Question about IBM Infoprint 1140 Laser Printer
Cannot change paper size of trays 1 and 2. Tray 1 shows legal and want to change to letter.
To disable the operator panel menus so that changes cannot be made to the printer default settings: 1 Turn the printer off. Note: Disabling the operator panel menus does not prevent access to the Job Menu or to Print and Hold functionality. 2 Press and hold Select and Return and turn the printer on. 3 Release the buttons when you see Performing Self Test. Config Menu appears on the first line of the display. 4 Press Menu until you see Panel Menus, and then press Select. Disable appears on the second line of the display. 5 Press Select. Locking Menus appears briefly. 6 Press Menu until you see Exit Config Menus, and then press Select. The menus are disabled. If you press Menu, the message Menus Disabled appears. To enable the menus: 1 Repeat steps 1 through 4. 2 Press Menu until you see Enable. 3 Continue with steps 5 and 6.
Posted on May 18, 2010
How to change tray 1 to plain paper legal of T644
...Tray Tab. Change the Paper Source to Tray 1. Click the Paper Tab. Select in paper size, Letter. Select for Output Size, Same as
Sep 24, 2011 | Lexmark T644 Laser Printer
My Lexmark T640 does not seem to recognize paper "tray 2". I want to print legal, but it only prints from tray 1. How can I get the printer to recognize and use tray 2 so I can print legal AND letter?
2 things
1st make sure the paper guides are set correctly on the trays for legal make sure it's exactly on legal or it put the tray into universal mode. (To clarfiy the guides in the back which allow you to put legal in the tray.)
2nd Go into menu and then to paper menu and adjust/ confirm the settings for tray 1 and 2. Based on your question tray 1 is letter and tray 2 is legal, so make sure both of the tray size and type are set correct.
Oct 21, 2010 | Lexmark T640 Laser Printer
My HP 4100N printer often automatically selects to print from tray 1 (the manual feed), when I want to print from tray 2 (the automatic feed). How do I set the default tray?
HP Laser Jet 4100 HP Not pulling paper from Tray 2
Action: The 4100 will look at tray 1 first then tray 2 If tray 1 is empty it will pull from tray 2 if the papersize matches the job otherwise back to tray 1 and ask for the paper. Your machine likely thinks the paper in tray 2 is not the size you want. For instance you have LETTER in tray2 But the machine thinks it is legal. The LJ 4100 detects the paper size in tray 2 automatically. If you print a configuration page: MENU them INFORMATION then ITEM then CONFIGURATION PAGE then SELECT. The page will print and show what size paper the machine thinks is in Tray 2 if it says LEGAL and you have LETTER you need to Check The Paper Backstop in TRAY 2. The back stop sets the length of the paper if it is not at Letter (8 1/2 x 11) the machine will not detect LETTER. Even if it just a little bit off or between positions.
If it is set at LETTER then you may have bad switches in the machine that are operated by the tray. Or the arms on the tray that operate the switches are not moving properly. You will find the arms on the rt, side of the tray and feel them change position when you move the backstop.
Hope this helps helps. Please keep us updated and remember to rate this answer. TF
Oct 18, 2010 | HP LaserJet 4100n Printer
Paper Available does not include legal (only letter and A4). Tried to go into the Advanced Properties - no legal available? The printer recognizes the legal tray but the laptop does not.
Try setting the paper size in the printer settings.
Click Printer and Faxes then right click on the HP Laserjet 4350 and click on Properties, then Device Settings tab and click on the down arrow and click on Tray 1 or 2 that has the Letter Paper installed and select the Letter paper size. Then click OK.
This paper tray is now configured for Letter paper.
Jun 09, 2010 | HP LaserJet 4350 Printer
Settings in HP Printer LJ 4100.
Hope this helps.
Mar 23, 2009 | HP LaserJet 4100n Printer
Change tray 1 paper size
You need to adjust the green paper size sensor in the back of the tray to letter. This is connected to sensors on the side of the tray. If you set it directly to Letter, then the printer will read the tray as letter paper.
Mar 13, 2009 | IBM Infoprint 1352 Laser Printer
Printer Trays
I have the same problem. Tray 2 shows "!" and doesn not print. PLEASE HELP!
Jul 02, 2008 | Lexmark T632 Laser Printer
Tray output
You should configure TRAY 1 as Legal only.
and Tray 2 as plain letter.
Specially when you specify from what tray/paper type to print.
This can be easily configured from the Printer Properties within the Printers and Faxes section of the Control Panel.
Jan 26, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
Paper tray selection
Go to Paper Menu > Paper Size > Tray 1 - note what the Auto setting states (Letter, A4, Legal, etc.) Pull the tray out to set what it is configured for. Then reinsert it & pull it out a few times, noting what the display show the Auto size show. It should match the tray's settings.
If the Display indicates otherwise, it means one of two things:
1) The "auto size sensing" board on the left may be defective. The left side of the tray has a matrix of 3 plastic tabs that stick out in certain order depending on the tray setting. If this board fails, it may show Executive or A4 when the tray is set for letter.
2) The tray may be in-between two settings. Try to readjust the tray length setting between sizes. (You will notice the plastic tabs will change order.) The last time you loaded paper it may have pushed it just enough so that it is no longer seen as letter by the auto sensing board.
I hope this helps...
Nov 28, 2007 | Lexmark Optra T610 Laser Printer
IBM Infoprint 1140 Laser Printer Logo
233 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
CheckitRight
CheckitRight
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
