Question about ATI Asus P4R800-V Deluxe Radeon FSB800 Prescott Ready Motherboard (MOTAS30)
MY Mainbord has P4R800-V With VIA Chipset and I haven,t CD Mainbord. please help me. are you here?
  • 2,351 Answers
All your drivers that come on the CD is at this link:
Fill in the information on the right. For your Asus P4R800-V Deluxe, fill the three lines as follows:
Please Select the Product
P4R800-V Deluxe Click search.
Posted on Dec 20, 2007
ASUS P4P800S-X SATA problem
It could be a bios thing have a look a there for a option to chage from IDE to SATA
Mar 31, 2012 | Intel ASUS P4P800S-X 848P Socket 478 DDR...
Mother board masi km4am-l H.D.D. 1 TRA WES 64MB when installing win xp hard not detected by win setup. I updated bios but not worked. advance thanks
you should not update the bios...the issue is the hard disk is on sata ...and you need a raid driver installed to detect the ...either get into BIOS and under advanced features..look the place where the drives are detected..and select the hdd and look for a feature called AHCI ..and disable it ..and leave sata like ide..and save with f10 and restart ...after that the hdd will be seen ..
another way is to make a floppy disk with the raid driver on it (the one from the mothermoard drivers disk ) ..and when it ask you to press f6 for 3rd party software it ..and insert the floppy will pick up the raid driver and will go like a charm ..
if you do not have a floppy ..install a second cd drive ..and use a cd ..and after pressing f6 for 3rd party ..browse and point to the raid driver on the mobo driver cd ..
Jul 15, 2011 | MSI KM4AM-L VIA KM400A CHIPSET ULTRA...
I have hdd sata and i want to setup win xp on it my motherboard is MSI (MS-7104 VER:1.0)
The Windows XP installation CD does not have a SATA driver. Please click on this link and follow my instruction for Windows SATA installation :-
Aug 16, 2010 | Computers & Internet
AcerPower 1000 (AP1000EA380M) PC Desktop: i cannot install win xp on acer power 1000...
Hi! Try to go to bios menu via F2 or del while system is starting up.Go to sata operation, change IDE to AHCI or vice versa, save settings then try to reinstall os(win xp) again via booting to the disc (F12) and choose cd/dvd or odd...hope this helps...Cheers!!!
May 18, 2010 | AcerPower 1000 (AP1000EA380M) PC Desktop
Ms 7142 Msi board, cant install xp with sata hdd
I think this is your board, K8MM-V. The following is the link to all drivers and info regarding said mobo:
Dec 30, 2009 | MSI K8MM-V Motherboard
M/b cannot recognize SATA HDD
This is common to other mainboards, the SATA controller have it's own BIOS, but it only works correctly using two identical SATA HD's at same time for data protection purposes. If you have a free PCI slot there are expansion cards based on VIA chipset VT6421 with 2 internal SATA ports, other external and one IDE. See one here
May 11, 2009 | MSI K8MM-V Motherboard
you need your windows xp disc preferably slip streamed with SP 2 or SP 3 and then you should be able to install it onto your sata hard drive.
If you are having issues then you may need to extract the sata drivers onto a memory stick or floppy disk and press F6 before windows xp loads and specify to use the sata drivers which you can download from the motherboards manufacturers website generally as a zip file which you will first need to extract into a folder.
If that does not work using the memory stick you can use nlite to slipstream the drivers with your windows xp disc :
Nlite download
if you need more help post back
Apr 11, 2009 | Mercury KVM800M Motherboard
Problems Installing my 160 GB Seagate SATA HDD
Check the SATA/RAID controller setting. It could have been set to [Disabled] Refer to your user?s manual for a detailed description on how to enable the onboard SATA/RAID controller by adjusting the jumper or BIOS settings. Regards SparkGap
Sep 24, 2007 | ASUS P5RD1-VM Motherboard
Samsung sata hard disk detection problem while windows setup
Hi, Typically, Windows XP installer does not provide full support for SATA HDs (drives) nor for all kinds of SATA Controllers (on the motherboard or add-on card). However, Windows XP installer provided a way out by prompting the user to press F6 and load the necessary drivers in the FDD. The diskette containing the drivers may either come from: manufacturer of motherboard; manufacturer of controller; or manufacturer of HD. If none was provided nor available, then perhaps you can DIY (do-it-yourself). More often than not, it is inside the MB installer/driver CD in D:\Drivers\SATA or something like that and copy to a floppy diskette. Alternately, you can download from the manufacturer's website, decompress and copy to FD. When the Windows XP installation CD puts out the message "Press F6 if you need to install a third party SCSI or RAID driver", press "F6" as instructed. Thereafter, press "S" to specify additional device on the next pop up screen. Insert the driver floppy disk in and press enter to continue. If the floppy disk is made successfully, the installation program will ask for selecting driver. Please then select "Motherboard chipset (VIA, Intel etc Serial ATA RAID Controller(Windows XP)".) After the SATA driver loaded, Windows XP will now recognize the SATA HDD, proceed and continue to install Windows XP. If you do not have a FDD, one of your option is to DIY a slipstream WinXP installer CD. This is better explained in this article . Hope this be of some idea/help. Pls post back how things turned up or should you need fur4ther information. Good luck and kind regards.
Sep 22, 2007 | Computers & Internet
Downgrading from vista to xp sp2
I know this problem, The HDD is a SATA disk, win XP setup cannot identify a SATA controller on it's own you need to load the driver (from a disk) so you may need to download it first. I think this is the correct link extract the files and burn to a CD or Floppy then run win XP setup by booting from CD you should see in the begining of win XP setup from CD it prompt you to press (I think) F2 to add RAID or SCSI Controllers, (this prompt is at the bottom of the screen) Then follow the propmts to load from the disk you made earlier. you should be able to select the controller from a list. (short list) you should then be able to continue and hopefully Win XP setup should now be able to see your HDD and give you choices about which partition (as per normal) you want to remove all partitions before installing winXP (you can then make whatever partitions you wish) Hope this helps
Aug 06, 2007 | Compaq Presario 1200XL104 Notebook
ATI Asus P4R800-V Deluxe Radeon FSB800 Prescott Ready Motherboard (MOTAS30) Logo
154 people viewed this question
Top ATI Computers & Internet Experts
Computer Links
Alun Cox
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
