Question about Fujitsu Office Equipment & Supplies
[sa010771] error. nothing is defined for the event scan assigned to the scanner button you have pressed. Scanner is not responding nor scanning
  • Dave Lovell
    Dave Lovell Jun 08, 2014
    Have just set up my Scansnap S1300i. When i attempt to scan I get the message 'The ADF top section is open' but the Automatic Document Feeder is not open. Can anyone help?
    Problem Solver:
  • 7 Answers
Goethe helped me find it.
Tools > Preferences > "Scan" tab
Switch Device Driver from TWAIN to ISIS / VRS
Posted on Jan 17, 2014
  • First Stop Tech
    First Stop Tech Jan 17, 2014
    Exit out of Preference Panel
    Go to Scan > Select Scanner and choose your model. Click "Select"
    Try scanning again
3 Suggested Answers
SOURCE: getting Error SA010771 for Fujitsu
Found it! To fix the SA010771 error.
This assumes you have already sat there (like I did) and tried everything including adding the event in the scanner settings and changing 0 to ScandALL PRO)
Open Scandall Pro click SCAN - Batch Scan Settings - Add a new profile, for the moment just leave everything as is (change it later). Click Close then close ScandALL PRO and then reopen it.
Click TOOL - Preferences - Event tab, you should now be able to select Profile 1 (or whatever you named it) from the dropdown for Scan.
You can figure the rest out from there : )
Jimi@JamesGoethe.com
Posted on Dec 16, 2011
TechSatya
  • 104 Answers
The error message is ScandAll Pro Scanning Application error. Error code [SA01077I] indicates "Nothing is defined for the event %1 assigned to the scanner button you have pressed.
%1: Event details
<Action> To assign an event, from the [Tool] menu, select [Preferences]. On the [Setup] dialog box opened, select the [Event] tab. Then, configure a batch profile for the event assigned to the scanner button.
For more information, please refer the ScandAll Pro help topics.
Hope the above information is helpful.
Please revert if you have any doubt.
Thank you for contacting FixYa.
Regards,
TechSatya
Posted on Aug 01, 2010
Copy and Scanner not responding
Copier may require you use the scan feature to make copies either ise the feeder otr flatbed. Press start on machine for manual entry but still use scan to get things working.
Nov 15, 2013 | HP HEWLETT-PACKARD CN583A Officejet 6700...
Wand Scanner - panscn08 buttons do nothing
Yes follow the first steps to set up the scanner (charge it, properly insert the memory card, etc.) Then you are ready to scan
Once you press the SCAN button and the Green LED stays lit its time to roll the scanner down your document to be scanned. When finished press the Scan button again to STOP the scan. If successful your Document count in the display will move from 000 to 001. That is the only indication that you now have a successful scan.
Next Press and hold the SCAN button until the display goes blank.
Now you can remove the memory card (by pushing in and it will release). Place this memory card into a memory card reader on your computer to transfer and view your scanned documents. Rinse and repeat.
BTW, I found a quick start guide for this Pandigital Handheld Wand Scanner Model PANSCN08 at:
http://www.qvc.com/footers/E167092_quick-start-guide.pdf
Good Luck!
May 04, 2012 | PANDIGITAL PANSCN Office Equipment &...
The scanner is not scanning as fast as it says its suppose and we just got it why is this
Hello
Make sure EPSON Smart Panel is installed.
If you are using Windows XP:
Click the Events tab in your scanner's Properties dialog box and make sure Take no action is not selected. Also, make sure the desired button is selected in the Select an event list box, and Start this program is selected.
For Windows Me, 98, and 2000 users:
Click the Events tab in your scanner's Properties dialog box and make sure the Disable device events check box is clear. Also, make sure the desired button is selected in the Scanner events list box, and the desired application in the Send to this application list is selected.
For Mac OS X users:
When in Classic mode, the buttons are disabled. Quit Classic mode. Initially, only the user who installed the scanner software can scan using the buttons. Other users must start EPSON Scanner Monitor in the Applications folder before using the buttons for the first time. From then on, pressing a button will automatically start the application assigned to it.
Jun 10, 2011 | Epson GT-2500 Flatbed Scanner
Scanner will not scan
Problems you may have while using the scanner often involve the operation of your software and computer. Operation problems usually occur because of:
Incorrect setup of the interface
Incorrect setup of your computer or software
Incorrect operation of your software
See your Start Here poster to confirm that you have set up the scanner in the correct way. Also, see the documentation that came with your computer and software for possible solutions
IF The scanner does not scan.
Try one or more of these solutions:
Wait until the Start button light stays green (ready for scanning).
Your system may not work properly if you use a USB cable other than the one supplied by EPSON. Use the USB cable that came with your scanner.
The scanner may not work properly when connected to the computer through more than one hub. In this case, connect the scanner directly to the computer's USB port, or through one hub.
Pressing the button does not start scanning
For Windows XP users:
Oct 20, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Psc pt40 in scan mode not responding to key presses
Hello Higlow. If your scanner won't respond to any keys other than the scanning key, I would first recommend a hard-reset of the scanner. To do this, remove the battery and/or disconnect the external power supply, then press and hold the CLR and ENT keys whilst reinserting the battery or power supply and continue to hold the buttons until the unit comes "back to life". This will reset your scanner and clear anything that might be causing problems. If the problem persists, it may be a problem with the software or the main board. If that is the case, please feel free to send me a message or email and I'll be happy to help. Good luck!
Dec 31, 2009 | PSC PT40 (pt40-100l) Portable Terminal
Scanner showing error 04 and cant let me scan
Disconnect the power supply from the back of the scanner base.
Disconnect the USB Interface cable and the ADF Accessory cable from the back of the scanner.
Press and hold the E-mail and Copy buttons at the same time. While pressing the E-mail and Copy buttons, reconnect the power supply to the scanner.
Reconnect the power supply and turn on the scanner.
Press the Scan Doc button. the carriage will start moving back and forth in the full scan bed length. To exit test, disconnect the power supply.
now try to scan the document ..........
Dec 14, 2009 | HP ScanJet 7650 Flatbed Scanner
Getting Error SA010771 for Fujitsu scanner when I press the Scan button
Nov 16, 2009 | Fujitsu fi-5530C Scanner
Want to use my scanner
First in Windows Explorer make sure the scanner can be seen.
If it is there right click on the properties of the scanner. Under the events tab, select the application to open after for scan capture (ScandallPRO, Photoshop, Adobe, etc.).
Just place the page in the paper chute and press the scan button.
It will scan the page and open the Application. Then you can do what you wish.
Jun 01, 2008 | Office Equipment & Supplies
Copy function
well you gotta provide the details in scanners configuration where you want the scanner to copy your Documents to .i.e. whether you want it to scan and store it as a image or open it with some Application or you want it to print just assign any one task with proper configuration it will definately work.
Thanks
Nov 17, 2007 | Canon CanoScan LiDE 30 Flatbed Scanner
Open Questions:
6,747 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Electro Med Services...
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
