Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
Cleaned gas and changed fuel filter. Mower only
Cleaned gas and changed fuel filter. Mower only runs with full choke on. Stalls without full choke.
    Scholar:
  • 110 Answers
There are a number of things that can cause this, depending on the engine fitted. Assuming a Briggs & Stratton V-twin...
Check that the carb solenoid under the float bowl is connected, has battery voltage when the ignition switch is at 'RUN', and is functional.
As a quick check, with the engne OFF, turn key to 'RUN' there should be an audiable 'click' from the carb if the solenoid is working.
After that, check that the fuel pump is delivering fuel (disconnect output, and crank engine). SHould be a good flow.
Posted on Oct 01, 2009
Hi, I have a 13.5hp Briggs & Stratton motor which starts and will only run on choke slow rpms and mild smoke.
check the point where the fuel hose goes to the fuel tank
there is very fine filter in the hose that could be blocked preventing full fuel flow
only running on choke indicates insufficient fuel flow
Apr 02, 2017 | Briggs & Stratton Garden
Lx288 mower quit running I thought it was out of gas so filled with gas started up but wouldn't keep running.
  • If unit will not run without choke , the main jet in carb is clogged and the carb needs to be cleaned out.
Nov 07, 2015 | Garden
Runs for 10 min and stalls.
check your vent hole on fuel cap,or just loosing the gas cap so it can get air if this helps than you know it is the vent.
Aug 12, 2015 | John Deere Riding Lawn Mower. EZtrak Z225...
Have a Zero Turn mower (50 inch deck), engine will only run with choke full on and bogs down or stalls when demand put on engine ie. mowing in high grass. Changed filters (fuel and air) with no change in...
You have a lean fuel condition. This means your carburetor is clogged. By turning choke on you are changing the air/fuel ratio in the carb. You will need to bring this in to a good repair shop to have the carb cleaned.
Aug 01, 2013 | Garden
I have a murray push mower 6-22271 briggs straton 4 hp. it start and then stalls . filter clean. choke fully closed when control is in full forwrd run/choke position. I pour gas in the throat and pull...
Your carburetor needs cleaned. It is dirty/has debris in it. If it has a bowl that is. If it has a diaphram (carburetor mounted on the fuel tank), replace the diaphram. They go bad.
I hope this helps get you going.
Jul 28, 2011 | Garden
Stalls after 20 mins. of running fine. (Starving for gas)
From the rear of machine look at the top left of fuel tank for the fuel line.Where line comes out of tank see if it is pinched where it goes down between frame and tank,grab line and see if it moves freely.If that is OK loosen fuel cap after 10 minutes of run time to see if your vent hole in cap is working.These are 2 common problems for the L series mowers.
May 22, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Engine only runs with choke full on. Dies when off full choke.
Hi Dave, it sounds crazy, but try this. Check your gas cap. It could be clogged, causing a vacuum to occur in the tank, and therefore not allowing the carb. to take on gas. It usually take 10-15 min. for this to occur. The next time you run the mower and it starts to stall out, loosen the gas cap and see if it begins to run again. If it does, then you know that the gas cap is clogged.
Jim
Jun 04, 2009 | Craftsman Garden
Cub cadet lt1050 poor running
when you cleaned the carb was the needle replaced. also what is the compression on this engine. if a unit has low compression they will sometimes only run on full choke. is there good fresh gas in this unit. No water..(if in doubt trow it out)
Mar 10, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
354 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
