Question about Hoover Steam Vac Dual V w/ SpinScrub Vacuum
Water tank leaks
Hoover steam vac -- when filled with water, water tank leaks from bottom.
    Scholar:
  • 190 Answers
If the tank is leaking, when removed from the cleaner, it is not user serviceable.
Posted on Oct 03, 2009
2 Suggested Answers
  • 190 Answers
SOURCE: hoover steam vac leak from the bottom when tank
The tank is not sealing to the black rubber ring seal on the lower handle. make sure this seal is not displaced.
Posted on Nov 20, 2009
I have a Hoover V Steam Vac model F7412. The tank for the clean water and cleaner fluid leaked out the bottom. I purchased a new tank but something in that area is still leaking. I know it is not the...
My clean solution tank is leaking from the bottom, too. It is not a hose or a valve. The clean solution tank is leaking in-between the clear plastic walls of the solution tank & the grey plastic bottom that are connected, together. I was thinking of caulking it all around the bottom where the clear plastic sides join the grey bottom plastic. I can't get into ordering a new one (spending $) unless Hoover will send me a new one for free. Purchased at Kohl's in Massapequa, NY in June 2008. There's a one year warrantee AND the directions say to EMPTY the solution tank after each use. Which I normally do because the tank runs dry.
Aug 08, 2014 | Hoover Steam Vac Dual V w/ SpinScrub...
Repair hoover steam vac F7210
Fixya does not make servicing recommendations.
Jul 23, 2017 | Vacuums
My Hoover steam vac dual v clean water and detergent tank leaks water before attached to the vac and during cleaning
This is a common problem with the earlier models which had a separate soap tank glued to the clean water tank. The plastic was too thin beneath the valve on the clean water side and would develop cracks. You most likely will need a new one piece tank. ( Part # 42272104)
May 21, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
Using my hoover steam vac tonight and too much water coming out. once it's turned on, water and shampoo continuously come out underneath until tanks are empty. looks to be leaking from left side bottom as...
make sure that you have filled everthing properly and the hoover steam is in a good condition. or check else is there any loose coonections in the bottom of the hoover, which makes the tank empty.
if the problem persists take it to service.
Feb 25, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover steam vac leak from the bottom when tank has water in it when not running but tank is not leaking
Nov 19, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
Leaking tank
(1) Does water or chemical leak from the tank when filled, but before it is installed? If not, then the tank is OK.
(2) If the tank is not properly aligned to the lower handle when assembled and latched, the black rubber seals on the handle will not seal to the tank. You may wish to look at this. Also, make sure both round black rubber seals are present on the flat mount where the tank valves will sit.
Oct 05, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover Steam Vac V2 Deep Cleaner leaking clean water
Fill the tank and determine if the plastic is leaking, or if the valves are leaking. if the tank is cracked, it would need replaced. There is an improved design now available.
You may cycle the valves on the bottom with the eraser end of a pencil.
Sep 24, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover Steam Vac V2 Leaks from Bottom
That is not the solution. I have purchased several tanks and the issue is not the tank it is leaking from the bottom of the unit. can you please let me know if you found a real fix? thx for your time
Jul 20, 2009 | Hoover F7220900 SteamVac V2 Upright Vacuum
Hoover steam vac spin scrub leaking cleaning solution
The hose leading from the tank to the sprayer head on the bottom of the unit, or the tank is not seated properly or the tank has a hole or crack
Feb 14, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover Steam Vac clean water tank valve leaks
a) make sure that there is not a place for a stair attachment. If
there is make sure air is not leaking through where the attachment goes
on because of damaged or misplaced fitting.
b) some steam vacs leave water behind them and **** up in front of
them. If you just walked forwad with the steam vac nothing would be
sucked into the tank.
c) try taking your finger off the trigger and using the steam vac. If
the tank still empties the trigger is stuck open.
d) try putting clean water in the dirty water tank only and using it on
a dry rug. If water goes somewhere from the dirty water tank you have
a leak.
e) take apart what you can and look at the parts. A good visual
inspection can solve many of these types of problem if you are careful
not to miss anything.
Nov 06, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover Steam Vac Dual V w/ SpinScrub Vacuum Logo
1,702 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
