Question about Whirlpool GEW9250P Electric Dryer
Control lock in on
I just changed the control panel to make the digital display work, put the dryer all back together and now the control lock is on. How do I get it to go off so I can use the dryer
  • 1 more comment
  • connieklug Oct 01, 2009
    Dryer control lock on, have held endo f cycle for 3 seconds and even longer, still not unlocking, I've unplugged the dryer and plugged it back in and held end of cycle button for 3 seconds again, still nothing.
    It didn't work. I tried unplugging it and trying it again and it still isn't working
    there is no control lock button, only a light
    Guru:
  • 1,326 Answers
One of these should work for you...
1:Press and hold the "control lock" button for 3 seconds
2:Press and hold the "end of the cycle" button for 10 seconds and the control panel will unlock
3 Press and hold the "Signal" button for 3 seconds
Posted on Oct 01, 2009
  • 10,515 Answers
TO DISABLE: Press and hold the END OF CYCLE SIGNAL button for
3 seconds.
When the dryer is running and Control Locked is on, the
dryer can be stopped by pressing the Pause/Cancel button, but
can’t be restarted until the control is unlocked.
The manual can be found here.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Whirlpool duet dreyer control lock On --can't program dreyer
try unplugging for a couple of minutes and it should reset to factory settings.
Mar 07, 2018 | Whirlpool Washing Machines
My dryer ran through the dryer cycle turned off. Hours later I noticed the "control locked" light is on and the dryer will not even light up to set program.
Hello. I really need the make/model number to help you accurately. However, depending on the model dryer you have, look on the control panel for a button or buttons that have a "key" symbol or the word "lock" underneath. Normally, you would hold the button down for 3-5 seconds until the lock light goes out. This is the indication that the control panel is unlocked and normal operation can be initiated. The manufacturers put a panel-lock feature on the units to prevent "busy little hands" or others from changing settings, for unattended safety, etc. Dishwashers, ovens, ranges, and other appliances also have locks for the control panel. If your dryer initiated a control lock by itself, this would indicate a shorted button on the control panel--soft touch buttons and glass touch-control panels are notorious for doing this. If I have the model number, I can usually provide the part number and/or procedure for getting into diagnostic mode to see any stored error codes(if any) which would help pinpoint a problem. I hope I helped you!
Oct 03, 2015 | Dryers
I have a code of loc coming on and my dryer wont work how can I fix this issue??
The control panel is locked. on the control panel, there will be either a "lock" button that you hold down for 3-5 seconds to unlock, or it will have "lock" in small letters with a line pointing to 2 of the option buttons. hold the 2 buttons it points to for 3-5 seconds and it will unlock. the control lock is a child safty feature that will not allow any the washer to work until it is unlocked. P.S. to put the control panel into the lock mode, is the same way as you unlock the control panel.
May 29, 2015 | Frigidaire ATF6000ES Front Load Washer
The controls locked is displayed. what causes this and how do i get the controls unlocked.
  1. Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to lock the control panel.
  2. Listen for a double beep and observe the "Control Lock" status light is lit when the control lock is in effect.
  3. Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to unlock the control panel. The "Control Lock" status light is goes out when the control panel is unlocked.
Jan 11, 2011 | Whirlpool GEW9250 Electric Dryer
Dryer electrical supply ok but dryer control panel won't come on
If the contro lock is faulty the unit will not start. I think you have identified the problem there.
Please rate my help++++Thanks for using FIXYA
May 17, 2010 | Whirlpool GEW9250 Electric Dryer
My frigidaire affinity dryer displays LOC and will not allow me to press any buttons what does that mean? please help
Hi, "LOC" indicates that the control panel settings are locked. Press the SELECT and OPTION button simultaneously to toggle this 'feature' on or off. Hope this helps.
Apr 15, 2010 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Control panel dead
1. Unplug dryer.
2. Remove 2 screws from rear top of dryer.
3. Lift panel assembly up, taking care to not pull wires.
4. Check plugs on circuit board for panel display. Press each one firmly, but carefully.
5. Put back together, plug in, turn on.
Jun 14, 2009 | GE Profile Harmony DPGT750EC Electric...
Ge adora problem with panel code e01
I'm almost having the same issues but the code displayed is E62. Can you help
Aug 23, 2008 | GE DCVH515EF Electric Dryer
Fisher and paykel clothes dryer ED 54 -U
go back to the last thing that changed..."as soon as I put the unit back together"...what item may have pinched a wire during re-assembly....not saying it wasn't pinched before you started. I am saying there is a possibility of a wire pinched to chassis...an electrical short.
Jun 05, 2007 | Fisher and Paykel DG05 Gas Dryer
Whirlpool GEW9250P Electric Dryer Logo
37 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
