Question about HP Pavilion zd7000 zx5000 zv5000 presario 3000,R3000 Series 120W Laptop AC Adapter-360699-001 CD-ROM Drive
Trouble with running a secondary monitor from my laptop
Im using a HP pavilion zd7000 and i cant seem to get my external monitor working with it, i have had the monitor working from my laptop before so i know its not the monitor, i have tried the trouble shooters but still no luck, can anybody help?
  • tonyphats Dec 27, 2007
    Thanks for the reply.
    for the past two weeks all i had to do was plug in my monitor directly into the back of my laptop and then turn my laptop on, most of the time the monitor fired up and worked normally on start up, i didnt even have to hold the 'fn' + f5, if it didnt work, i would right click on my desktop, click on properties, then settings in the display properties box and tick on the box that says extend my windows desktop onto this monitor and it sorted it.
    Now it just doesnt seen to want to work, i know there is a connection between the laptop and monitor because the monitor will come out of standby when i have told the laptop to allow the extension of the desktop to the monitor but the screen stays blank,,,,?
    any other suggestions?
  • 32 Answers
Hello tonyphats,
How are you trying to use the monitor? Just connecting it to the laptop? I know on most laptops you have to select to use the external monitor it won't just come up. You usually have to hold down the 'Fn' button and then press 'F5' or 'F7' to toggle between - monitor only, monitor and lcd, and lcd only.
If you are trying that, what happens? Does anything show on the screen?
-Chester
Posted on Dec 27, 2007
  • Chester Gould
    Chester Gould Dec 27, 2007
    No problem,
    What operating system are you using? Sounds like XP, it's good news that the monitor goes out of stand-by, that means that it is most likely a configuration problem.
    When you go to properties now, is the extend desktop to this monitor option available? What about the option that reads; identify? That will usually flash a number on the monitors to let you know which one is which.
    Does your monitor show up in the device manager? You can view that by; right clicking 'my computer' on desktop, select properties, select hardware tab on top, click Device Manager button, click Monitor +... does it only show your LCD or is your other monitor there too? If your other monitor is there, then I bet it is the problem I mentioned originally.
    Even if the monitor is unplugged, the option is stored on what to do with a monitor by default when it is plugged in... so if by accident the option to switch back and forth between lcd + monitor was pressed it may save that so it wouldnt work automatically the next time you plugged it in. Do you know how or what buttons need to be pressed to toggle between extended desktop, lcd only, monitor only? I think HP is different, but I can't remember off the top of my head.
    Also, what type of monitor are you using, through researching I found a lot of people have had similar problems to you, and found out that their monitor was broken. You said it just worked before, do you have another pc you can plug it into to verify it is working now?
    -Chester
Using notebook display and external monitor: HP Pavilion zd8205us primary display is garbled, secondary display is clear and good, It doesn't matter which display device you set as primary or secondary
try to switch the blue VGA cable that is connected from the laptop to the external monitor. You may also restart your laptop and set aside the external monitor to check if the laptop is still experiencing garbled display... If it still is, then it is a monitor issue and need to address to HP personnel by calling HP hotline. Otherwise your issue will be resolved by simply doing that..
Nov 14, 2010 | HP Pavilion zd8000 Notebook
HP Pavilion zd7000 lap top Power on issues
I just built/repaired one of these the other day. My son uses it now. Motherboards are notorious for going out. However you need to give more description to your problem. You just say it has issues but that doesnt really tell me anything. If you turn it on and get no beeps and no screen and everything seems dead except for the power light then it needs the system board replaced. But if you see the hard drive light running like normal with nothing on the screen then try it with an external monitor. If the external monitor works then the screen has died but the motherboard video card components are good. If you still got nothing then the board is bad and will need replaced.
I'm sorry it is almost always bad news on these.
Apr 22, 2010 | HP Pavilion zd7000 zx5000 zv5000 presario...
Problems with video HP Pavilion ZD7000
memory problem, screen frozen or something disturbing is on block(Like drives) My be the memory.
Jan 03, 2010 | HP 336084-6C0 - HP Pavilion zd7000...
I have an hp Zd7000 that wont start i can hear it trying to.
Did you try the FN+screen switch key. maybe check to see if nothing is loose ( hdd, ram ) also the bios to see if screen settings are correct
Oct 01, 2009 | HP Pavilion zd7010us PC Notebook
HP Pavilion notebook's screen is too dark to see!
do u have a external monitor,connect it up and see whether,u r output is any better..
Jul 22, 2009 | HP Pavilion zd7000 zx5000 zv5000 presario...
On/off switch on zd7000 laptop
That fans is not fited in your laptop once again cheak the fans settings and virfy the your switch
Jun 15, 2008 | HP Pavilion zd7000 zx5000 zv5000 presario...
White screen zd7000
You still might have a problem with your connector. It might have a cold soldered joints. Try to power on your laptop with no keyboard cover in the way were you can have an access to the place where cable is connected to your motherboard then try to wiggle it a little. If your video is coming up and down, you have a cold soldered joints. Another considerations would be:
1. Your LCD cable
2. Your LCD goes bad
Regards.
May 27, 2008 | HP Pavilion zd7000 Notebook
HP Pavilion zd7000 zx5000 zv5000 presario 3000,R3000 Series 120W Laptop AC Adapter-360699-001 CD-ROM Drive Logo
149 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
