Question about Craftsman Convertible 14" Gas Line Trimmer
Routing of fuel lines - Craftsman Convertible 14" Gas Line Trimmer
    President:
  • 1,776 Answers
Typical fuel line routingrouting of fuel lines - 2.gif is:
One line (the one with the fuel filter in the end of it) comes out of the fuel tank2.gif and goes to the bottom fitting on the carburator. The second line comes out of the tank and goes to the bottom fitting on the primer bulb. The third section of line goes from the top fitting on primer bulb to top fitting on the carburator. Hope this helped and best wishes.
Posted on Oct 01, 2009
Hyosung motorcycles fuel line placement
Hi, Kevin for more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Hyosung motorcycles fuel line routing Google Search
vacuum and fuel line routing
2008 hyosung gt250r fuel and vacum line diagram
http://files.hyosungmotorsusa.com/GT125_250_Service_Manual.pdf
Nov 04, 2016 | Hyosung Motorcycles
Tip
Fuel line routing for ryobi,poulan and sears trimmers
hello sir, fuel line routing for ryobi,poulan trimmers, looking at machine from left side,front green line from tank to bottom of port on primmer bulb. rear line from tank which has filter inserted through tank with small white ring pushed up against tank & filter fittings, goes to port at bottom of carburetor.top line from primmer bulb goes to top port of carburetor. that is the way they go on.it is important to make sure you have the same fuel line I.D. and O.D. are very important! also if old line dissolved it will get in carburetor and clog ports & small screen inside.clean inside of carburetor with carburetor cleaner & air pressure. to get your parts and numbers ,go to mtd parts.arinet.com, parts,791-683398,fuel line assembly.hope this helps
.hello sir,routing fuel line for craftsman,homelite, trimmers,fuel tank over engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carburetor fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carburetor fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carburetor fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carburetor when replacing fuel line it is very important to use the same ID and OD line,when the lines dissolve small pieces will get in the carburetor clogging small passages and screen,it is advisable that you clean out carburetor and use a new filter.hope this helps, DON'T FORGET THE 4 THUMBS UP,,,,any comments welcome,thank you.
on Feb 27, 2010 | Garden
Replaced fuel lines,vent line is my major problem!
Make and model please.?
Where is the fuel leaking from exactly?
Generally you don't get diagrams od fueling routes. They often go via the most direct route from tank to carb/primer
May 26, 2016 | Garden
1999 Kawasaki 300 Prairie. Where can I get a diagram showing fuel line routing?
Hi, Gary sorry you can't find the first and best tool you ever bought for your Kawasaki despair not for a mere $10 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
1999 Kawasaki 300 Prairie fuel line routing Google Search
ATV Connection
Where do connect the fuel line that goes from the carburetor to the engine
https://www.tradebit.com/filedetail.php/276766770-kawasaki-prairie-300-service-manual-repair-1999-2002
Apr 02, 2016 | kawasaki Motorcycles
Poulanprop fuel line routing diagram
in 1980 it is pretty much forward from fuel tank to fuel pump from fuel pump to carburetor ....the return line from pump to tank
hope it helps
Apr 06, 2014 | GMC C1500 Cars & Trucks
1992 Honda CB 750 Nighthawk fuel line routing
Hi, Anonymous for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
1992 Honda CB750 Nighthawk fuel line routing Google Search
http://45.63.74.91/cb750-fuel-line.html
Honda 1992 CB750F2 Service Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda CB750F2 Owner Manual
Feb 10, 2013 | 1992 Honda CB 750 Nighthawk
1986 Yamaha Fazer fuel line routing diagram
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $ you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
1986 Yamaha Fazer fuel line routing diagram Google Search Fuel line diagram
Yamaha FZS1000 2001 Service Manual
OEM parts for Yamaha
Yamaha FAZER FZS1000 Owner Manual
Jul 06, 2012 | 1987 Yamaha FZX 750
Fuel line routing for craftsman chainsaw 358.350370
hello sir,routing fuel line for craftsman,homelite,ryobi,hedge and line trimmers,fuel tank under engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carb, fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carb, fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carb, fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carb, when replacing fuel line it is very important to use the same ID and OD line the homelite takes a special line that is black in color and a bigger size,the bigger line is ID .08-OD140 small line ID3/32 X 3/16.when the lines dissolve small pieces will get in the carb clogging small passages and screen,it is advisable that you clean out carb,and use a new filter.hope this helps,any comments welcome,thank you. if the filter has broken off of the line half way that is where you will run out of fuel, hh
Jan 11, 2012 | Garden
Need diagram / pictures of routing of all fuel lines. 1981. CX500 Custom
It's hard to find diagram for older bike.
I got the pic from the tank to pet ****.
LINK HERE
Aug 10, 2011 | Honda CX 500 B Motorcycles
Ryobi Cultivator 410r
The linefrom the tank with the filter goes to the mixture inlet on carb. The fuel return goes to the suction side of bulb. The bulb outlet line goes to the tank. Hopes this helps
Mar 19, 2009 | Ryobi Factory Reconditioned 18" 40cc...
Craftsman Convertible 14" Gas Line Trimmer Logo
552 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
