Question about Oster Golden A5 2-Speed Universal Motor Clipper 78005-140
Not a problem, just a question. What exactly is
Not a problem, just a question. What exactly is the function of the "capture plate" that some Oster A5 clippers have under the cover plate?
  • 193 Answers
I assume you mean the thrust plate, it acts as a wearable pad for the armatur to run on these will wear remove and inspect for damage a small hole is a sure sign of wear.
Posted on Sep 27, 2010
What is the Cook funcction button and how is it used?
This link is for FREE online Oster Microwave Oven Manuals
http://kitchen.manualsonline.com/manuals/mfg/oster/oster_microwave_oven_product_list.html
I hope you find your model there. Best of Luck. I love the Cook function button on my microwave - probably similar to mine. This link explains some of the functions of microwaves in general
http://www.which.co.uk/home-and-garden/kitchen/guides/more-from-your-microwave/simple-guide-to-microwave-functions/ Hope it helps...
Oct 21, 2012 | Oster Microwave Ovens
I have an oster a5 clipper. The motor is running but the blades do not move .What can be the problem? What part do i need to buy?
Its possible the gear wheel which is located under the name plate has slipped, if you remove the plate, lever and drive link the gear will pull off.
Inspect the teeth on the gear if there are signs of damage or slipping this is likely to be the problem.
Sep 06, 2011 | Oster Golden A5 2-Speed Universal Motor...
Have Oster model 23-51f fast feed trimmer. Took the blade off havinv trouble putting parts back together namely small copper plate approx. 1-cm long, also having trouble getting the blades to fit together...
We also have these model clippers and have found out that the modelo number has been updated to 76023-510 type in Oster professional products for more info....hope this helps
Sep 22, 2010 | Oster 76915016002 Hair Trimmer
One od the two blade holder screw grommets has come loose from the housing/case. Need to replace. Need parts diagram.
Oster has their own website. Also some areas even have a shop to take your oster too. You might be able to get the screw there or a new plate. For if it keeps coming loose then it might be stripped.
Jan 01, 2010 | Oster 76076-010 Hair Trimmer
Simple question: Are the Oster 76 2-speed, the Oster Crewmaster 2-speed, and the Oster A5 2-speed all the same clipper with different detachable blades?
well the 76 and the golden a5 are almost the same the name plates are different and the 76 uses a toggle switch but the a5 uses a rocker switch. not sure about the crewmaster sorry.
Oct 03, 2009 | Oster Golden A5 2-Speed Universal Motor...
I don't know how or where to apply grease to my oster classic 76
The cover plate is the part with two screws that has the name and other info on it. If you remove the two screws and the plate, you will see a nylon part that moves the blade back and forth--that is the lever. The other end of the lever, with a hole in it, is connected to a metal part called the link. Both parts are easily removed by simply pulling them upward from the device. The bakelite gear is the part that the link sits on (the larger hole in the link). It too can be simply pulled up off the metal shaft that it rides upon (careful not to lose the washer under it). If you don’t have a tube of oster grease, a good white lithium grease is recommended in light application for the gear and the shafts (lever and gear shafts and armature gear and teeth of bakelite gear). Also, the bakelite gear shaft has a hole down its middle and two small holes that lead to the outside of the shaft. The shaft should be filled with grease so that grease can get through those small holes to lubicate the inside of the bakelite bearing. The small pads on each side of the lever (in the case) are oiled, not greased.
Oster clippers, by the way, are known for getting pretty warm. Oster blade wash will help with that, as well as oiling the blades.
Hope this helps you.
Sep 10, 2009 | Oster 76076-010 Hair Trimmer
Oiling
there is a silver oiling nipple next to the name plate depress the centre and oil, also clippers must be greased in the gearbox underneath the name plate.
Aug 30, 2009 | Oster Golden A5 2-Speed Universal Motor...
How to replace adjustable lever on oster clippers
remove two screws securing the name plate, the lever will pull up and off before replacing ensure the felt seals are in place (located next to a metal post). Grease and slide the new oster part into place, refit name plate.
Aug 26, 2009 | Oster 76076-010 Hair Trimmer
Blades do not function
If the power lever (the tab that moves the blade back and forth) is not moving with the blade off, chances are that you have a stripped bakelite gear. Take the two screws out of the cover plate and remove it. Remove the lever. Remove the link (the metal part that the lever connects with). Remove the bakelite gear (the part that the link fits down over). You should then be able to see if the teeth are chewed or worn off to the point that the armature gear will not turn the bakelite gear. If that is the case, replace the gear. Amazon carries both single speed and 2 speed gears under Oster A5 clipper parts.
Good luck.
Dec 20, 2008 | Oster Golden A5 2-Speed Universal Motor...
Oster Golden A5 2-Speed Universal Motor Clipper 78005-140 Logo
143 people viewed this question
Top Oster Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Chuck
Are you an Oster Health and Beauty Expert? Answer questions, earn points and help others
