Question about Ryobi Cultivator
I found out that the gas filter inside the tank of my Ryobi 1500 roto tiller has come loose does it go back on the nipple of the rubber gromet it is hard to tell Do I have to take the gromet out
  • 472 Answers
YES IT DOSE YOU MAY NEED TO REPLACE THE FULE LINE
Posted on Oct 02, 2009
Oil to gas ratio of ry60514 ryobi roto tiller?
50 to 1
http://www.manualagent.com/ryobi/ry60514/owners-manual
Apr 02, 2015 | Ryobi Garden
Ryobi RY60511A tiller wont start
when the primer buld is empty, when pushed it should push bubbles into the gas tank and when let go should draw fuel from the tank. the primer buld now when pressed pushes fuel into the carb and should not push back to the tank. when let go again it will draw more fuel from the tank. the inlet nipple on the carb should be the 3 oclock
Apr 11, 2012 | Ryobi Cultivator
Replacing fuel line on ryobi 775r trimmer. when i removed old line and filter, the plastic fitting with the filter protruded about 1/4'' out of tank and was held by plastic retainer ring, now i can get the...
First off, get a piece of fuel line longer than you need for the job. With the gas tank removed, wrapped in a towel and put in a vice to steady it I fed the gas line in from the outside of the tank to through the fuel hole (where the gas cap fits on). I carefully worked the fuel line onto the filter until it was all the way on (touching the bottom of the filter assembly). I then gently pulled on the line feeding it through the hole. Then with gentle pulling, twisting and nudging from inside and outside the tank I worked the fuel filter nipple through the hole on the bottom of the tank until it was flush and secure.. Once the filter and fuel line were secure in the hole on the bottom of the tank, I then worked the secure ring up the fuel line and worked it onto the filter stem until it was snug. I then fed the line through the appropiate holes in the engine, trimmed it to size and fitted it on the nipple on the engine.
Jul 03, 2010 | Ryobi Garden
How do you get the fuel line connected to the fuel filter nipple on the bottom side of the gas tank on the Ryobi 725r gas trimmer?
You must run the fuel line through the back of the tank and out the filler hole,make your connections,i used a small amount of vaseline to make the connections.Then pull the filter into place,make sure some of the nipple of the filter pokes through,then slide the retainer ring on the hose and force it onto the filter nipple.
May 09, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Have ryobi 35 head, does not get gas, everything ok. someone said that the gas tank has a filter clogged or line broken. primer seems to be pulling air.
If you are pulling air and you don't get enough fuel, the filter in the tank may either one that is weighted and is just placed on the end of the fuel line. Or it could be one that is attached to the tank with a nipple sticking through and held in place with a ring around the fuel line and pressed up tight to the tank, over the nipple. There is also the possibility that your fuel line is broken somewhere. If you cannot see the break, it would be inside the tank. Good luck,,,Lee
Oct 07, 2009 | Garden
Replacing fuel lines and filter in gas tank. How do I install new filter intank and connect to new fuel line when I can't reach inside the tank to hold the filter and plug in place while I press the new...
usually you can remove the tank and the hoses run thru a rubber gromet. pull that gromet and the hole is big enough for the filter to come out. makes it easy access. This all depends on the type or tool you have.
Oct 02, 2009 | Garden
I have a roto tiller with carb problems it was
carb needs a good cleaning or probally rebuilding it would be your better choice
Sep 22, 2009 | Ryobi Cultivator
Gas line cracked and nipple fell back into tank ..how do I remove gas tank to replace gas line and nipple????..ryobi 725r trimmer
Empty the tank by dumping into a can or something. Shake the trimmer around until the "nipple" falls out. Get a replacement fuel line and follow their instructions. When yoou put the tube back into the tank, have something that you can guide the line through the hole with. I used a small hex wrench. If you cut the tip of the tube at a sharp taper, it will be much easier to start through the hole. You might think of replacing the return line as well. You should not have to remove the tank if you expose the carb and remove the air filter...Good luck...Lee
Aug 02, 2009 | Ryobi Garden
Replacment gas line and blub,where do i get them for a ryobi roto tiller?
From any MTD dealer. Ryobi is now owned by MTD who also owns Troy Bilt, and Bolens. Most lawn mower shops should be able to get the parts. You'll need the model number off the tiller.
Jun 27, 2009 | Ryobi Cultivator
Ryobi 2 cycle gas trimmer 705r/725r
The gas nipple that come out I have...whats goes in the other hole?
Aug 28, 2008 | Ryobi Garden
Ryobi Cultivator Logo
124 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
