Question about GE Profile Spectra JGBP90 Gas Kitchen Range
GE Gas Range Over Won't Heat
My GE oven range stove top and broiler are working properly, however, when I try to bake, my oven will not heat up any longer. It simply stauys on PRE for pre heating. Any idea what the problem may be?
    President:
  • 744 Answers
Hello, Yes this is going to be the bake igniter. If you remove the lower panel in the oven you will see the bake igniter. It may still be working when you switch on the oven but it is not getting up to the correct temp in order to ignite the gas. Replace the igniter and you will be all set. If you have any other questions please feel free to comment. Good Luck! Mike
Posted on Oct 01, 2009
My broil HAS NEVER WORKED. top element does not heat up even after the control panel was changed.
Search Results
    Gas Oven Broilers - Do Any Really Work? - Chowhound
    www.chowhound.com/post/gas-oven-broilers-work-923543
    Nov 8, 2013 - but do want to say that I broil in my Breville Smart Oven and it's great.... I have never had a gas stove in any home I've ever lived in, always ...
    Kitchen Basics: How To Use Your Broiler ' The Kitchn
    www.thekitchn.com/kitchen-basics-how...
    Apartment Therapy's The KitchnMar 31, 2010 - Every oven that we've ever come across has some kind of broiler - it's the same device as heats your oven for baking or roasting, after all.
    I have a Kenmore electric range; model 920/9285*. The ...
    www.shopyourway.com > Manage My Life > Questions
    The oven and broiler on my stove won't heat up. Was working ... Having a Oven not working can be rather disappointing as well quite a concern. I have taken the ...
    Top or Bottom Broiler? [Archive] - CookingLight.com Community
    community.cookinglight.com > ... > Food > Popular Threads Archive
    Sep 3, 2002 - 24 posts - ‎7 authors
Jan 27, 2016 | Stoves Ovens
Stove top and broiler work Oven won't heat
the way to check this is to first see if ignitor comes on or put an amp clamp meter on it. the ignitor needs to draw 2.8 amps or more to engage the gas valve. if it doesnt lite or draw any amps at all. check voltage to bake ignitor. it will be the ignitor most likely. but the gas valve or control could be bad.
Aug 04, 2010 | Amana AGR5835QD Gas Kitchen Range
Oven wont bake
sounds pretty simple a bake element
Oct 03, 2009 | Jenn-Air JGR8750 Gas Kitchen Range
GE Profile gas range - stove works, oven doesn't heat
Set the oven for bake. Wait a couple minutes and look in the oven. If you see a orange glow the ignitor is working, but, may need to be replaced.
If you see no orange glow the ignitor definitely needs to be replaced.
Feb 20, 2009 | Kitchen Ranges
My broiler works - but the oven does not - GE Dual Fuel range
Thanks for providing the full model number, which allows us to look up part numbers and see exploded views of your product.
Most likely the bake ignitor is bad (even if it still glows, it may not draw enough amperage to allow the gas safety valve to open). One way you can test this on your model is to swap out the broil ignitor for the bake ignitor, as they are the same part number on your model. (part number WB13T10045) The broiler is normally used much less than the oven, so the part does not fail very often on the broiler. You will have to take the cover off the floor of the oven, then the flame spreader, to reach the burner area. The ignitor is the rectangular part at the back, on the side of the burner. (only two wires to deal with) (By the way, for future reference, your model number ends is SS, as in stainless steel, not a 55)
Jan 15, 2009 | GE Profile JGSP44 Dual Fuel (Electric and...
Oven produces soot when running, broiler ok, stove top ok
Al, you need to seat the needle valve on the bake. Remove the bottom drawer, right below the bake burner you will see the nut just below the air shutter adjustment. Turn this nut clockwise a few times, it might seem hard but just do it. Then try the bake again, you should have a nice bluel flame. Tenbears.
Dec 20, 2008 | GE Spectra JGBP30 Gas Kitchen Range
The oven broiler work but the baking part doesent.
hi thanks for the question I would replace the bottom igniter it has failed thanks the appliance doc
Sep 30, 2008 | GE JGRP17 Gas Single Oven
My oven wont heat up.
can you tell me the model # off the stove. sounds like you may have to replacet the TOD or the heat probe.
Jun 24, 2008 | GE JGBP28 Gas Kitchen Range
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
647 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
