Question about Yamaha TSS-1 Computer Speakers
I can't seem to get the speakers to work when
I can't seem to get the speakers to work from my yamaha tss-1 home surround when connected to my samsung desktop. I have an auxillary cord to connect the speaker box to the computer, do i need a different cord? i'm also not 100 % sure on where it should connect. Thanks!
3 Suggested Answers
SOURCE: paired with my laptop but no sound comes out of the speaker. my laptop still plays throuugh its own speakers.
Although I have a different model, I was having the same problem. By right clicking on the speaker icon next to the clock in the icon tray you'll get different options. Click on 'Playback Devices' and then you'll see all the speakers that are active. In my case, the default speaker was set to be my laptop speakers (you can see this because of the green dot). By simply changing the bluetooth speaker to be your default speaker (by right clicking on it) you'll hear sound again. And when the blueetooth speaker is disconnected, the laptop use your 'secondary' speakers, that is, your laptop speakers. Hope this helps!
Posted on Oct 10, 2009
SOURCE: Yamaha YST-MSW10 subwoofer quits after about 10 minutes
This problem can be solved by either of the following:
1/ Modify the PCBA to prevent the auto shut off feature from working. This is done by adding a 20k ohm resistor across pins 1 & 2 on the timer IC6. This resistor will prevent the timer from turning off the amp. To do this, unplug the amp. Remove the 8 screws on the perimeter of the rear of the amp. Carefully remove the rear plate. Disconnect the speaker wires at the speaker and the front panel connection on the main board. Locate IC6 on the bottom of the main board. Solder a 20k ohm resistor (1/4W) across pins 1 & 2. Pin 1 and Pin 8 are noted on the board. Be sure to insulate the leads of the resistor to prevent contact with the board. See picture. Re-assemble in reverse order.
2/ Some 5.1 channel amps allow independent control of the volume for the subwoofer in their setup. Check your amp to see if you can raise the signal level going to the subwoofer to prevent the amp from shutting off. You can then dial back the volume of the subwoofer using the volume control on the front._436.jpg
Posted on Jan 08, 2011
Will a panasonic tv work with a yamaha surround sound system
Yes, any TV will work with any surround system. It all depends on how you wish to connect them together. That all depends on what kind of inputs/outputs you have on both the TV and the amplifier. Too difficult to advise without being there and having the operating manuals for both the TV and 5.1 system.
Aug 21, 2014 | Yamaha 5.1-Ch. Surround Sound Home Theater...
How do I connect Samsung smart TV to a Yamaha receiver and get sound to come out of surround sound speakers?
Generally you will connect the Digital audio or optical audio cable from TV to the input of Receiver. Then using the remote control of Receiver you will program the source for digital audio or optical audio as TV. I am assuming the speakers on the receiver are already connected and working. All you do is then turn on TV and turn on Receiver and select TV on Receiver. The TV audio will play through the receiver. Make sure the TV sound is in Mute.
Aug 07, 2014 | Yamaha Audio Players & Recorders
Surround problem with Yamaha HTR-5930 5.1 Channels Receiver
The signal that comes from most tv's via the optical output is a stereo signal only. That is what your receiver is reading. You would have to manually set your receiver to decode the signal into surround,.
Apr 18, 2013 | Yamaha HTR-5930 Receiver
I just bought a Yamaha 5.1 system with rcvr RX-V365 i have HDMI to tv then HDMI to RCVR then another HDMI to DTV. Problem cant seem to get picture AND sound together through RCVR. depending on what setting...
RX-V365 doesn't support sound over HDMI. It can switch the video+audio from HDMI in to HDMI out, but can't play the sound through the speakers. You need to connect the audio separately via optical or coax digital cable.
Mar 19, 2010 | Yamaha 5.1-Ch. Surround Sound Home Theater...
Lux Audio 5.1 home theater speaker & Yamaha HTR 5540 AMP
configure ur PC (both OS audio and third party sound driver) for surround sounds. control panel- sounds and audio devices - speaker settings - advanced - speker settings. so this done. make sure u select the 6 input channel - the button is on the right edge near the volume knob. near the vol button there are two buttons for selecting input type with up down arrow. from that u can select the input type this will be indicated on the top front indicator. but with the 6 input channel selected all selections are preceeded. if u select stereo mode u will have left/ right audio only.
make sure u connect the input right. connect from computer to 6 channel input. main, surround, center and sub-woofer.  connect the spekers to main (L/R), rear(surround) (L/R), center and sub woofer to terminal marked sub woofer ouput. this done select like i said before the 6 channel button. that should do it.
Mar 13, 2010 | Yamaha HTR-5540 Receiver
Left surround channel don't work
the problem you have seems to be on programing the master effects to get to it go to main menu and see the distribution and effects you want to hear on you home theather.remember that home surround needs some decoders to send the sound where the images come and its right built in....
Nov 17, 2008 | Denon AVR-887
Center channel quit woring
The center channel amplifier in the main unit isn't working. Check the warranty. If it's still in force Yamaha will fix it free. If out of warranty, they'll give you an estimate.
May 15, 2017 | Yamaha Audio Players & Recorders
Yamaha TSS-1 Computer Speakers Logo
29 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
