Question about KitchenAid Dishwashers
Can't find model number.
I have a KitchenAid KUD1230B0 dishwasher, but I can't find that model number anywhere on the web. I'm positive about the number, except for the last character which may be a 0 or an O. Can you suggest a similar model I can lookup for parts and repair advice?
5 Suggested Answers
  • 641 Answers
SOURCE: Kenmore Ultra Wash Model 665 Dishwasher
Dishwashers which are properly installed and regularly used won't normally have a problem with bad odors. Check the following: ?Was the drain hose brought in at the top of the cabinet, or down near the floor? it must be 34" from the floor. ?Do you run the unit at least once every 2 days? -Run a cycle with a quart of vinegar to clean the tub and pump. ?Does the disposal tend to back up slightly when the dishwasher drains? Drain may be clogged. -Don't use gel detergent! ?Check your water softener(If so equipped) These can cause foul odors in the water supply if not properly balanced or maintained Good luck!
Posted on Sep 02, 2007
SOURCE: Where can I buy the cable repair kit for my Kitchenaid dishwasher
OK, pretty easy fix. Look at diagram 10 here: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5164885
The link (#24) probably broke and the spring (#18) probably shot off and is lying somewhere behind the dishwasher. Just pull out the dishwasher (careful not to disconnect or crimp any of the hoses) and check to see if both springs (one on each side) can be located. Just replace the old links and re-hook the springs and all should be well.
You can order the link replacement (part #8194001) from kitchenaid at 1-800-422-1230.
Posted on Feb 20, 2009
SOURCE: 38 year old kitchenaid KDI-16 imperial dishwasher
yep you can just get springs from lowes or home dept or your local hardware store; they're often in with the hardware (i.e., screws) and not plumbing. remember that the springs need to stretch out a bit, too; so you may end up buying springs that look shorter than they should, but they eventually habituate.
Posted on Nov 27, 2009
  • 177 Answers
SOURCE: spray arm doesn't turn
Probably blocked spray arms. Remove each spray arm and check and clean all the holes as this is where the water sprays out from to clean the dishes and glasses. When they are blocked you get poor wash results and the arms don't turn as well
Posted on Feb 06, 2010
Should the KitchenAid dishwasher #kudio1flbl6 door open automatically?
If it does, it's the first time I've ever heard of a D/W with this feature. But read your manual to be positive.
Aug 02, 2014 | KitchenAid Dishwashers
Kitchenaid whisper quiet plus dishwasher
It is likely the thermal fuse is cut off and will need to be reset or replaced depending on the model number of your dishwasher. Please provide actual model number in the comments.
Apr 25, 2014 | KitchenAid Dishwashers
Falls open when? This unit wom't operate unless the door is secure so I assume you mean the door assist springs are disconnected or broken and the door just falls heavily to the open position after you unlatch it from the closed position. Try these, part 18 here
http://www.searspartsdirect.com/partsdirect/part-model/Kitchenaid-Parts/Dishwasher-Parts/Model-KUDI01FLSS3/0593/0130000/W0503111/00007
should attach to frame in an easy to distinguish hole or slot and to door hinges, number 2 here
http://c.searspartsdirect.com/lis_png/PLDM/W0503111-00001.png
Aug 27, 2012 | KitchenAid 24 in. KUDI01FLSS Stainless...
What are the dimensions?
You are missing a digit in the model number. KitchenAid Dishwashers have a number (0-6) after the SS.
The KUDI01FLSS0 installation guide gives the dimensions of the dishwasher opening and the unit itself on various pages. See http://www.kitchenaid.ca/assets/pdfs/literature/Installation%20Instructions%20-%208524480.pdf . The top vent and the front vent KUDI01FLSS model washers are slightly different. The front vent dishwasher dimensions are 33 7/8" H (with the wheels removed) x 23 7/8" W x 24 7/8" D (including the handle). The top vent model is only 24 1/2" deep. With the wheels in their lowest position, the opening for the dishwasher must be 34 1/2" high (from floor to the bottom of the counter top).
I hope this helps. Other KitchenAid appliance manuals are available here: http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=KAD . Use the search box to enter the model number and use the drop down menu to select Consumer.
Aug 14, 2012 | KitchenAid 24 in. KUDI01FLSS Stainless...
Need manual for model # for kitchen aid dishwasher KUDS301XBL2
Could your model number be KUDS30IXBL2? KitchenAide has the manuals for most of their appliances on their support site: http://www.kitchenaid.com/flash.cmd?/#/page/customer-service . Enter the model number or first few numbers and digits and click Go. The direct link to the KUDS30IXBL2 manual in English is: http://www.kitchenaid.ca/assets/pdfs/literature/User%20Instructions%20-%20W10300928.pdf .
I hope this helps.
Nov 16, 2011 | KitchenAid Dishwashers
Need manual for kitchenaid dishwasher model no. KUDG25SHBL
Go to this site and enter your exact model number (the last digit was missing, possibly):
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=KUDS01FLBL
Then you will see a page with diagrams and parts. You will be given a number to call to order the manual.
Good luck, hope this helps, and thanks for using FixYa.
Sep 01, 2010 | KitchenAid 24 in. KUDS01FLBL Built-in...
How long is the wash cycle on a KitchenAid dishwasher?
It depends on the model. It can be anywhere from 30 mins to 1 hr. Then you have the dry time.
Apr 09, 2010 | KitchenAid 24 in. KUDP02CR Built-in...
Spray arm doesn't turn
Feb 06, 2010 | Dishwashers
Kitchenaide builtin - take 20-30 pushes on start button
change the controls you can get at loocal appliance shop take model number when you go
Feb 17, 2009 | KitchenAid 34 in. KUDP01FLSS Stainless...
Dishwashers Logo
110 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
