Question about Napoleon 36" Zero Clearance Top/Rear Vent Natural Gas Fireplace with Black Door
Nothing happens when we flip the switch, though the pilot light is on.
  • 73 Answers
Is the gas valve turned to ON position?try to jump the top and bottom screws on the gas valve, there are 3 in a row there inside the bottom door on valve. use a small wire to jump it no risk of shock its milivolts and you wont even feel it. if unit lights you have a swich problem or wire problem
Posted on Feb 06, 2010
Model mgh-055 furnace. Why won't it light?
Pushing down the button causes enough gas to be fed to the pilot to allow it to be lit and remain burning. If nothing happened, the gas valve could be at fault.
Sep 20, 2015 | Heating & Cooling
Lights flip up when car starts,never go's down
sounds like your on off switch in vichle is not working correctly as it may be stuck in the on position even though you switch it off. I say that only because there seems to be power on the light motor all the time and when you start the car they flip up> find the relay that goes to the motor off the lights it could also be that the relay is stuck in the on position. when you switch your lights on you should hear a click noise come from the relay if you dont then it is possible that it may be burnt inside> easy way to cheack is to start the car and remove one fuse at a time if nothing happens replace the fuse and do the next one until the lights close. all you will be doing is removing power off the relay, when you find the one that is powering that motor remove it and replace the relay
Sep 05, 2013 | 1981 Chevrolet Corvette
1981 c3 headlights flip out when car is started,but will go down
49de7c30-fce9-4e27-ae89-f6cfe5dc93d3.jpg Sounds like your on off switch in vichle is not working correctly as it may be stuck in the on position even though you switch it off. I say that only because there seems to be power on the light motor all the time and when you start the car they flip up> find the relay that goes to the motor off the lights it could also be that the relay is stuck in the on position. when you switch your lights on you should hear a click noise come from the relay if you dont then it is possible that it may be burnt inside> easy way to cheack is to start the car and remove one fuse at a time if nothing happens replace the fuse and do the next one until the lights close. all you will be doing is removing power off the relay, when you find the one that is powering that motor remove it and replace the relay
Sep 05, 2013 | Cars & Trucks
Have a Reznor propane heater, suspended, the pilot light ignites, though the ingniter runs continuously, thepilot light burns for about 2 minutes then everything shuts off, never ignites the main burn
First clean the flame sencor if fitted jump out the pressure switch see if thhelps , Also there are two snap discs high and low temp try jumping these out 1 at a time .
Mar 12, 2013 | Heating & Cooling
Element on light on ... Nothing is on
This happens when one of the infinite switches short out. The indicator lamp will remain on even though none of the elements are heating up. To figure out which one is defective, gain access to the rear of the switches and remove the wire going to terminal P (Pilot) Restore power and see if the light is out now. Keep doing this to the remaining switches until you find the one where the light stays out with the wire removed after power is restored. Supply model number and we will supply the part number for the infinite switch. Be sure to let us know if it is the 6 or 8 inch burner switch. Good Luck and be careful. Eric
Mar 23, 2012 | Frigidaire Cooktops
Hi, I am a caretaker in a 12 suite apartment block. The building has an old gas-fired hydronic Weil McLean boiler (maybe 10-20 years old). The gas pilot switch was regularly flipping (about 2 times at...
IS ANYONE CHECKING GAS PRESSURES? A BLOWING PILOT COULD BE UNSTABLE AND LIFTING OFF.IF IT IS WIND RELATED TRY A PIECE OF TIN FOR A "WIND SHIELD" AROUND THE PILOT
Jan 05, 2011 | Heating & Cooling
Pilot turns on but when I switch to turn it on,
When you light the pilot, are you holding it down for 30-60 seconds. When you release the pilot button, does the pilot flame stay lit? Or does it only go out when you turn the knob to on position. Make sure the pilot flame is heating the end of the thermocouple and that it's a strong blue flame, not a lazy yellow pilot flame. Make sure the tip of the thermocouple is not burn't off, which usually happens with lazy yellow pilot flames. Replace thermocouple is nothing else works.
May 13, 2010 | Coleman 5040-751 BackHome Open Flame Patio...
I have a Intertherm heating and air conditioner it is a Manufactured Home. The furnace model number is E2EB-017HA. When you flip the switch to heat and move the control arm up nothing happens. You can go...
When you turn the on/off switch to on you are turning on the "fan switch" and the blower motor is only coming on. When you turn the switch to cool and move the tempature control lever down you are turning on the air conditioner...So it sounds like your heater is not working. Is the heater electronic ignition or does it have a pilot? If it has a pilot the heater may not be working because the pilot is out and will need to be lit. If it is electronic ignition you will need to inspect the unit to determine what component is faulty. Could be the igniter,gas control valve,ect. Verify that gas is not shut off to unit at line valve and gas control valve on unit.
Oct 07, 2009 | Intertherm Heating & Cooling
I have an older Maytag D8512 with an electric igniter. When I push the start button, nothing happens. I checked the pilot light and it is off. I used a long matchstick to see if I could start the pilo
there is no pilot light. electric igniter will glow and pull amps allowing gas valve to open. if you do not see igniter glow it is bad or thermal fuse has blown. look for 120 volts at the igniter when running. if voltage found bad igniter, if no voltage trace back to fuse/stats.this assumes dryer is actually running. if drum not turning could be a number of things. door switch, fuse, etc
May 24, 2009 | Maytag Dryers
Patio Heater pilot lights won't stay lit
crappy pilot flame (not properly heating the thermocouple), bad thermocouple, thermocouple loose where it screws into the pilot safety valve, bad safety valve magnet.
One or more of those is the problem.
Oh...there is also a saftey switch...in case it tips over. It will also cause the pilot to not stay lit (if the switch or wires that go to i are faulty)
May 30, 2008 | Coleman (5040B750) Patio Heater
Napoleon 36" Zero Clearance Top/Rear Vent Natural Gas Fireplace with Black Door Logo
236 people viewed this question
Top Napoleon Pool & Spa Experts
Paul Carew
Gene Haynes
Dan Webster
Dan Webster
Are you a Napoleon Pool and Spa Expert? Answer questions, earn points and help others
