upgrading/downgrading or installing CFW in PSP is a risky business. the rule of thumb is to know if you have hackable or unhackable motherboard. if you had 5.03 chickhen before, then most likely you have a PSP-3000 or PSP-2000 v3 which has unhackable motherboard. you should have just installed 5.03 Gen-C or CFW Enabler 3.70, or upgraded the OFW to 6.20 and installed 6.20 TN-E or 6.20 PRO-B. 5.50 Gen-D3 is for hackable motherboards like PSP-1000 or early versions of PSP-2000. you have bricked your PSP!!!
for more details, check out sites like pspslimhacks.com, pspcustomfirmware.com or qj.net.
you can update by downloading the latest UPDATE by the playstation site OR before you download any new updates you do know that psp's are hackable?? when you hack it you can play games from your memory stick at no cost!!! NOTe psp 3000's are not hackable!!! theres NO WAY!!! check on the bottom of your psp theres a serial number than it says psp and your current type... of psp if its 1000 or 1001 or 2000 or 2001 you can hack it!! IF YOU want to know how to hack heres my email [email protected] and give me a message on how to hack it!! thank you for reading this i hope it helped you!! PLEAse RATE and make a testimonial!!
Wrong answer. 6.30 is not hackable. But also pandora doesn't work on PSP 3004. So you can't downgrade or hack your PSP. There is really nothing you can do this momment.
You can't for now. You can't dowgrade PSP 3004 because pandora won't work. This version is not hackable. You can sell your PSP and buck a hackable or hacked one or wait till something come out it ever will!
Sorry, but your psp is UNHACKABLE, like mine. Just dont update your firmware, and wait for something to be released for firmware 6.00. On psp 3000's, only firmware 5.03 is hackable. So just wait, and keep checking back at the psplimhacks home page for news for psp3000fw6.00 hacks.
- Fixed a bug when playing within Infraestructure - New system version - Improved the Pops flashing system - New update server.
Just copy the CFWEnabler folder into /PSP/GAME , then go to Games and run the installer
1)INSTALLING 5.03 OFFICIAL AND LOADING CHICKHEN R2
a)INSTALLING 5.03 OFFICIAL
Firstly, you CANNOT do this unless you hava a PSP with Version =<5.03 . To check your PSP FW go to Settings-> SystemSettings-> System Information . If the version is 5.03 , skip thispart and follow the guide below to install ChickHEN . If you have alower version follow this GUIDE in order to install OFW 5.03 .
-Download 5.03 OFW (http://135ff34d.seriousfiles.com) -Connect your PSP to your PC via USB and create a folder in PSP/GAME named UPDATE. -Copy the .EBOOT file in PSP/GAME/UPDATE. -Run the update from your PSP . Now you should have a 5.03 OFW PSP , just what you need in order to load the Tiff Exploit.
b)LOADING CHICKHEN R2
Some useful tips for those who can't get the ChickHEN to work :
-Restore Default Settings -Set UMD Auto Start and Cache OFF. -Make sure you're on 5.03 OFW -Format Memory Stick. ( this will erase all the data from your MSso you'd better backup your files on your PC before doing it )
-Try another method as this video shows : (http://ad452dd7.linkbucks.com) -Don't give up , just try and be patient.
Note that the files needed for PSP 2000 and 3000 series are different than the ones needed for PSP 1000 so don't screw it up.
DOWNLOAD: FOR PSP SLIM ( 2000 & 3000 ) :
-Download ChickHEN R2 Easy to Load (http://0639570b.thesefiles.com)
FOR CLASSIC PSP ( 1000 ) :
-Download ChickHEN R2 Easy to load (http://d249d993.thesefiles.com)
-Copy h.bin to the Memory Stick ROOT . -Copy ChickHEN folder to PSP/PHOTO ( create one if needed ) -Navigate to your PHOTOS folder , and enter the ChickHEN folder.And wait, you will see some images, these will start to loadthumbnails.Go all the way down to the last image. Your PSP may freezeand reset. Just keep retrying and ChickHEN R2 will load up….But if yousee flashing colors, your PSP will reboot loading the ChickHEN.
For those who can't load the ChickHEN files check above for useful tips and remember to restore default settings.
Check your PSP's version to make sure. If the version is somethinglike 5.03 ChickHEN R2 you should be fine and ready to install CFW.
2)INSTALLING CUSTOM FIRMWARE
Do NOT try this on any PSP 3000 or PSP 2000 unhackable mobo's this is only for PSP Phat and 2000 hackable series. This will permanently install CFW onto your PSP ChickHEN must be enabled.
-Download Recovery Flasher 1.60 (http://926291d9.thesefiles.com) -Download 5.0 OFW (http://a3b04c08.thesefiles.com) -direct download -Copy the Recovery folder to PSP/GAME . -Also copy the 5.0 official update renamed as 500.pbp to PSP/GAME/RECOVERY folder . -Go to GAME and run the program and install 5.0 M33-6 !
In the end , press SELECT while in XMB and change UMD Iso Mode to''M33 Driver'' or ''Sony NP9660''. I also recommend formatting memorystick. Place your CSO/ISO games to the ISO folder on your memory stickroot.
GUIDE created by : PSPgamen OF AFTERDAWN Any questions ? probs ? post here ! Enjoy :)
