Question about Bose Lifestyle 12 System
Bose lifestyle 12 no sound is there a fuse in the subwoffer module
  • 3 Answers
Yes there is a 1.6 amp fuse just behind the AC socket.
Had the same problem, changed fuse ok now !
Posted on Nov 09, 2009
  • ajdavies4 Dec 10, 2011
    How do you get the fuse out?
BOse lifestyle 12 Series 2 Bass Module Front panel ratteling how to fix?
happy to help . well its a classic case of over tightnening the screws on the body of the speaker and then it cracks and the ratteling sounds starts coming or they r loose . just glue it down with super glue or tight them as required.
Nov 30, 2014 | Bose Audio Players & Recorders
Bose lifestyle 12 no power
check inside for a blown fuse.also there may be a problem with the board it's self.check to see if youre getting power through the cord and then go from there.check something electrical in the same place you plug in your bose such as a hair dryer and see if that works.if it doesn't check your fuse box for a blown fuse.
May 22, 2012 | Bose Lifestyle 12 System
How to add secon subwoofer to my lifestyle bose system?
You cannot add a second sub woofer to your Bose system unless you are very well versed in electronics and would like to tamper with the internal electronics of the Bose module. Unlike other systems the 6 channel amplifier ( 5 + 1sub ) and its crossover electronics + power supply unit is built into the Bose bass module. The circuit uses very small surface mounted devices with double sided pcb ). And even a professional technician might refuse this work in fear that he may damage the whole unit itself !!!!.
Mar 19, 2011 | Bose Lifestyle 12 System
Hello, We have Bose Lifestyle 12 system. It has been working great until now for 10 years. We moved homes locally with in town. Now when I tried to hook up my system, there is no sound coming out of the...
Please check if the AC cord of Acoustimass module has a good connection to AC outlet, also check all the connections specially the cable that goes to the system control unit jack, for your reference in the link below you can see and download the manual of your Bose system:
http://www.bose.co.uk/GB/en/images/Lifestyle%2012%20Series%20II%20Home%20Theater%20System_tcm6-4071.pdf
Mar 04, 2011 | Bose Lifestyle 12 System
My base module doesn't work anymore , can i replace it with another brand or amplifier
There's a base unit on eBay for bid, currently around $90, expiring tonight at 15:45 PST
http://cgi.ebay.com/Bose-Lifestyle-12-control-system-new-box-w-o-cord-/170595656943?pt=LH_DefaultDomain_0&hash=item27b84b24ef
another $210 Buy-It-Now
http://cgi.ebay.com/BOSE-LIFESTYLE-5-8-12-EXCELLENT-EXTRAS-AND-REMOTE-/260731188231?pt=LH_DefaultDomain_0&hash=item3cb4ca3407
$204 BIN...
http://cgi.ebay.com/Bose-Lifestyle-5-8-12-Music-Center-Near-Mint-/180620466103?pt=Receivers_Tuners&hash=item2a0dd197b7
Bose products are highly proprietary. If they have non-standard connectors from the amp or in the speakers I'd take that as a clue they're NOT compatible with other manufacturers' products.
Feb 02, 2011 | Bose Lifestyle 12 System
My Bose Lifestyle 12 - No Sound
What sound are you putting into the system? Have you checked that the audio you're putting into the system works into some other device? Have you checked that you have the correct input device selected?
If you have checked that the audio going into the system is working properly and you have the correct input device selected then yes, audio in but nothing out = something is broken inside.
Nov 01, 2017 | Bose Lifestyle 12 System
No power
Sounds like the internal 1.6 amp fuse has blown. Its quit easy to change, check the replies I've sent to get access to the unit and the internal fuse.
Oct 04, 2009 | Bose Lifestyle 12 System
No sound from speakers ( lifestyle 20 )
remove the screws that hold the amplifier block to the speaker.the fuses are in the amplifier inside
Jun 14, 2009 | Bose Lifestyle 20 System
Front bose speakers and bass module stopped puttimg put sound
If you're saying you hooked the Bose speakers directly to the Yamaha's amp instead of the prescribed way through their own bass module - they're cooked.
Dec 23, 2008 | Bose Lifestyle 12 System
No output from Bose Lifestyle 12 system
Sounds like you have a problem in the circuits, which of course would take an experience technician to find and repair. But a 1994 electronic item has pretty much reached the end of its expected life cycle (sadly, compared to older equipment which is still working great). Basically, it sounds like the power amp circuit is shutting down a few seconds after startup. Might check to make sure no speakers or cables have shorts, which could activate a protection shutdown circuit. If any of the cubes don't hiss when you turn it on, that would be the first place to look for a problem.
Jul 01, 2008 | Bose Acoustimass 15 System
Bose Lifestyle 12 System Logo
1,023 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
