Question about Acer X191WSD Monitor
MY SCREEN WENT DIM AND DARKER THAN NORMAL NEED TO KNOW WHERE TO GET A REPLACEMENT
  • Richard C Cohen
    Richard C Cohen Oct 01, 2009
    Hello. Did the screen start "pinking" when turned on before this happened? The symptom you're describing is most likely from dying fluorescent tubes concealed behind the edges of the monitor screen. They provide the bright and vivid colors and the backlighting. Is the monitor under any kind of warranty? Sometimes you can find a facility that repairs the displays but, usually, the cost of fixing them is competitive with the cost of a brand new unit.(I have the same problem with my daughter's laptop) If the picture is still being displayed on the screen but it appears black or extremely dark, either the tubes or the power supply that feeds them is going bad.
    The repair is involved so keep "monitor replacement" in the back of your mind. Hope I helped you.---Rick
    p.s. If the screen is black, you can check to see if the image is indeed there by using a bright flashlight close-up.
    Guru:
  • 355 Answers
From acer delar or contact acer company
Posted on Oct 02, 2009
Vizio xvt3d554sv
it is s problem witg ccfl backlight , the amazon link is just example, you must get the corect length of tube, and size
Oct 13, 2013 | Televison & Video
Samsung LCD TV Problem with Video
If this is a LCD, you have a failing LCD panel. Typical of older Samsung sets!
Jun 10, 2013 | Samsung Televison & Video
Dull laptop screen back light
You may have a faulty CCFL lamp. A faulty CCFL lamp may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering and/or with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight or a faulty inverter that supplies high voltage to the CCFL lamp. Usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.lcdparts.net
Dec 30, 2009 | Dell Latitude C610 Notebook
The left side of my Dell inspiron screen is darker than the right. Changing the brightness only changes the brightness proportionately. any suggestions
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 29, 2009 | Dell Inspiron 1525 Laptop
Screen is half dark and whistles when battery is unplugged
You could have a defective screen, either a faulty inverteror a CCFL lamp - follow this to determine the fault.
Apr 15, 2009 | Dell Inspiron 1521 Laptop
Delll axim x30 screen remains dimmed even though fully charged
ok , you have checked the brightness settings, check battery power settings as well. you may have to do a hard reset so back up your info. If doing a hard reset, pull the battery and charge it on its own if you have a cradle. Hope this works for you
Feb 28, 2009 | Dell Axim X30 Pocket PC
Tv is dim
Ned more info as do all things including the on screen display look darker then normal???how old is set??
Mar 31, 2006 | Mitsubishi VS-70709 TV
Acer X191WSD Monitor Logo
136 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
