Question about Samsung HCN4226W 42" Rear Projection HDTV-Ready Television
TV keeps turning off.
The time of tv powered varies. Maybe about 15 - 25 mins. When the tv is turn on for the first time, last longer, maybe about 35-40 min, then it turns off and keeps doing it every 15-20 mins. The center light flash like two or three times. And do the same when I try to turn the tv on.
  • Anonymous Mar 16, 2014
    After plugging in tv it no longer turns o green light flashes for a min off then three flashes
  • 4,402 Answers
Could be a couple of things
first i would guess to be convergance ic then IC831S (STR-X6456).and could be loose connection.
you could try this to narrow it down, purchase a can of freeze at radio shock and spray it on these ic one at a time see if it stays on longer or just replace them
Posted on Dec 20, 2007
When tv is turn off and goes to standby it does not have picture when turned back on with remote or tv on off button. the set is 1.5 yers from purchase. what can i do to fix
the low voltage side is weak there is a 5 volt side on the main power this is where standby is and also is used for startup, it sends power to the startup switch if its to low even just by a few volts it may not have the power to turn on the tv fully and take longer for the screen to come on. on the power board check the capacitors there are a few 16v and one or 2 6.5volt types theses maybe weak. if you replace them. they also like to put inferia capacitors in the power board so that it will need repairing so buy a good brand 105c type black or gold type these last far longer and even out the power consumption in the board.
Jan 21, 2014 | Proscan PLDED3273A 32" LED 720p HDTV with...
What do I do when my Emerson TV keeps turning off by itself?
This is probably due to dry solders in the power supply area of the tv... next time when it powers off give it a whack on the side and see if will just light up for a moment.. If it doesn't just open the tv and check for dry solders, loose contacts and faulty capacitors.. PS:I would not task some one without experience in electronics to handle this one. This shouldn't cost you much even if you hire a tech anyway..
Feb 29, 2008 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
TV Samsung WS-32Z308P (Slim-Fit CRT). Chassi S62A. TV keeps turning on and off in a 15 min cycle.
mine had 6 bad capasitors on which i replaced for 3.99 and been fine since.heres where i got my guide from.hope it helps...
samsung smart tv fix YouTube
Dec 03, 2013 | Samsung WS32Z308P 32" TV
Tv turns on by itself
Pull batteries out of the remote control and keep it that way, just to see if maybe power button on remote control is being pressed/faulty. Also check the auto turn-on option of your TV, it might be set to a specific time to power on/off. This would be noticable if TV is powering on at specific time of day.
Nov 26, 2013 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
My tv cuts off then it won't come back on when powered on the power button light just keeps flashing. After unplugging tv for 20-25 mins it will come back on
CRT screens use a vacuum tubes for displaying purposes. These tubes warn off through time and use, with symptoms like colours fading out, late responce on start and even quit doing what they suppose to do.
My solution is to replace the warn tube with a new one,if you really want to keep this screen properly functional, but this could get to much trouble and cost maybe.
Feb 20, 2013 | Televison & Video
Have sound but no picture. Turned TV off last night and when I turned the TV on this morning there was good sound on all channels, but there is no picture. Just a black screen
is hv circuit problem a power transistor to 25KV transformer maybe dead, check the HV Circuit, or 1XXV output from Mains transformer the fuse maybe dead
Mar 11, 2010 | Sony KV-36XBR450 36" TV
T.v will not turn on
Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board. Or, it maybe something simple like a blown fuse inside the TV. But, I can't say it's 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptom.
You have a few choices:
1. You can try leaving the TV unplugged for 30 - 45 minutes so the TV can discharge and reset itself.
2. If by chance the TV is still under warranty, go that route.
3. If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you red light blinking codes, circuit diagrams, test points, and part# lists.Usually, cost under $20. And most cases the new part cost less than $15.
4. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
Jul 15, 2009 | Element Electronics Televison & Video
My Tv is turning off by itself
unplug and let sit for a min then plug back in
Jan 01, 2009 | Televison & Video
Projection TV turns off for a few seconds
Good Day, boattech1;
To my understanding the Model 53UDX10B is a rear projection, that uses no fans. I think maybe your LAMP may be getting weak.
Good Luck, big IRISH.
Jul 20, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Check this, for how long the TV is on? 30 min., 45min, 1 hour? because maybe you have accidentally programmed the SLEEP control. If so, go to the set up options or menu with the remote control and check the status of the sleep power off time. Or maybe the TV has the otion to power off automaticly set the same way that is the alarm turn on.
Jul 12, 2008 | Mintek DTV-373-D 37 in. LCD HDTV
Samsung HCN4226W 42" Rear Projection HDTV-Ready Television Logo
101 people viewed this question
Jerry Greenberg
Jerry Greenberg
