Question about Garden
Mower takes too long to pick up speed
I have a 48" Bunton walk behind. When I put it in gear it takes several seconds(like 15 to 20) for it to kick in.
I bought the mower used 3 wks. ago, but all the belts are fairly new.
  • bowlmongonty May 11, 2010
    Do you mean for it to start going foward or for the blades to start turning?
  • 67 Answers
Check that the belts are at right tension as they could be sliping slitly and that is why it is taking the time to kick in ,try tightening the belts a bit
Posted on Oct 17, 2009
My scag 48 inch walk belt driven ,is having trouble going up slight hills , already change the clutch springs
I also have a 48" Skag wall behind mower. Have you checked the tension on each wheel's belt when under load? It that where the slippage is, or is there a slow down on the engine itself? If the engine is slowing down...several things to check...needs tune up...plugs...I also use premium gas in my mowers and get better performance. Check all belts for where and slippage. Is it engine or some mech connection?
Hope this helps
Paul
Jun 10, 2017 | Garden
How do I fix the speed control on an Ariens walk behind lawn mower?
do you mean the throttle cable? as its a push mower im gussing it is. If the mower is relatively new then it will be fitted with an opc (or dead mans handle) in which case there is no need for a throttle control as the engine speed is governed and should only be used at the fixed goverened speed
Apr 08, 2016 | Ariens 21 In Classic Walk Behind Push Lawn...
Why did my Lawn Boy Platinum self propelsion quit?
I believe there is a V-belt that drives the front wheels,it may have broken,or the gears in the gear box have failed !
Jun 22, 2014 | Tecumseh Lawn Boy Push Mowers Insight...
Drive gear does not engage
Cable adjustment,broken V-belt, bad gear box.
May 30, 2014 | Tecumseh Lawn Boy Push Mowers Insight...
Why wont my walk behind mower wont start
take your spark plug out put some gas in the chamber replace plug if it fires and not run it is in fuel delivfry check and see if carb. is gummed up if so clean it if not check for restriction in gsas from tank to carb. one of these is the problem
May 23, 2014 | Tecumseh Lawn Boy Push Mowers Insight...
Ariens self propelled hit a rock will not start clanks and smokes Crankshaft does not seem to be bent. Somtimes kicks back when trying to start.
If you have kick back or the mower backfires you probably have a partially sheared flywheel key.
The good news is they are cheap and designed to shear to protect the motor from damage.
You can take the recoil cover off the engine and then remove the nut that holds on the flywheel and gently pry off the flywheel.
You should see a mangled flywheel key that was under the nut holding the flywheel on. Take it to a mower parts store and match it up with a replacement. Put the new one back in and reinstall the flywheel.
That should do it! Good luck and be careful!
Aug 24, 2010 | Ariens 21 In Classic Walk Behind Push Lawn...
Metro walk behind bogging down
the springs that control carby is there leaves or grass stopping it from moving ,some lawn mowers have bad desinge for air flow off ****
Jun 02, 2010 | Encore EXMARK LAWN MOWER HEAVYDUTY STEEL...
Need bunton 48
good luck buton went out of bus a long time ago you can try Jacobsons web site they now own them
Aug 30, 2009 | Garden
Garden Logo
139 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
