Question about HP Officejet J5780 All-In-One InkJet Printer
When I try to connect to a network printer I get the error 0x00000005 access denied. checked the server, registry, and spooler, nothing seems to be working, im stumped!
  • 17 Answers
SOURCE: HP Laserjet 2600n networking
When you print a test page from the general tab of the printer properties dialogue, it completely bypasses the print spooler. Since your test pages print correctly, this tells us quite a bit. Some of it good and some of it bad.
The Good:
The printers, base driver install, connections and protocols are all functioning correctly.
The Bad:
The printers, base driver install, connections and protocols are all functioning correctly making it much more difficult to pinpoint the problem.
JetDirect printing through the print spooler can be trouble prone with no clear solution. The fact that the 2600n is a host based GDI printer can make it even more so however I still have a couple of things to try.
1-Search for Localspl.dll and check the version number, file size etc. etc. If it is anything other than:
(32 bit x86)
Localspl.dll 5.2.3790.4046 342,016 23-Mar-2007 20:24 x86
Or:
(64 bit x64)
Localspl.dll 5.2.3790.4046 750,080 23-Mar-2007 22:15 x64
then request a copy of this file from Microsoft here:
https://support.microsoft.com/contactus2/emailcontact.aspx?scid=sw;[LN];1414&from=KBHotfix&WS=hotfix
See KB934885 http://support.microsoft.com/kb/934885
for more info. You may want to try the registry tweak there to see if it can help pinpoint the problem as well.
2-Download the latest firmware for the 2600n from HP. There have been at least 2 firmware updates that I know of for this printer. I don't know if any of the updates fixed issues with network printing but at this point it can't hurt.
Firmware: http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=446153&prodNameId=446154&swEnvOID=1005&swLang=8&mode=2&taskId=135&swItem=ly-32271-4
Posted on Jan 16, 2008
  • 93 Answers
SOURCE: operation could not be completed (error 0x00000005)access is denied
Try to refresh or restart the print spooler service and then try to print again.
Posted on May 27, 2008
  • 8404 Answers
SOURCE: im trying to cancel a print job and all i get is
open the print que and delete the job there.
controlpanel, printers, open yours, delete the job.
it may be that you are required to have administrative priviledges to do this. If this is your computer, go to the control panel as an administrator user and change your user settings.
Posted on Oct 26, 2009
  • 38 Answers
SOURCE: print spooler unable to connect tp printer,cable
Print internal configuration page and check for IP address in printed sheet and try to compare with the driver information
Check for LED at network card if it’s on
Try to send ping command to IP address to verify connection and if reply is confirm
Uninstall driver and reload and try to search the printer with IP or hardware address while loading driver
If still any problem it could be network card have problem need to be replaced
Posted on Nov 07, 2009
  • 8404 Answers
SOURCE: How do I cancel print job. I get message access
OPen the printer program, select the jobs and select cancel.
go to the control panel to find the printer program
Posted on Dec 20, 2009
My printer can not print. I tried to follow troubleshoot and restarted the spooler nothing happened. It showed the message that says "printer lost its connection to server" the name of the...
did you already try all the set up of your printer?. you said showed error message lost its connection to server that means you need to re install your printer to access the server. you need the CD installer of your printer then run the software so that your printer can now connect to server.
Apr 12, 2011 | Office Equipment & Supplies
Dec 20, 2009 | HP Photosmart C7280 Laser Printer
HP Deskjet F300 Series Offline
my print is offline, how can I fix?
Jun 08, 2009 | HP Office Equipment & Supplies
Printer error code: 0x000000aa......
this error is because the resource is in use, you need to empty your print queue before you can change ports or settings
May 29, 2009 | Brother MFC 490cw Color Inkjet...
SQL Server does not exist or access denied
check your firewall or the sql server machine firewall.
Jan 06, 2009 | Microsoft SQL Server 2005 Standard Edition
"Error 1068 Could not start the Printer Spooler on local Computer"
HI,
right click on my computer -> select manage -> one should be services and something (or something like that) open that and go to services -> find the printer spool service and right click on it -> click on properties -> in the printer spool service properites click the "Start" button and also under a drop down menu change it from "Disabled" to "Automatic".... This is what you did right ?
Log in to Administrator account and try it there. If that doesn't work then install a fresh copy of Windows Xp. It should work now. Thank you.
Sep 07, 2008 | Office Equipment & Supplies
Operation could not be completed (error 0x00000005)access is denied
This worked for me. Go to control panel, look for printer in the hardware and sound section. click on it. Right clikc on it, and run as administrator. Cancel all documents, and that should be good.
May 01, 2008 | HP Officejet J5780 All-In-One InkJet...
The Good:
The Bad:
(32 bit x86)
Or:
(64 bit x64)
Jan 15, 2008 | HP Color LaserJet 2600n Printer
HP Officejet J5780 All-In-One InkJet Printer Logo
89 people viewed this question
Seeker5211
Seeker5211
