is fresh and it won't let me print a black text document-is it possible with out having to go and get a blue cartridge?
The Epson DX4850 will print black only. You can find a check box in the settings to Print Black only in the advanced options.
This works fine for me when all my colours are empty.
Jan 18, 2010 | Epson Stylus DX4850 All-In-One InkJet...
CX5400 Replaced all ink after months in storage
uninstall the printer then reinstall it according to the setup manual.Make sure you are installing the cartridges correctly.Then print a test page form the properties menu
Oct 07, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Epson Stylus CX5400 - Printing is bad even after Head cleaning!
Before replacing the print head on the printer try these steps , and if the printer get long without printing the changes of ink getting dried id high and resulting streaky printing or missing ink on the paper even if the ink is detected by the printer ...
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Jan 09, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Epson CX5400 - use as scanner only?
imy cx5400 prints only part of the page.it also prints so light i can barley read it.When Iprint pictures there are lines all down the picture.
Aug 30, 2008 | Epson Stylus CX5400 All-In-One InkJet...
Printing without color?
Im sorry to inform but yes, Epson ink jet printers require all of the ink cartridges to have ink in them in order to print any color, black and white, or grayscale images. Epson printers contain a permanent print head that needs to be charged with all colors to work. Even when users are printing black text only, a small amount of color ink is used to keep the print head charged for color printing and prevent air bubbles from entering the color print nozzles which can damage the print head. Therefore, once one of the cartridges are expended, the printer signals you to replace the cartridge in order for printing to continue.
May 12, 2008 | Epson Stylus CX4200 All-In-One InkJet...
Epson Stylus CX5400 prints bands of color
directly hooking the printer to mac and windows computer are you getting bandings still? interesting issue... we will isolate it first by trying to hook printer directly to both computer, if its printing fine when directly connected, then there is something on the application or communication process. try printing a different document using same application when on the network and try printing from different application as well. update me afterwards..
Apr 03, 2008 | Epson Stylus CX5400 All-In-One InkJet...
Epson stylus cx5400 reset???
try doing this :
Reclamping the Ink Cartridges
Once you start the ink cartridge reclamp procedure, you must complete all the steps in one session.
1. Make sure the EPSON Stylus CX5400 is turned on and not printing.
2. Press a MENU button until you see CHANGE CARTRIDGE, then press the COLOR COPY BUTTON. The ink cartridges will move to the replacement position.
3. Lift up the unit's cover, to access the ink cartridges.
4. Pinch the tabs on the front and back of the cartridge, and lift it out of the printer.
5. Lower the cartridge back into its holder, then press down on the top of the cartridge until it clicks in place.
Caution: Don't touch the green circuit board on the back of the cartridge, as you may inhibit normal operation and printing.
6. Carefully lower the scanner and press it down until it clicks into place. The EPSON Stylus CX5400 begins charging the ink delivery system.
The On light flashes and the EPSON Stylus CX5400 makes noise. Charging takes about 30 seconds. When it's finished, the On light stops flashing and stays on steady.
Caution: Never turn off the EPSON Stylus CX5400 while the On light is flashing, unless the Stylus CX5400 hasn't moved or made noise for more than 5 minutes.
if the issue still persists - you need to call the vendor - it´s a hardware issue
Dec 30, 2007 | Epson Stylus CX5400 All-In-One InkJet...
The black ink is not printing out
Look at this old post of mine here to see how to effectively clean the print head and unclog the nozzles. http://www.fixya.com/support/t137335-problem_print_outs_from_printer If you still have no joy, try getting a copy of a thing called "Countermeasure for loss of ink" from http://www.TheServiceManualShop.com it should help you further
Sep 13, 2007 | Epson Stylus CX5400 All-In-One InkJet...
Blue lines all over the printing
Did u clean the print nozzle's as well? If that does not solve your problem, you should try and replace the cartridge. (Colour in case of blue lines and black in case of black lines)
Jan 22, 2007 | Epson Stylus Photo 1290 InkJet Printer
79 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
